Old 08-20-2016, 08:28 PM   #99
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Spartarus View Post
blah blah blah
Oh - you still here?
The real reality is that the J swap has already been proven effective in S2000s and Miatas, but somehow it's folly in your precious twin, because it hasn't been done yet. That's fine if you can't get your head around it. Like I said before, engine swaps aren't for everyone, especially if you have to do everything with your wallet instead of your brain, and they quite clearly aren't for you unless someone else has already proven they can work. Much like forced induction on the FA20 because the CR is too high, or the LS is a big nasty American boat anchor, or the 1UZ will never fit or work properly, etc. Oops - I guess all that stuff DOES work...hmmm. Good thing the people who got those to work didn't listen to people like you, or else the aftermarket for this platform would be like Mercedes.
BTW, I'm replying to your trolling not because your comments have any value whatsoever, but because you, yourself, are the very thing that stifles creativity and sharing knowledge on forums. Congratulations on making this place just a tiny bit worse.
venturaII is offline
Old 08-20-2016, 08:38 PM   #100
Dempz
Dempz's Avatar
Drives: 97' Z3, 13' FR-S
So, I logged on today, and this is what I saw.
Oh, hey look, that Honda V6 thread came up again, and the last post was by OP!
Wow, I hope he made some progress, or has some sort of announcement!
Maybe he took some measurements, or started the swap?!
I'm going to go have a look!
Nope, just more schoolboy bullsh*tting.
Disappointing.
The question mark was enough for me to know it wasn't going to be a build thread. Maybe you could contribute to the thread as opposed to complaining? Just a thought lmao.
Dempz is offline
The Following User Says Thank You to Dempz For This Useful Post:
venturaII (08-20-2016)
Old 08-20-2016, 09:21 PM   #101
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
I contributed early on, before OP decided to declare war on reality.
Turns out, he didn't want any information in the first place, as he ignored all the information that was presented, and continues to ignore any valid point that he can't argue with.
For example, when told that no other 60 degree v6 has fit without major modification due to height, the response wasn't "oh, I suppose I should measure it, and then figure out if / what I need to change to make it fit," no. The response was a mix of denial, ignorance, and sociopathic rage.
This means the coversation can't move on to any of the other specific information he needs, because he has no specific information, refuses to collect it. When somebody offers it, he considers it a personal attack.
The thread is 8 pages long. We could have done a real feasibility check and have an A - Z list of exactly how to do the swap by this point, but that's not what OP was interested in doing. It seems he was just seeking approbation, and he didn't find it.
There are many ways to displace.
-Spartarus
Spartarus is offline
Old 08-20-2016, 09:34 PM   #102
venturaII
venturaII's Avatar
And yet here you are, still adding nothing of value..
Old 08-21-2016, 11:24 PM   #103
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by venturaII View Post
If 300 NA bhp is your goal, and entirely achievable with a J series, then explain how that's 'down on power'?
NA headroom. 300hp NA is entirely possible. I had a bored and stroked 3.6l J and made 296/275 at the wheels without a tune. But, it costs a good amount of money to make more than ~340whp, which is the reason I got away from that platform (that and it was in a FWD boat...).
And yes, I am aware that 340hp is more than 300hp, but my point is that there are other swaps that provide better bang for your buck, and a better base to start your build on. Nearly everyone says their initial goal is 300hp; then they live with it for a while and want more. If you're staying NA, you reach a point of diminishing returns around 340whp with the J. It's good power - don't get me wrong - but it's pricey to get there. Most that say they are there don't have dyno graphs to back it up, and those that do spent A LOT of money doing so.
Originally Posted by ort895 View Post
Shhhh, there is no reasoning with a "put an LS in it" guy.
I'm confused...are you referring to me? If you look through the thread, I was the one that took an old J block and lined it up with the FR-S transmission while I was replacing my clutch. I wanted and planned this swap out, but when I ran the numbers, it just didn't make sense.
This swap is entirely possible. A transmission adapter and a new clutch can certainly be made to mate the J to the FR-S tranny. But I really don't think it's worth it, which is why I scrapped the idea. I also had my doubts that the transmission would be up to the task.
It's no secret that I do like the LS, however I think it's a bit "lazy" for this chassis. I also like the 2J, but the iron block is a turnoff. Truthfully, the 1UZ appeals to me more than both, however you're still kinda tapped out for NA power.
Not to mention that an LS or 2J will require a different transmission, better cooling, and likely axles and such. A V6 needs none of that.
As I mentioned above, I'm not sure the stock transmission would last long. I don't know why you think the stock axles can handle a 300whp/260-280wtq engine - Sprintex powered cars are breaking stock axles, and they're making less. Also, from my measurements, I'd want to shift the engine back a bit, otherwise it's hanging over the front axle pretty far and would foul on the hood (it's a 60* block, the engine with heads and intake is tall). So thats money into a new oil pan, oil pickup, and intake manifold. While those are still requirements for other swaps, parts are plentiful, and in most cases, cheap. For cooling - quite frankly, you should upgrade cooling on a stock FR-S/BRZ, so this would already be done for someone that is starting a swap.
I'm not looking for a fight, I'm just speaking my mind. I love the J, even for all it's quirks. It sounds good, it's reliable when built properly, and surprises a lot of people with what it's capable of. But I don't think it's a great use of money for a motor swap into this chassis.
With that said, I'd still love to see it happen, but with someone else's wallet lol
Parting out HERE
civicdrivr is offline
Old 08-22-2016, 12:18 AM   #104
venturaII
venturaII's Avatar
So, my 300 bhp ceiling is there for several reasons, one of which being it opens up a lot more interesting options than the standard LS swap recipe. J motors are cheaper and more plentiful than any LS motor you'd actually want (at least, where I am..), to boot.
