Old 12-03-2016, 02:53 PM   #15
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by wbradley View Post
Unless you are a hardcore racer, radiator is fine. If you are driving in 85 degree weather every day and want to check oil temp and coolant temp, get an ELM 327 BT OBD2 dongle for $20 on Amazon, then download Torque on an Android device. There is an extra step to install oil temp plug-in.
I have monitored temps NA on a track and doing lots of pulls while FI both with and without an oil cooler.
With my setup I made the following observations:
-While NA on the time attack track, it took maybe 5 mins to reach dangerous temp. 125 C/230 F is where most 0W30 thins out.
-FI with oil cooler can go all day no oil temp issues
-FI without oil cooler gerts up to 120 C after several pulls on my drive home from work.
-Coolant has never gotten far above normal range ever.
Conclusion- Oil cooler definitely advisable, but not ESSENTIAL for daily driver. Upgraded radiator not needed. If your hot days are that bad, get a lower temp thermostat. Not Mishimoto, supposedly they are having breakage issues.Catch can highly variable. I collect a few drops every few thousand miles, literally.
Do use thicker oil especially if no oil cooler. I don't recommend the oil warmer/light cooler from Subaru EJ and FA20T engines. It is probably mostly there to heat up the oil quicker for the turbo. Not much cooling effect vs conventional air/liquid heat exchanger.
Awesome thanks man. Will invest in an oil cooler. This will be more a light daily driver main weekend car but not too much track time yet.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 12-03-2016, 03:36 PM   #16
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Originally Posted by johl View Post
May as well look at the Jackson racing dual radiator and oil cooler
Heat soak and IAT are increased without air ducting modifications.
menikmati is offline   Reply With Quote
Old 12-03-2016, 05:24 PM   #17
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@Xxyion - Neal advised against the Jackson radiator/oil cooler due to the way the lines are routed. The Perrin oil cooler works fine - that's what was on the car that got an Edelbrock when I was at the shop yesterday.
For iOS you can use DashCommand to monitor temps. It's $10 plus another $10 for the 86 specific PIDs. You'll need a wi-fi dongle instead of Bluetooth. Be careful with the OBD2 port - my cheap wi-fi dongle bent the pins after repeated use. I recommend getting an OBD2 extension cable and plugging the dongle into that. Can post some Amazon links for you later. Happy to demo the app for you at the shop or a local meet sometime.
TofuJoe is offline   Reply With Quote
Old 12-03-2016, 05:59 PM   #18
Amputechture
Drives: 2014 BRZ
I have one of the OEM liquid coolers. The highest I've seen it reach is 109C, it usually stays around 90C with normal driving. I have noticed it does not do exceptionally well at keeping peak temps down, but recovery/decrease times are much better than without it. The fact that you can get up to operating temp so quick is worth it's price tag alone imo.
Does the Edelbrock kit come with a map sensor? If not, you'll definitely need that.
Amputechture is offline   Reply With Quote
Old 12-03-2016, 06:31 PM   #19
Xxyion
Lowly Cartuber
Xxyion's Avatar
Thanks so much man! Yeah I was already looking at the Perrin Oil Cooler as it was recommended to me from a few friends. I'll definetly have to check out that app you suggested. I'm curious if I can actually use my Dashlinq head unit and side load an android app and connect via Bluetooth. It would keep the interior a lot cleaner
Old 12-03-2016, 06:38 PM   #20
TofuJoe
Ohne Titel
TofuJoe's Avatar
There are definitely some people using the Torque app on Android head units. Seems like a really clean setup.
Old 12-03-2016, 07:35 PM   #21
CSG Mike
CSG Mike's Avatar
Oil cooler w/ 0W20 will have MPG benefits on a daily driver, compared to xW30 without oil cooler.
wbradley (12-04-2016)
Old 12-03-2016, 07:35 PM   #22
CSG Mike
CSG Mike's Avatar
A TMAP is included with the Edelbrock kit. It's unlikely that anyone will outgrow it
Amputechture (12-03-2016)
Old 12-03-2016, 07:46 PM   #23
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by Xxyion View Post
What can i expect?
Your engine to blow up.
Sent from my Nexus 5X using Tapatalk
enivid is offline   Reply With Quote
Old 12-03-2016, 11:18 PM   #24
menikmati
2.5 bar Bosch.
Old 12-04-2016, 04:37 AM   #25
Kodename47
Kodename47's Avatar
Drives: UK GT86
it does, but it's utter rubbish that you need one if it didn't. It's not a turbo.... You can't overboost. In fact, why do you think the D-Box makes such a difference? You wouldn't have that issue with the OEM MAP sensor, nor a TMAP with the same range.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-04-2016, 03:33 PM   #26
Amputechture
Drives: 2014 BRZ
D-Box? Can't say I'm familiar with this 'd-box' you speak of. Boost amount can vary by atmospheric pressure and weather dictating density. Even with a set amount of boost per the pulley...I would not want to risk my ecu not being able to properly correct fueling/timing because I didn't want to spend 90 bucks on a MAP sensor.
Old 12-04-2016, 07:57 PM   #27
CSG Mike
CSG Mike's Avatar
Because of the TMAP's location.
Old 12-04-2016, 08:44 PM   #28
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Oil cooler if you track it or illegally drive as if you were tracking it. Not a necessity for a daily driver as much unless you do one pull after the other repeatedly.
Catch can also not a necessity unless tracking. It might collect a few drops of oil here and there.
Next oil change switch to thicker 5W30 for keeping viscosity at higher temps.
If you haven't already upgraded your tires now you will be thinking very seriously about it while spinning in 1st, 2nd and 3rd.
Xxyion, couldn't help but notice you list your colour as WRP. World Rally Poo?
Like this guy...realistic, common sense answers...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following User Says Thank You to paiceyfan For This Useful Post:
wbradley (12-05-2016)
Week-End Pics ? Did you get any sweet shots of your 86 this week-end ? BC-Boy BRZ Photos, Videos, Wallpapers, Gallery Forum 36 05-28-2014 01:14 AM
FR-S/BRZ Week – Exciting Week For Owners 86_Insider Scion FR-S / Toyota 86 GT86 General Forum 2 08-09-2013 06:38 PM
What to expect? Obja Scion FR-S / Toyota 86 GT86 General Forum 13 06-08-2013 12:08 AM
When to expect BRZ STI AndreaCristiano BRZ First-Gen (2012+) — General Topics 66 08-07-2012 07:46 AM
MY GF's FRS confirmed for last week of May or first week of June clayrush Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2012 04:45 PM
