Old 12-05-2016, 01:12 PM   #673
ajc209
Drives: GT86 Cosworth
Originally Posted by weederr33 View Post
Lawl was someone tracking their Renault?!
Renault Cilos and MX5s (miata) along with Caterams (or similar) are the staple track cars over here.
You do see quite a few BMWs too.
ajc209 is offline   Reply With Quote
Old 12-05-2016, 05:35 PM   #674
Kodename47
Kodename47's Avatar
Drives: UK GT86
RenaultSport Clios and Meganes make pretty tasty track cars If the French are good at one thing, it's a hot hatch.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-05-2016, 06:43 PM   #675
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'll be honest, if the Renault Meganes RS was available here, I'd buy one. What was the Clio that had the mid engine in it? I think it was a V6 with all wheel drive
MS, CSCS, TSAC-F, CPT
Old 12-06-2016, 03:23 AM   #676
Kodename47
Kodename47's Avatar
Drives: UK GT86
it was just called the Clio V6. It's RWD.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-06-2016, 04:32 AM   #677
ajc209
I'd love a 255 V6
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (12-06-2016)
Old 12-06-2016, 12:07 PM   #678
weederr33
weederr33's Avatar
@Matt@Cosworth
Do you think it's possible to tweak the Stage 2.3 tune for an Unequal length header?
Old 12-07-2016, 02:36 PM   #679
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
yes
I have some alternative cam timing that seems to work OK with UEL's you'll lose a bit of power mind you
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (12-07-2016)
Old 12-07-2016, 10:03 PM   #680
weederr33
weederr33's Avatar
Originally Posted by Matt@Cosworth View Post
yes
How much of a loss is it? And I don't mind because it would be interesting to have an UEL set up with the Cosworth kit. I think SpeedHunters had our kit and had it paired with a set of JDL Auto Design UEL headers if I recall correctly.
Old 12-09-2016, 03:59 PM   #681
Matt@Cosworth
Hello
I have seen a power test with our kit and the JDL header and it was about 6-8Bhp down at the top with a bit of loss mid-range too
still the owner was in love with the 'boxer burble' and 270 ish is still pretty respectable
weederr33 (12-09-2016)
Old 12-09-2016, 04:15 PM   #682
weederr33
weederr33's Avatar
I think I know my next mod come this spring!
Old 12-16-2016, 10:43 AM   #683
pjp
Drives: frs
Exhaust
Just got My 1.2 kit
Has any one installed it with the car up on Ramps?
Not much room but Maybe??
Don't have use of a lift without paying shop to install it!
pjp is offline   Reply With Quote
The Following User Says Thank You to pjp For This Useful Post:
weederr33 (12-16-2016)
Old 12-16-2016, 11:10 AM   #684
Matt@Cosworth
you may struggle for height as the midpipe is now 1 piece you need a fair amount of room under the car to swing the midpipe down and around to get it past the steering column and engine
If you're LHD ( which you probably are) then its a lot better but I'd still bank on needing to get the car about 3' in the air
Old 12-16-2016, 12:02 PM   #685
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Originally Posted by pjp View Post
Just got My 1.2 kit
I installed my 1.2 on ramps. Put the front of the car on ramps. Remove the skid plate and dust shield over the transmission. Remove the two nuts on the engine mount bolts. Jack up the engine just to the point to where the engine mount bolts lift up out of the frame. Don't raise the engine by the oil pan... use something stronger like the transmission or use a hoist. This should give you enough room to remove the factory overpipe and get the Cosworth midpipe in place.
The hard part for me was removing the factory overpipe. The heat shields make it a little hard to remove. But if you jack up the engine enough to get the factory overpipe out, the Cosworth should go in just fine.
No lift needed but it would be easier if you had one. If you haven't installed any of the exhaust yet, I would remove all the factory exhaust and then start by installing the Cosworth midpipe first and then working your way back. Do the axleback last and you will have more room.
sly is offline   Reply With Quote
Old 12-16-2016, 10:06 PM   #686
Insurme1
Drives: 2013 Scion FR-S 10-Series
Matt,
I'm about to lose faith that Cosworth is going to through with stage 3 as proposed. Can you please give an honest update on where you guys stand on this issue?
Insurme1 is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
