Old 12-02-2016, 12:36 AM   #379
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Originally Posted by novice View Post
I was thinking about getting rfp1 for weight reduction and wanted something wider but the rpf1 17x8 at 15.6 lbs and MPSS at 23 lbs. If the stock wheels are 38lbs the it seems like the stock wheels are just fine weight wise. Not sure how your 17x9 are lighter thatn the 17x8s. Unless the white papers from enkei and Michelin are off.
Guess I can "weight" to wear the stock tires down first as all I would gain is better grip and I'm not a racer. might even just keep it stock as it would be marginal aesthetic changes for the most part. I don't even care for the looks of the rpf1 just thought they were a lot lighter.
Sorry can only tell you what I've seen and tested myself, remember this are both measurements with wheel/tire/sensors all together, and the rpf1 17x9 with 255's vs stock 17x7.5 215's. Hopefully next week I'll be putting some brand new 255 R888R and will update with that weight
Sent from my XT1650 using Tapatalk
StegaDragon is offline   Reply With Quote
The Following User Says Thank You to StegaDragon For This Useful Post:
gypsy_seven (12-02-2016)
Old 12-02-2016, 07:42 AM   #380
novice
novice's Avatar
Drives: Fr-S 2.0 Release
The stock wheels AND tires are 38 pounds.
yup, and so are the rpf1 17x8 with tires. both are 38 lbs. there is no weight loss by going to the rpf1, just gain width which is nice but not worth the money to change from a brand new set of wheels and tires for me at the moment.
novice is offline   Reply With Quote
Old 12-02-2016, 08:03 AM   #381
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
A good place to start with weight reduction is taking out the useless rear seats. The seating material with all the steel seat belt hardware was decent.
FyeaFRS is offline   Reply With Quote
Old 12-02-2016, 08:42 AM   #382
novice
novice's Avatar
i got kids, yo i'm removing spare and getting small battery. i don't live far from work and do not use this car for long trips.
but here is the rpf1 weights
http://enkei.com/wp-content/uploads/2015/07/RPF1.pdf
tires are generall around 23-26 lbs. I use MPSS for general reference. I don't know if they are heavier than other performance tires. But as you will see wheel and tire on a rpf1 17x8 is 38 lbs. I'm assuming larger the wheel/tire, more weight.
215/45ZR17
(91Y) XL
300 AA A 1,356 lbs. 50 psi 10/32" 21 lbs. 7-8" 7" 8.4" 7.7" 24.7" 844 US
225/45ZR17
(94Y) XL
300 AA A 1,477 lbs. 50 psi 10/32" 22 lbs. 7-8.5" 7.5" 8.9" 8.2" 25" 833 US
235/45ZR17
(97Y) XL
300 AA A 1,609 lbs. 50 psi 10/32" 22 lbs. 7.5-9" 8" 9.3" 8.2" 25.4" 821 US
245/40ZR17
(95Y) XL
300 AA A 1,521 lbs. 50 psi 10/32" 23 lbs. 8-9.5" 8.5" 9.8" 8.5" 24.7" 841 US
245/45ZR17
(99Y) XL
300 AA A 1,709 lbs. 50 psi 10/32" 23 lbs. 7.5-9" 8" 9.6" 8" 25.7" 810 US
215/40ZR18
(89Y) XL
300 AA A 1,279 lbs. 50 psi 10/32" 20 lbs. 7-8.5" 7.5" 8.6" 7.7" 24.8" 840 US
225/35ZR18
(87Y) XL
300 AA A 1,201 lbs. 50 psi 10/32" 20 lbs. 7.5-9" 8" 9.1" 8.2" 24.2" 859 FR
225/40ZR18
(92Y) XL
300 AA A 1,389 lbs. 50 psi 10/32" 22 lbs. 7.5-9" 8" 9.1" 7.9" 25.1" 829 US
225/40ZR18
88Y SL
Star BMW 300 AA A 1,235 lbs. 51 psi 10/32" 21 lbs. 7.5-9" 8" 9.1" 7.9" 25.1" FR
225/45ZR18
(95Y) XL
Star BMW 300 AA A 1,521 lbs. 50 psi 10/32" 22 lbs. 7-8.5" 7.5" 8.9" 7.6" 25.9" 802 FR
225/50ZR18
(99Y) XL
300 AA A 1,709 lbs. 50 psi 10/32" 24 lbs. 6-8" 7" 9.2" 8.2" 26.9" 774 US
235/40ZR18
(95Y) XL
300 AA A 1,521 lbs. 50 psi 10/32" 23 lbs. 8-9.5" 8.5" 9.5" 8.5" 25.4" 819 US
235/45ZR18
(94Y) SL
300 AA A 1,477 lbs. 51 psi 9/32" 23 lbs. 7.5-9" 8" 9.3" 8.6" 26.3" 790 FR
235/50ZR18
(101Y) XL
300 AA A 1,819 lbs. 50 psi 10/32" 26 lbs. 6.5-8.5" 7.5" 9.7" 8.7" 27.3" 762 US
245/35ZR18
92Y XL
Star BMW 300 AA A 1,389 lbs. 50 psi 10/32" 22 lbs. 8-9.5" 8.5" 9.8" 9.2" 24.8" FR
245/35ZR18
(92Y) XL
300 AA A 1,389 lbs. 50 psi 10/32" 23 lbs. 8-9.5" 8.5" 9.8" 9" 24.8" 840 US
245/40ZR18
97Y XL
MO Mercedes 300 AA A 1,609 lbs. 50 psi 10/32" 24 lbs. 8-9.5" 8.5" 9.8" 8.6" 25.7" 809 FR
245/40ZR18
(97Y) XL
300 AA A 1,609 lbs. 50 psi 10/32" 24 lbs. 8-9.5" 8.5" 9.8" 9" 25.7" 809 US,FR
245/45ZR18
(100Y) XL
300 AA A 1,764 lbs. 50 psi 10/32" 24 lbs. 7.5-9" 8" 9.6" 8.5" 26.7" 780 FR
255/35ZR18
(94Y) XL
300 AA A 1,477 lbs. 50 psi 10/32" 25 lbs. 8.5-10" 9" 10.2" 9.5" 25" 832 US
255/35ZR18
(94Y) XL
TPC Spec 300 AA A 1,477 lbs. 50 psi /32" 24 lbs. 0-0" 9" US
255/40ZR18
(95Y) SL
Star BMW 300 AA A 1,521 lbs. 51 psi 10/32" 24 lbs. 9-10" 9" 10.2" 8.5" 26" 799 FR
255/40ZR18
(99Y) XL
300 AA A 1,709 lbs. 50 psi 10/32" 25 lbs. 8.5-10" 9" 10.2" 9.5" 26" 799 US
255/40ZR18
(99Y) XL
Star BMW 300 AA A 1,709 lbs. 50 psi 10/32" 25 lbs. 8.5-10" 9" 10.2" 9.2" 26" 799 US
265/35ZR18
(97Y) XL
Old 12-02-2016, 09:40 AM   #383
funwheeldrive
I use my seats at least once a week. You are obviously not a dad.
