#169 |
Drives: Stock
Oh and for some people who beleive its to high on pump numbers, remember dynos read diffent. I noticed in one pick the dynapack sign so seeing how that's there I assume it was on a dyna pack. Dyno pack it a higher reading dyno so if you do the math a good number woul be roughly 180hp sounds about right to me. The importance is how 12 volt added roughy 10 hp with the intake manifold.
#170 | |
Drives: Full race 4cyl boxer
Example: Dynapack setup requires Final Drive, Drivetrain loss, AND wheel diameter to be entered. If you were to enter those values wrong by just a little, you would get errors in the final value. Even running with low tire pressure in the rear would give inflated HP numbers because the effective wheel diameter would be less than the machine thinks.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
| The Following User Says Thank You to justatroll For This Useful Post: | Teseo (11-27-2016) |
#171 | |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | justatroll (11-27-2016) |
#172 | |
If they DO, why is there a wheel diameter setting in the setup menu?
#173 |
Maybe that part is just so the customer can get some sort of vehicle speed chart.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | justatroll (11-27-2016) |
#174 |
Drives: 13 frs red
In the middle of the summer, my car runs almost as strong as the one on the dyno.
#175 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
looking at getting an aluminum driveshaft, 6.67 final drive, and lightweight flywheel and hoping to hit mid 13s in the drag.
#176 |
Drives: 13 frs red
#177 |
#178 |
Off Topic
#179 |
Here
http://www.dynapackusa.com/vehicle.htm I should have read the description. Wheel Dia - for entering wheel diameter so equivalent ground speed can be calculated for display - not used or necessary for power and torque measurements
| The Following User Says Thank You to justatroll For This Useful Post: | CSG Mike (11-28-2016) |
#180 |
Drives: 2014 FR-S
![]() JDL UEL header OFT E85 Tune Top Speed axel back |
| The Following User Says Thank You to GenRuleAThumb For This Useful Post: | Teseo (11-28-2016) |
#181 |
Sorry but our cars have ~12-13% drivetrain loss (MT).
Your peak wheel HP shows up as 174.6 174.6 * 1.13 = 197.3 HP So your engine is outputting right about 200 hp What am I missing? (Hint: 'drag power' is way too high @ 41 hp). 41 hp of drivetrain loss on a engine hp of 216 is 19% loss See what I mean about "tweaking dyno settings" to show power where it isnt? And thats without being able to see any of the Rotating mass numbers.
#182 | |
Off Topic
Say your car makes 200 bhp, and for ease of math it loses 20 hp (10%) through drivetrain loss. You do some mods to it and now it's making 300 bhp. You're still spinning the same gears at the same speed in the same fluid, so it should still only lose 20 hp, not 30 hp (10%), right? If expressing it as a percentage is correct, why would drivetrain loss go up just because power went up, when the workload to spin all the gears and whatnot hasn't changed? |
| Recommended cheaper power gains mods | emishor86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 03-27-2016 08:49 PM |
| POWER Mods for NA setup | NYCsubaruBRZ | Engine, Exhaust, Transmission | 61 | 02-17-2016 09:19 AM |
| Mods to reduce drivetrain power loss? | FRSW12 | Engine, Exhaust, Transmission | 31 | 12-28-2015 05:10 PM |
| Easy mods for power and sound. | LWAA | BRZ First-Gen (2012+) — General Topics | 40 | 09-13-2015 09:20 PM |
| More Power VS. other Performance Mods | Darryljr11 | Mid-Atlantic | 38 | 08-11-2013 08:53 PM |
