Old 10-24-2016, 08:21 PM   #127
empower-auto
Kouki-Monster
empower-auto's Avatar
Super subscribed
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-24-2016, 09:20 PM   #128
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Quick update for the thirsty ones lol ..
We are in the process of having a shifter adapter made, getting the manifold mocked up,
Oh and working out a drive by wire solution....
Side note to answer a few questions: Sorry no 1jz stuff yet, vvti will be possible, but we have a finite amount of inputs and outputs and vvti will eat up 2 more of them.
Pure Automotive is offline   Reply With Quote
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
CxG (01-14-2017), Draco_PR23 (10-24-2016), gatorbushmen (10-25-2016), Godzilla35 (10-26-2016)
Old 10-25-2016, 12:47 AM   #129
nickg
Drives: 2014 Whiteout FR-S Manual
You have to redo the fuel system into a return type correct? How difficult is this on our cars?
nickg is offline   Reply With Quote
Old 10-25-2016, 01:51 AM   #130
cello002
Drives: GT86
Cool
Do you guys have dry sump oil pan for 2JZ in FRS? What brand and model is it?I s it directly fit?
cello002 is offline   Reply With Quote
Old 10-25-2016, 01:38 PM   #131
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
depends on how much power you want to make. you do not need to if you keep it relatively stock. the return system would consist of an in tank regulator delete, a 1:1 regulator in the engine bay, then a return line back to the tank with a bulkhead fitting into the canister
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
bakerr6 (10-25-2016), fguadamuz (10-26-2016)
Old 10-25-2016, 11:35 PM   #132
Pure Automotive
Yes we do, it is a billet pan, can sell you an entire kit that fits the car with a 2jz
Old 10-25-2016, 11:36 PM   #133
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
What are you guy going to do about the drive shaft?
Votlon is offline   Reply With Quote
Old 10-26-2016, 08:07 AM   #134
Fred1
Fred1's Avatar
Drives: Scion Frs 2014
Looking forward this swap kit! Thanks for keeping us to date.
Fred1 is offline   Reply With Quote
Old 10-26-2016, 09:59 AM   #135
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Curious about the cost of this swap so far, is it still within expectations? i.e. is the final product to come of this still considered a "budget swap"?
Old 10-26-2016, 10:45 AM   #136
nickg
Im sure the cost can differ wildly depending on what you do with the engine. If you keep the stock turbos and sell your fa20, it would probably be pretty reasonable. But a lot of people wouldn't go through the work of an engine swap without also getting crazy power with a built motor and single turbo setup, which would add several thousands to the cost.
Sent from my XT1575 using Tapatalk
Old 10-26-2016, 12:01 PM   #137
PandaSPUR
PandaSPUR's Avatar
Yea obviously, but I assumed as this thread is titled "Budget 2JZ Swap" that the customer had some rough figure in mind and Pure had some sort of plan or hopeful estimate.
Basically wondering if there have been unforeseen challenges that kinda kills the "Budget" part of this specific swap.
Old 10-26-2016, 11:17 PM   #138
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
I'll tell you one thing for sure, the wiring thing is the most expensive and cumbersome.
mulekr1 is offline   Reply With Quote
Old 11-06-2016, 10:06 PM   #139
briantran123
Drives: fire storm frs 6mt
so for the stand alone, what system are you guys running with? I've heard haltech is coming out with something that'll be able to run all sorts of canbus with the new box. Motec is another system that works but the price isn't that obtainable to most customers. really interested in the intake manifold/ fuel rail and harness, are you guys doing a group buy and such when it'll be released? another question, for the exhaust manifold, will you guys be designing one to market? if so, any interests for a divided setup? have a borgwarner s472 laying around for the project
briantran123 is offline   Reply With Quote
Old 11-11-2016, 06:39 PM   #140
Pure Automotive
If Haltech follows through, you can guarantee it will cost almost as much as Motec M1 series because they are very similar.
The Intake manifold is being designed as we speak, and will 100% be a group buy when it's confirmed and finished.
Most Exhaust manifolds will work as long as they don't put the turbo far away from the engine. I have a Powerhouse Racing on my car and this car has a knockoff.
The Following User Says Thank You to Pure Automotive For This Useful Post:
R2RO (11-25-2016)
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 09:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-21-2015 12:50 AM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 12:23 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 09:14 AM