Now, the spare tire on the other hand....
The Following User Says Thank You to funwheeldrive For This Useful Post:
HKz (04-07-2017)
Old 12-02-2016, 11:47 AM   #384
FX86
I read on here sometime ago that removing the spare tire changed the handling dynamics of the car and not for the better...can anyone vouch for that?
Old 12-02-2016, 12:11 PM   #385
novice
novice's Avatar
makes sense. i'm sure the engineers balanced the car for stock inventory.
Old 12-02-2016, 01:59 PM   #386
funwheeldrive
I heard the same thing too. I kept the spare for about a year before taking it out. It just feels like you are driving with less fuel in your tank.
I store my emergency bag (jumper cables, medical kit, flashlights, etc.) down there, so there is still a little weight in that location.
Old 12-03-2016, 07:56 PM   #387
WNCFRS
Drives: 2016 FRS RS 2.0 auto #921
Problem with RS 2.0 climate control
Not sure if this is the best place to post this question but figured RS2 owners would see it.
I've had my RS2 for about six months and look forward to driving it every chance I get. Can't say I've felt that way about a car since my 67 Stingray twin top. One relatively minor issue I've noticed is that the temperature setting seems to be wildly inaccurate. In the summer I would have to set it around 62 or less for reasonably cool air and recently when some warming is required I have to keep it in the same area to not get roasted. I admit this is merely my mental comparison to settings in our 2014 Prius or 07 Rav4, both of which have digital climate control. It seems like my required setting in the FRS is around six or seven degrees lower for about the same temp.
My next step is to keep a digital thermometer in the car to get some hard numbers but just thought I'd ask if any other RS2 owners are experiencing the same issue. My thought is perhaps a faulty temp sensor somewhere.
WNCFRS is offline   Reply With Quote
The Following User Says Thank You to WNCFRS For This Useful Post:
SC10N (01-14-2017)
Old 12-04-2016, 08:27 AM   #388
michaelchatten
Drives: 2016 FR-S RS 2.0
Mine is the same way. I crank it up on a cold morning by once it's warmed up anything for me about 66 is just to damn hot especially if I have it on the vents pointing at me. I usually keep it on the windshield and floor.
michaelchatten is offline   Reply With Quote
Old 12-05-2016, 07:12 AM   #389
LancePower
Drives: 2020 BRZ tS
Originally Posted by bmont12 View Post
Little late to the party, but I have 835. Purchased her back in august here in Toronto
Velcome to da club.
LancePower is offline   Reply With Quote
Old 12-05-2016, 10:39 AM   #390
FyeaFRS
i got kids, yo
Well that's what you get for being breeders
The Following 2 Users Say Thank You to FyeaFRS For This Useful Post:
funwheeldrive (12-28-2016), novice (12-05-2016)
Old 12-05-2016, 04:28 PM   #391
thatchmaster
@WNCFRS -- You'd probably get some better views if you crosspost this as a new thread as this climate control is the same as the BRZ Limited, FR-S 10 Series, RS 1.0, etc.
I have a similar experience. My quick guess is that it's related to the location of the ambient/interior temperature sensor. If it's not in an area around where the heat is blowing, it's likely that the system will [over]compensate (I haven't bothered to look for it). In a previous car, I set the temp around 72 and never really had to change it. In this, I'm anywhere from 62-68 to keep a similar feeling. The interior is small here, too, so small temperature changes may affect the sensor(s) as well (?).
thatchmaster is offline   Reply With Quote
Old 12-19-2016, 09:39 PM   #392
StegaDragon
Just quick update because I said I would
FR-S 10 Series Registry torqdork Scion FR-S / Toyota 86 GT86 General Forum 2518 12-11-2025 02:12 PM
FT86Club's BRZ Series.HyperBlue Owners Registry Veloist BRZ First-Gen (2012+) — General Topics 961 05-14-2025 06:47 PM
FR-S Monogram Series Registry Chad86 Scion FR-S / Toyota 86 GT86 General Forum 79 09-10-2021 10:14 PM
FR-S Release Series 1.0 Registry brianFKNmyers Scion FR-S / Toyota 86 GT86 General Forum 800 10-26-2020 09:18 PM
'Unofficial' US BRZ Series.Blue Registry Jimmy45brz BRZ First-Gen (2012+) — General Topics 110 08-15-2017 07:37 PM
