Old 12-02-2016, 07:47 PM   #1
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Getting boosted in a week...what to expect?
Hey Guys,
So i ordered my Edelbrock Kit with a Delicious tune which will be installed on the 10th. I'm beyond excited. I've never done modifications to this extent before so part of me is a bit nervous. Just a few questions.
What can i expect? As much as my mind is thinking crazy amount of power and torque everywhere...thats probably not realistic.
What are some supporting mods i should consider? (hood vents, boost gauge...etc.)
I want to keep this as reliable as possible and so any sort of supporting mods that would up the reliability would help.
For those of you on the Edelbrock kit...any major issues i should keep in mind or be aware about? Also what kind of power are you making reliably. I'll be on 91 Octane. Most likley no E85 as it's not in a convenient location for me.
Do you regret your decision at all?
Thanks in advance for the answers and help!
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 12-02-2016, 08:29 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Oil cooler and catch can. I didnt think so but i was creating crack case pressure and creating oil leaks so... ya... oil cooler fixed the issue with timing being pulled when car heated up tomuch.
Clutch, the factory just wont last.
Exhaust that breaths helps the car rev faster.
Motor mounts and transmission mounts made it easier to disengage the clutch. Factory motor mounts and transmission mounts cause a nasty vibration.
Just get ready to spend 10k
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-02-2016, 08:53 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Oil cooler if you track it or illegally drive as if you were tracking it. Not a necessity for a daily driver as much unless you do one pull after the other repeatedly.
Catch can also not a necessity unless tracking. It might collect a few drops of oil here and there.
Next oil change switch to thicker 5W30 for keeping viscosity at higher temps.
If you haven't already upgraded your tires now you will be thinking very seriously about it while spinning in 1st, 2nd and 3rd.
Xxyion, couldn't help but notice you list your colour as WRP. World Rally Poo?
Old 12-02-2016, 09:54 PM   #4
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I'm currently running the Edelbrock kit with a Delicious tune on an otherwise stock car.
No other modifications necessary if the car is driven normally, although I would try to adhere to a shorter OCI (oil change interval).
As far as oil coolers, I'm still waiting for a proven setup that is 100% compatible with the Edelbrock kit before I make the leap. Current oil temps are around 200-210F during my commute.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
paiceyfan (12-04-2016)
Old 12-02-2016, 10:10 PM   #5
GsxrMe
GsxrMe's Avatar
Oh i used the same 1 as all turbo subis use. Heats up oil quicker when cold and keeps the oil alittle lower as im spanking red light to red light.
Goto the subaru dealer and order all the same hoses and pipes as the factory forester xt uses. Looks like complete stock. Parts guide is on the forums.
5w30 oil is a must
2014 Subaru BRZ
Old 12-02-2016, 11:17 PM   #6
You ordered the kit and now are asking what else you need?
AJPG (12-04-2016), gramicci101 (12-03-2016), Jmonty (12-02-2016), Marat (12-03-2016), menikmati (12-02-2016), Summerwolf (12-03-2016)
Old 12-03-2016, 06:03 AM   #7
Hugo
Drives: Toyota 86
1. Boost/AFR and Oil Pressure Gauge (If you want a third gauge get Oil Temp)
2. 5w30 oil
3. Catch Can
4. Motor/Trans/Diff Mounts (i went with STI mounts as it was stronger then stock but isn't as harsh as perrin or cusco)
5. Clutch (Depending on power levels)
6. Fuel Pump/Injectors (Again, depending on power levels)
7. Oil Cooler (Depending on how you drive)
8. Radiator/upgraded fans (Again, depending on how you drive)
IMO, the first 4 are a must to get you started for FI, and as far as i know, vented hoods isn't as necessary compared to if you went the turbo route, but will be beneficial for your driver and passenger coils regardless. (As demonstrated by Velox)
Hugo is offline   Reply With Quote
Old 12-03-2016, 08:46 AM   #8
GsxrMe
GsxrMe's Avatar
2. 5w30 oil
3. Catch Can
I agree with your list. Your better safe than sorry. Don't be cheap and blow you shit up like so.... many do on the forums.
