Old 11-26-2016, 04:44 AM   #1
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Moto-East Flex Fuel Kit Troubleshooting
Hey guys,
Any of you who is running flex fuel had this problem? I've been running moto-east's FF kit for 2 years now and suddenly today, I tried starting my car, I noticed my Flex Fuel gauge not working. No display or readout. My car would turn over to start, but would die. I know this has something to do with the kit, but what component could it be? I checked all the wiring and it checks out fine. It all boils down to the gauge, analyser, or the sensor. Any ideas? TIA!
Tye300 is offline   Reply With Quote
Old 11-26-2016, 07:35 AM   #2
steve99
Drives: FT86
Originally Posted by Tye300 View Post
Hey guys,
id check the fuse if the display is blank
if the fuse is blown then check wiring for damage or shorts the fuse blew for a reason
check their is 12v and earth to sensor\eca analyser module
Measure the voltage on the signal wire to ecu it will either go to rear o2 or cpc volts shouls be between 0.5 and 4.5 depending on ethanol content if its 0v or 5v likely someyhing is wrong especially 0v
Wayno (11-27-2016)
Old 11-26-2016, 11:17 AM   #3
Tye300
Tye300's Avatar
Thanks Steve,
Checked the fuses and they are intact. Really stumped here. I will double check the earth/ground wire.
Old 11-27-2016, 05:33 PM   #4
Hawk77FT
Drives: GTS 86
If you got yourself the ECU harness i would take it out and put it back in. I had some issues when I first did mine but no issues ever since. Also track the wires and check their state.
Hawk77FT is offline   Reply With Quote
Old 11-28-2016, 08:31 AM   #5
Tye300
Tye300's Avatar
Okay thanks bro. Will check it out. Still waiting for moto-east's response to my email.
Old 11-29-2016, 09:55 PM   #6
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
If you have the harness, I'd likely say the issue is the connection in it or to your Zeitronics unit. Check all of the connections and drive around then report back to us with pictures. Mine went in flawlessly and I haven't had any issues since the install, though I left a lot of slack in the wiring to the Zeitronics unit and the gauge display.
Trefoil is offline   Reply With Quote
FS: Moto-East Flex Fuel Kit mitim3 Audio/Visual, Electronics, Infotainment, NAV 1 10-23-2016 12:04 PM
sold: Moto-East Flex Fuel Kit industrial Engine, Exhaust, Bolt-Ons 5 05-19-2016 04:41 PM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Moto East Flex Fuel Kit Synack Engine, Exhaust, Bolt-Ons 1 11-30-2015 06:59 PM
Moto-East Flex Fuel Kit GB! Xero-Limit Groupbuys 32 09-14-2014 08:20 AM