I doubt the transmission will grenade with the J in front of it, assuming you don't drive like a 17 year old. Same goes with the axles. There are people who've broken them with relatively stock FAs, and there are people (likely FAR more than those who've had problems) who've racked up tons of miles with much more boosted power and torque and have had no issues. I tend to think it's more an issue of how you drive. I'm looking to the Miata/S2000 community for input in this area (Miata especially) to gauge the need for these upgrades, and there doesn't seem to be a pressing need for it. Same goes for cooling. Sure, upgrading is additional insurance (especially if you're going to be tracking it regularly), but how much it's needed on the street seems to be a bigger question. Certainly the stock units will last for a reasonable amount of time and allow upgrading at your leisure, rather than it being a necessity. All this is why my 300 bhp cap and this motor has been chosen.
Oil pan/pickup and headers (and motor mounts...lol).. are not terribly concerning for me. I've fab'd plenty in the past and I don't expect this to be much different. Intake is a bigger question, as I haven't done one yet, but the extent of modifications is unknown yet. Another issue you brought up is engine setback...as you mention, it'd be nice to get the engine a few inches further back, but if using the stock 86 transmission, then you'd need to come up with something clever in the shifter department. Not that it can't be done, but it's more fab work. Plus then, that'd require a shorter driveshaft, etc. So for the sake of economy and simplicity (which is kind of the whole point of this particular swap), leaving as much as possible in their original location is preferable.
As you say you love the J motors, I too think the LS is a great motor. It's just overkill for this application, given the criteria above. Maybe as they become a more popular swap and there are more refined and comprehensive solutions available, the cost will come down enough to offset the additional upgrades required, but then again, that'll also just drive up prices of LS motor/transmissions, since there will be ANOTHER platform and community trying to scavenge them.
Old 08-22-2016, 02:03 AM   #105
varora
Drives: 968
I had an acura TL with the J32A2 motor with headers, intake, pulley; that motor would pull crazy hard, it would walk Audis and Mustangs with ease on the highway. I drove it like I stole it and after 150k modded miles it still idled smooth as when it was new, the car understreered like mad though and needed a better tranny, i went through 3, i felt like i could have beat on that motor for at another 100k and it would just beginning to need any major maintainance
A well done fa20 sc or tubro setup with catch cans, oil cooler will easily hit 5k for parts. I think it would be a cool option to have if swap could be achievable in that range, also the j32a2 sounded delicious, the engine bay was full of angry tigers
varora is offline
The Following User Says Thank You to varora For This Useful Post:
ort895 (08-22-2016)
Old 10-22-2016, 08:56 PM   #106
SKELLINGTON
Drives: 2013 CBS BRZ LIMITED
In case anyone is still interested in more information about a J swap I'm in the middle of one for my Miata. I actually got rid of my BRZ a couple years ago to build this project. So if any inquiring minds have questions I'll try to keep up on answering them to the best of my ability.
SKELLINGTON is offline
The Following User Says Thank You to SKELLINGTON For This Useful Post:
venturaII (10-24-2016)
Old 11-02-2016, 01:32 PM   #107
Jmk91
Drives: 2017 Brz Performance Package
Should've done the k series. The k miatas look sick! I know it's less power than the j but the k series swap seems rather simple on the miata.
Jmk91 is offline
Old 11-21-2016, 09:21 AM   #108
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
I know the honda v6s prettty good and it is a $ per $ common sense. The blocks you want would go for around $1500-2500 used. You still have to build them to hold more than 400hp. Have to find the right block to fit starter etc etc.
Plus until recently and maybe still they were a pos to tune unless spending on a full standalone.
So if you are going to do ALL that...why not make life easier for the money and just throw an LS in and call it a day. This is coming from a guy that is a purist and like stay with the brand of engine in a brand of car.
Now if someone is serious I can get you some measurements.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline
Old 11-21-2016, 10:33 AM   #109
venturaII
venturaII's Avatar
Why does everyone assume a swapped motor needs to be 'built'? A 3.2 J motor right out of the boneyard with a quick reflash and headers would be close to 300 bhp. That's all I want. The tuning and integration with the 86 system is another story, but I'm assuming there would be similar solutions available as what are developing within the LS swap community. Dunno yet. And if you feel like sharing dimensions of whatever parts you happen to have, I'll never say no to that. lol
Old 11-21-2016, 11:53 AM   #110
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
[ame="https://www.youtube.com/watch?v=iduRc9MvRdA"]Project Toyonda K86 - Supercharged K24 FRS Build Series - Intro And The Plan - YouTube[/ame]
Follow this channel if you guys want updates. The owner of the car is a friend of mine and i will be helping him much of the progress. I'ts not my youtube channel so this is not a plug.
He's working on a K-Series swap to his FRS. Thats all I can say for now. Don't want to spoil it.
As far as progress. Idk how detailed the youtuber will cover the swap but right now the car is completely stripped of everything down to its shell.
EDIT: This project is estimated to be a year. It really depends how much work needs to be put in or how much we actually want to work on it. lol.
Kayysonie is offline
Old 11-21-2016, 12:18 PM   #111
venturaII
venturaII's Avatar
You should start a separate thread. This is a discussion regarding the J series V6.
Old 11-21-2016, 01:01 PM   #112
Kayysonie
Badass Member
Meh.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 07:32 PM
FRS 10 SERIES GLOWING BADGE SWAP? IgnitionGundam Cosmetic Modification (Interior/Exterior/Lighting) 10 11-29-2013 12:00 AM
3 upcoming Honda VTEC motors from Honda!! RRnold Other Vehicles & General Automotive Discussions 10 11-19-2013 09:27 PM