Cusco mounts are rock hard, the engine/transmission has like no movement at all. The idle vibration was noticed after install like instantly. But with the Cusco mounts the car gives a sense of something has been done to the car feeling when someone sits in it for the first time. The turbo with this exhaust is very very stock sounding until I give it a decent amount of pedal.
Again whatever you path is, please don't take the cheap "well maybe next time route". Get a complete list together and do it correctly. Your better spending the extra $200 on an oil cooler than 3k on a short block.
Show me one Turbo Subaru that doesn't have atleast the oil cooler below installed from factory. You wait, you won't find one.! The link is below.
Forester XT Cooler
http://www.ft86club.com/forums/showthread.php?t=50427
I don't recommend the 2 piece barb for the block. JEGS has a 1 piece that doesn't leak. I can provide the PN that I used if PM'd
2014 Subaru BRZ
Old 12-03-2016, 10:13 AM   #9
CSG Mike
CSG Mike's Avatar
Any EJ turbo engine, that isn't an STI.
Old 12-03-2016, 11:24 AM   #10
Xxyion
Lowly Cartuber
Xxyion's Avatar
Hahaha sorry I should have stated that I've already done most of my research. Everything listed so far seems to match up with what I've looked at. I do this though on the off chance someone mentions something critical that I overlooked during my many hours of forum browsing. Just my own fail safe.
The Following User Says Thank You to Xxyion For This Useful Post:
Tcoat (12-03-2016)
Old 12-03-2016, 11:26 AM   #11
Xxyion
Lowly Cartuber
Xxyion's Avatar
Hahaha. World Rally Pearl Blue. Is that not correct?
Old 12-03-2016, 11:29 AM   #12
Xxyion
Lowly Cartuber
Xxyion's Avatar
Thanks a lot for the responses guys. The one thing I never thought of was the radiator. Will look into that.
Old 12-03-2016, 01:04 PM   #13
johl
johl's Avatar
Drives: toyota 86
May as well look at the Jackson racing dual radiator and oil cooler
johl is offline   Reply With Quote
Old 12-03-2016, 01:48 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
Unless you are a hardcore racer, radiator is fine. If you are driving in 85 degree weather every day and want to check oil temp and coolant temp, get an ELM 327 BT OBD2 dongle for $20 on Amazon, then download Torque on an Android device. There is an extra step to install oil temp plug-in.
I have monitored temps NA on a track and doing lots of pulls while FI both with and without an oil cooler.
With my setup I made the following observations:
-While NA on the time attack track, it took maybe 5 mins to reach dangerous temp. 125 C/230 F is where most 0W30 thins out.
-FI with oil cooler can go all day no oil temp issues
-FI without oil cooler gerts up to 120 C after several pulls on my drive home from work.
-Coolant has never gotten far above normal range ever.
Conclusion- Oil cooler definitely advisable, but not ESSENTIAL for daily driver. Upgraded radiator not needed. If your hot days are that bad, get a lower temp thermostat. Not Mishimoto, supposedly they are having breakage issues.Catch can highly variable. I collect a few drops every few thousand miles, literally.
Do use thicker oil especially if no oil cooler. I don't recommend the oil warmer/light cooler from Subaru EJ and FA20T engines. It is probably mostly there to heat up the oil quicker for the turbo. Not much cooling effect vs conventional air/liquid heat exchanger.
The Following User Says Thank You to wbradley For This Useful Post:
menikmati (12-03-2016)
Week-End Pics ? Did you get any sweet shots of your 86 this week-end ? BC-Boy BRZ Photos, Videos, Wallpapers, Gallery Forum 36 05-28-2014 01:14 AM
FR-S/BRZ Week – Exciting Week For Owners 86_Insider Scion FR-S / Toyota 86 GT86 General Forum 2 08-09-2013 06:38 PM
What to expect? Obja Scion FR-S / Toyota 86 GT86 General Forum 13 06-08-2013 12:08 AM
When to expect BRZ STI AndreaCristiano BRZ First-Gen (2012+) — General Topics 66 08-07-2012 07:46 AM
MY GF's FRS confirmed for last week of May or first week of June clayrush Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2012 04:45 PM
