Old 12-02-2016, 07:49 PM   #1
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Whiteline Camber Bolt Kit (Rear)
I'm planning to install the rear Whiteline Camber Bolt Kit and was wondering if anyone had experience with installing these? Do you need a press to get the stock bushings out to install these or do they just slip out. Trying to decide if this is the way to go or just get some adjustable lower control arms.
Thanks!
MJones_RB is offline   Reply With Quote
Old 12-05-2016, 12:03 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I have these currently installed.
They are a PITA to install and a PITA to adjust. Your alignment guy will hate you. After install cost they will cost you more then LCAs (they require professional install to remove the old bushings).
On the other hand they drastically stiffen up the rear of the car as well. Buy the non-adjustable bushings if you want to tighten things up and just buy LCAs. They give you more adjustment anyway
MJones_RB (12-05-2016)
Old 12-05-2016, 12:54 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Agreed with @finch1750
SPC LCA's are cost effective, work great and are easy for an alignment shop to adjust.
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
Cole (12-05-2016), MJones_RB (12-05-2016)
Old 12-05-2016, 12:58 PM   #4
Cole
Not a troll
Cole's Avatar
Agreed. My SPC's have treated me well so far. Haven't noticed any slipping, and if they do, it's not terribly difficult to adjust them on your own.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Old 12-05-2016, 02:38 PM   #5
MJones_RB
MJones_RB's Avatar
Thanks to @Cole, @finch1750 & @JazzleSAURUS for the advice. Will get a set of SPC LCA's instead.
The Following User Says Thank You to MJones_RB For This Useful Post:
JazzleSAURUS (12-05-2016)
Old 12-05-2016, 07:21 PM   #6
JazzleSAURUS
Yep!
When you get them installed and aligned, trade around all the adjustables with a paint pen, and make a reference point on both the adjustable bit and where it mounts. This way, if something slips, you know about it, and can get it back to how it was.
Old 12-05-2016, 07:54 PM   #7
MJones_RB
MJones_RB's Avatar
Yep!
Great advice!
What about toe arms? Does that depend on how much if a drop you set? I only plan on about an inch up front, maybe .75" in back.
Old 12-05-2016, 08:08 PM   #8
JazzleSAURUS
Don't bother with toe arms for most applications. The SPC arms come with SPC toe arm bushings that will allow you to get your toe back within spec.
If you're doing this install yourself/with buds in a garage over a few beers, be careful, as installing the toe arm bushings with LCA's will cause a pretty wild ride to result without an alignment depending on how stuff bolts up.
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
MJones_RB (12-06-2016)
Whiteline Camber bolt.... Help FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 04-28-2017 03:15 PM
SOLD: Rear Upper Control Arms WITH Whiteline Camber Bolt Kit KVDB31 Brakes, Suspension, Chassis 16 07-02-2016 10:14 AM
FS: Whiteline Front Camber Bolt Kit immaculate Brakes, Suspension, Chassis 5 08-19-2014 05:24 PM
FS: rce yellows & whiteline camber bolt $300 chappys4life Mid-Atlantic 19 05-13-2013 02:31 PM
