#29 | |
![]() humfrz |
#30 |
"DGM BRZ"
Drives: 2016 BRZ Limited
It's cool guys I thought you were being serious about how I drive the car
![]() I guess I'll try to pick up some lubricant this weekend and fix it myself spraying under the boot. In other news I noticed the little rubber stop that the clutch pedal arm hits against in the footwell is chopped in half from wear lol, I guess I should replace that with something. |
#31 | |
#32 |
"DGM BRZ"
#33 |
It's the rare "actual" upgrade. That rubber thing is a POS.
#34 |
"DGM BRZ"
Ended up using some rubber drawer liner and 3M tape until I finally find those chair leg pads somewhere. Seems to work great so far but probably won't last as long as a chair pad.
Still gotta figure out what spray lube to pick up today too. |
#35 | |
![]() @Ultramaroon ....what should he try to get onto that "socket" and how best to do it .... ?? humfrz |
#36 | |
"DGM BRZ"
#37 | |
#38 |
Haha.. NICE! I'm working on that now. gimme a few more mins.
#39 | |
There should be grease around the end of the pin and grease in the divot on the end of the fork. If it's good, I collect it together and mash it back into the divot. Using a 14 mm socket and a long extension remove the 2 mounting bolts. They will be super fucking tight and they will let go with a snap. The outer heater hose will be a bit of a pain. Just fold it up and back a little. When the cylinder comes loose the piston will extend the pin. There's a little spring on the wet side that pushes against the piston but the boot will keep everything together. Move the cylinder aside and pop the dust cover off of the fork. Rock the top of the fork forward and reach down the back of the fork carefully with your finger. You will feel the pivot pin in the socket. Mash a good ball of grease in there with your finger. Then jiggle the fork back and forth a bunch of times. Notice at first how the TOB binds a little over the guide. That's what gets bad enough to break the fork. It will clear up a little when you work it back and forth but it really needs to be cleaned. The clutch material sticks in there and acts like sandpaper. Reinstall in reverse order. Enjoy.
#40 |
^Pics?
#41 |
http://www.ft86club.com/forums/showthread.php?t=77390
minus the hydraulic stuff. ![]() Here's under the bell housing.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | PWBRZ (12-03-2016) |
#42 | |
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 01:22 PM |
| Clutch squeaks | bhbnuckle | CANADA | 8 | 08-19-2016 10:56 PM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 05:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 01:49 PM |
| HELP! Clutch fork retainer clips | teamKS | Engine, Exhaust, Transmission | 3 | 08-13-2015 12:46 AM |
