Old 11-11-2016, 05:41 PM   #141
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
One of the missing pieces arrived, just thought I would share, how's this for fitment??
Pure Automotive is offline   Reply With Quote
Old 11-11-2016, 10:16 PM   #142
ft86xtc
Drives: 2013 FRS
Count me in for the group buy! How long did you have to extend it, i got a r154 off craigslist with an extended shifter im curious if mine is long enough.
ft86xtc is offline   Reply With Quote
Old 11-12-2016, 07:54 AM   #143
Pure Automotive
If not you can send us yours and we can modify it
Old 11-13-2016, 11:44 PM   #144
eyestein
Drives: FRS Series 1.0
Tightttt
eyestein is offline   Reply With Quote
Old 11-25-2016, 03:11 AM   #145
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Originally Posted by Pure Automotive View Post
If Haltech follows through, you can guarantee it will cost almost as much as Motec M1 series because they are very similar.
The Intake manifold is being designed as we speak, and will 100% be a group buy when it's confirmed and finished.
Most Exhaust manifolds will work as long as they don't put the turbo far away from the engine. I have a Powerhouse Racing on my car and this car has a knockoff.
+1 for that Intake Manifold, I am gonna do one of these swaps in my other FR-S chassis next year. Definitely waiting on that wiring solution if you guys can make it work, hopefully it will be VVTI compatible.
R2RO is offline   Reply With Quote
Old 11-28-2016, 11:39 AM   #146
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by Norville Rogers View Post
So three parts have been bolted on, intake and exhaust manifolds and a shifter housing.
Has anything else happened?
sure. the intake manifold is now in cad and the model is being cleaned up and tweaked for production. the wiring harness is built. the custom ecu firmware is being written. the ac line modifications are 3/4 done to retain ac. a drive by wire throttle body is tested and working with the oem gas pedal. this isn't a get it done in a month swap, we actually work on a ton of cars so this isn't a guy in a garage working on one car non stop.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-29-2016, 04:03 AM   #147
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
You obviously have NO idea how much it takes to get this swap into the car. Let alone with standard functioning accessories (hydraulic PS, cable throttle, no A/C, etc) - they're trying to market something with OEM-esque functions.
If they get it wrong, people like you will bitch at them for not doing enough.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 11-29-2016, 08:47 AM   #148
krimsonmedic
Drives: 2013 Scion Frs.
With a functioning 2jz, in good shape but maybe not "Built", are we atleast looking at sub 20k? Is it still too early to even guess?
krimsonmedic is offline   Reply With Quote
Old 11-29-2016, 03:32 PM   #149
slicktop
If this is offered with everything you need for the swap, I'd expect it to be around the $20k mark.
-slicktop
2013 Scion FRS
Old 12-12-2016, 09:49 PM   #150
Pure Automotive
Hardly likely at the moment...
I don't know what will feel better, finishing the swap or making you look like the troll you are when it is finished.
For all those following the thread, thank you so much for appreciating how much we are putting into the swap. As @spitfire481 said, we have A LOT of things nearing completion, I am very excited about so many things that will all happen in the next month or so. We are working at the pace of others, not our own, if I were funding and building every piece it would have been done already, but in this industry you have to rely on other people and their timelines to make things happen.
Side note for all my 2J guys who are already piecing things together, check these out! IGN1A Coil Kits
Old 12-13-2016, 08:46 PM   #151
BlackBRZKnight
Drives: 2014 Crystal Black Silica
I'd rather be chomping at the bit and wait a little longer, ensuring that this swap "kit" is exactly what you envisioned. I would advise others that have problems with their production timeline to either a)do it themselves and wish them well or b)move on to another swap that is arguably less complicated. You can't please everyone guys, but I get more and more excited about the prospects of this swap "kit" with every update. Thanks in advance for your time and attention to detail guys!!
BlackBRZKnight is offline   Reply With Quote
Old 12-14-2016, 06:46 PM   #152
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
They look excellent in their boxes. But has there been any progress before you call anyone a troll. I'm glad I'm not a paying customer. Any news on the swap????
Scrappydoo is offline   Reply With Quote
Old 12-15-2016, 07:33 AM   #153
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm not sure if it's been mentioned or not, but does anyone know the weight difference this swap makes? I'm assuming that the iron block is much heavier than the FA20, despite the FA20 being relatively heavy for a 4 cylinder.
Old 12-21-2016, 07:50 PM   #154
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I guess we are into the holiday break now.
Will there be any news next year?
Or the year after?
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 08:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
