Old 11-25-2016, 05:46 PM   #127
Reamer
Drives: 2015 FRS
The @Jackson Racing T4 car uses this setup, and won it's class nationally.
Nice. Granted, this was just cruising on the freeway and I don't recall what my temps were before hand (I'm bad about getting baselines) but the claim that coolant temps keep the oil temps constant seems to be true.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
CSG Mike (11-25-2016), mrg666 (11-27-2016)
Old 11-25-2016, 05:57 PM   #128
CSG Mike
CSG Mike's Avatar
Generally speaking, as the entire engine heat soaks from long sustained driving (20+ minutes on the highway), the oil temp will be *slightly* (talking maybe 10F, depending on conditions) higher than the coolant, and this is totally normal.
This is opposed to a stock car, which will usually hit equilibrium of 190F coolant and 225F oil, while cruising on the highway.
mrg666 (11-27-2016), Reamer (11-25-2016)
Old 11-25-2016, 06:25 PM   #129
Reamer
Drives: 2015 FRS
This was just under an hour on the freeway. I'm also around e65 mix so I'm not sure how much that actually effects engine temps either.
Sent from my Pixel using Tapatalk
The Following User Says Thank You to Reamer For This Useful Post:
Old 11-25-2016, 06:29 PM   #130
CSG Mike
CSG Mike's Avatar
Best case, the oil and coolant temps are identical
Reamer (11-25-2016)
Old 11-25-2016, 10:26 PM   #131
choi0706
Drives: t
fitment with front mount turbos?
choi0706 is offline   Reply With Quote
Old 11-27-2016, 07:55 AM   #132
CygnusX1
CygnusX1's Avatar
Drives: subaru BRZ Sport premium
I can confirm that while it is a semi-tight fit, the Grimmspeed intake will also fit.
I am also interested in seeing what threshold this has in a NA track setup, preferably in a climate similar to humid Texas summers. I suppose if nothing is posted for this in 6-7 months when temps are getting stupid again, I'll post them up but I can also guarantee my skills will most likely not be pushing it either. Maybe I'll just drive on the street in 2nd gear between 5-7k to simulate a faster person :laughing:
You are pretty sure about the fittment of a Grimmspeed intake?
@CSG What do you think?
CygnusX1 is offline   Reply With Quote
Old 11-27-2016, 11:46 AM   #133
Reamer
Drives: 2015 FRS
I have both installed on the car right now.
CSG Mike (11-28-2016), CygnusX1 (11-27-2016)
Old 11-28-2016, 06:54 PM   #134
7 skulls
Drives: 2014 scion frs
Great looking product. Any one have track / hard driving oil temp logs with this set-up yet? Curious how it compares to an OEM style oil cooler and/or an air/oil cooling system.
7 skulls is offline   Reply With Quote
Old 11-28-2016, 06:56 PM   #135
Reamer
Drives: 2015 FRS
Granted, this isn't logs but I'm gonna point to Mike's previous post:
Old 12-08-2016, 09:55 PM   #136
choi0706
Drives: t
anyone? how much larger is it from OEM? or other aftermarket radiators? I'm wondering if this will fit with a fullrace turbo kit.
Old 03-02-2017, 04:54 PM   #137
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
If you could post pictures of how close the fittings are to the intake box I'd be eternally grateful. I just installed the JR rad and the fittings rub the stock air box a bit.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 03-02-2017, 04:57 PM   #138
Reamer
Drives: 2015 FRS
I'll try to remember to get some tonight. Cannot guarantee quality pics. Lol.
Kestrel (03-02-2017)
Old 03-03-2017, 02:50 PM   #139
Kestrel
Kestrel's Avatar
Old 03-03-2017, 02:52 PM   #140
Reamer
Drives: 2015 FRS
I lied. Lol. Maybe I'll remember today.
Kestrel (03-03-2017), Ultramaroon (03-08-2017)
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 05:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 11:26 AM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 02:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
