Old 11-24-2016, 09:57 PM   #29
Originally Posted by treminaor View Post
That's how I drive my cars, never had a problem with grease turning to sludge before this. If I was going drive it like a grandma it the whole time I would have bought a manual Corolla and called it a day.
I's jest ah messen wich ya there, @treminaor ...... sorry if I upset you .....
Old 11-25-2016, 12:10 AM   #30
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
It's cool guys I thought you were being serious about how I drive the car
I guess I'll try to pick up some lubricant this weekend and fix it myself spraying under the boot.
In other news I noticed the little rubber stop that the clutch pedal arm hits against in the footwell is chopped in half from wear lol, I guess I should replace that with something.
treminaor is offline   Reply With Quote
Old 11-25-2016, 12:20 AM   #31
You know those adhesive backed felt pads? Perfect. I'm still on my first one after 2 years.
Old 11-25-2016, 12:39 AM   #32
treminaor
"DGM BRZ"
treminaor's Avatar
Exactly what I had in mind, could have sworn I had some laying in a drawer but I'm still searching
Old 11-25-2016, 12:53 AM   #33
It's the rare "actual" upgrade. That rubber thing is a POS.
Old 11-26-2016, 03:51 PM   #34
treminaor
"DGM BRZ"
treminaor's Avatar
Ended up using some rubber drawer liner and 3M tape until I finally find those chair leg pads somewhere. Seems to work great so far but probably won't last as long as a chair pad.
Still gotta figure out what spray lube to pick up today too.
Old 11-26-2016, 04:25 PM   #35
Be careful about spraying anything in there because you don't want to get anything on the clutch disk, pressure plate or flywheel. Most of the time "Bubba" just screws things up.......
@Ultramaroon ....what should he try to get onto that "socket" and how best to do it .... ??
Old 11-26-2016, 05:03 PM   #36
treminaor
"DGM BRZ"
treminaor's Avatar
I picked up the Lucas Red #2 tube and a grease gun. Waiting to get info about where to point it in there lol.
Old 11-26-2016, 06:29 PM   #37
Oh, the pivot? I've come full circle on the lithium spray. I don't think it hurts anything to stick a little spurt in there but it won't last as long as the lithium complex stuff.
Old 11-26-2016, 06:39 PM   #38
Haha.. NICE! I'm working on that now. gimme a few more mins.
Old 11-26-2016, 07:02 PM   #39
We will remove the dust boot over the fork. You will have to unbolt the slave cylinder and slide it out of the way. We won't touch the hydraulics.
There should be grease around the end of the pin and grease in the divot on the end of the fork. If it's good, I collect it together and mash it back into the divot.
Using a 14 mm socket and a long extension remove the 2 mounting bolts. They will be super fucking tight and they will let go with a snap.
The outer heater hose will be a bit of a pain. Just fold it up and back a little.
When the cylinder comes loose the piston will extend the pin. There's a little spring on the wet side that pushes against the piston but the boot will keep everything together.
Move the cylinder aside and pop the dust cover off of the fork.
Rock the top of the fork forward and reach down the back of the fork carefully with your finger. You will feel the pivot pin in the socket.
Mash a good ball of grease in there with your finger. Then jiggle the fork back and forth a bunch of times.
Notice at first how the TOB binds a little over the guide. That's what gets bad enough to break the fork. It will clear up a little when you work it back and forth but it really needs to be cleaned. The clutch material sticks in there and acts like sandpaper.
Reinstall in reverse order.
Enjoy.
humfrz (11-26-2016), treminaor (11-26-2016)
Old 11-26-2016, 07:05 PM   #40
gravitylover
^Pics?
Old 11-26-2016, 07:31 PM   #41
Originally Posted by gravitylover View Post
^Pics?
http://www.ft86club.com/forums/showthread.php?t=77390
minus the hydraulic stuff.
Here's under the bell housing.
PWBRZ (12-03-2016)
Old 11-26-2016, 09:32 PM   #42
Enjoy.
Are you fixing the fork, performing a prostrate exam or describing your prom date?
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 01:22 PM
Clutch squeaks bhbnuckle CANADA 8 08-19-2016 10:56 PM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Clutch Fork Broken rick s Issues | Warranty | Recalls / TSB 8 08-27-2015 01:49 PM
HELP! Clutch fork retainer clips teamKS Engine, Exhaust, Transmission 3 08-13-2015 12:46 AM
