Old 11-30-2016, 01:04 AM   #239
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Originally Posted by Joeyk View Post
^ this ...
Ask what color undies I'm wearing next. Ian Senpai knows everything!!
You're dyno chart is what sold me on this kit.. Do you know what A/R your turbo is?
And are you on a built short block? If so would you mind sharing the CR ?
Cheers
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 11-30-2016, 01:07 AM   #240
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
Got mine in, but unfortunately not through Eric.
He helped me make the final decision in choosing the kit over other kits out there.
Love the kit fast spool, great power band, and bad ass noise. What's not to like?
Here are some Pictures of my kit.
This was one of the pulls. Final numbers were 380hp and 340 TQ.
Which reminds me I need to have my tuner send me the final chart haha.
Did they offer that intake with the kit? Mine didn't even come with a filter lol
Sent from my SM-N920T using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 11-30-2016, 09:40 AM   #241
Joeyk
Drives: It runs
They offer intake as option. But I think it will be 2.5" pipe.
I had custom made a 3" intake.
7 track days in since the install in august still running like day one.
Oh stock internals... just slap the kit in and get a good tune is all you need for it to run well. No problems.
Joeyk is offline   Reply With Quote
Old 11-30-2016, 09:41 AM   #242
Joeyk
Drives: It runs
Cheers
Stock block. 71/63
Old 11-30-2016, 09:53 AM   #243
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Their kit now comes with a 2.5" filter automatically and an optional 3" cold air intake they fixture'd off the one I made for my car.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 11-30-2016, 01:10 PM   #244
olsonpg
olsonpg's Avatar
Stock block. 71/63
Full race site gives two options for the 71/63 for this kit.
I wonder what the Velox kit uses?
There's the EFR 71/63 0.80 A/R IWG (T4) OR the EFR 71/63 0.85 A/R IWG (T25).
Cheers
Old 11-30-2016, 01:17 PM   #245
VerusEric
VerusEric's Avatar
Cheers
You can always ask me .
Joey and myself run the 0.80 A/R TS (Twin Scroll) T4 IWG (Internal Wastegate) option of the kit. It has been proven multiple times that twin scrolls out-perform single scroll variants in transient, mid-range, and top-range power, it is a superior design. It seems like a no-brainer to me to run the T4 twin-scroll vs. the single scroll but ultimately the decision is up to you.
Thanks,
Eric
Old 11-30-2016, 01:34 PM   #246
olsonpg
olsonpg's Avatar
Thanks,
Eric
Cheers brother, thanks for the quick response.
So I assume the package kit on your site is the .80 AR twin?
I'm really torn between the EFR 67/58 0.80 A/R T4 and the 71/63 .80 T4.
I want to mimic your guyses power numbers and torque curve but was thinking that maybe with the 67-58 I could reach similar torque numbers just a bit sooner? What are your thoughts?
If I did choose to go with the 67-58 would I be able to get it through you?
Old 11-30-2016, 01:36 PM   #247
gabeg86
gabeg86's Avatar
I have the 6758 and I love it. Can't compare to the 7163, but I'm very happy with my choice.
Old 11-30-2016, 01:42 PM   #248
olsonpg
olsonpg's Avatar
Ah thanks for your input, i just realized you've had this kit for over a year now!
I love that intake you have. Is it custom?
You wouldn't happen to have any dyno sheets would ya?
Still on stock block as well?
Cheers
Old 11-30-2016, 02:06 PM   #249
gabeg86
gabeg86's Avatar
Cheers
Yup over a year and a half now! Had the block built last winter from heads to crank. Currently running 11.5:1 compression, so my numbers will be a bit different. I'd have to dig around a bit for the dyno sheets. Idk what I did with them haha
Which intake are you referring to? My NA cold air? Not currently running any special sort of intake with the Full Race kit.
Old 11-30-2016, 02:33 PM   #250
olsonpg
olsonpg's Avatar
On one of your pics page 16 you have a stubby cone filter right up against your turbo.
Ahh.. I'd love to see that dyno sheet but don't dig too hard. Is it similar to the 7163's people are running above?
Do you remember what numbers your hitting? Im wondering if the 67-58 can hit 300+ wtq and not fall off too hard by 7000 rpm.
I'm thinking of built 12.5-1 e85 and 67-58 hitting 400w-300+tq and hopefully not seeing a waterslide torque drop off.
Old 11-30-2016, 02:48 PM   #251
gabeg86
gabeg86's Avatar
I'm sure those numbers are easily doable with the 6758. Pushing 500 whp I could see a drop off, but I'm confident you would run 400-450 whp, especially keeping the compression up like that without seeing a large drop-off in torque. I'll look around and see what I can find. Have yet to hit a dyno with the new motor setup. Custom tweaked e-tune from Bill @ Delicious following the build.
Old 12-01-2016, 01:43 AM   #252
VerusEric
VerusEric's Avatar
That is correct, that is our recommended kit for a few reasons and I didn't want to add each kit to our website. However, we can order any variant you want, not a problem.
Why we went with the 7163 over the 6758 for our specific build in no particular order:
-Latest EFR turbo sporting the only mixed flow turbine wheel
-Aluminum CHRA (lightweight, saves about 4-5 lbs)
-The same turbo is used in IndyCar
-The ability to push low-mid 500 hp which the 6758 seems to be limited to around 420-450 max.
To us, the difference in spool wasn't worth the above positives. The difference in spool is going to be around 300RPM. Transient response for both will still be awesome, you honestly can't go wrong with either unit! Ultimately, the decision rests on you and you can't go wrong with either, so don't spend TOO much time mulling it over, you'll be happy either way .
@gabeg86 - If you happen to stumble upon your dyno chart, please e-mail me or post it up in this thread: http://www.ft86club.com/forums/showt...55#post2767355 I'm attempting to keep all of Full-Race's turbo kit results in a single thread and managing it.
As for 6758, from the owner's thread, I'm posting a dyno chart below. It seems this dyno gives a bit inflated numbers IMO (stock-ish car hp was 173hp) but still gives a great representation of torque curve.
6758 Twin Scroll T4
Built Engine
E85, 27PSI by 3500RPM, 4-port solenoid with twin port IWG.
Thanks,
Eric
>>Circuit Motorsports - Full Performance Shop - Central FL / Orlando - 86 Specials << Circuit Motorsports Southeast 204 10-05-2016 01:27 PM
Full Blown Motorsports Base Turbo Kit with e85 Upgrade TyperRspec789 Engine, Exhaust, Bolt-Ons 24 07-12-2013 04:58 PM
Full Blown Motorsports Turbo Kit INSTALLATION at Real Auto Dynamics! Kevin@RAD Forced Induction 70 04-24-2013 08:47 PM
Indy Car and Grand Am Race at Barber Motorsports Park naikaidriver Southeast 5 04-07-2013 05:05 PM
Shannonville Motorsports Park Full Track August 11, 2012 funcheung CANADA 5 08-13-2012 11:54 AM
