Old 11-21-2016, 05:27 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Classy86 View Post
along the lines of HP........
You are replying to a thread that is 2 years old plus the OP hasn't posted since 03-14-2016.
go_a_way1 (11-21-2016)
Old 11-21-2016, 06:29 AM   #16
Classy86
Not So Junior Member
Drives: White Subaru BRZ limited
i dont pay attention to these things but thankyou
Classy86 is offline   Reply With Quote
Old 11-21-2016, 08:20 AM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Actually, this is a great time to resurrect this thread and ask the guys who have been pushing it for several years how they are doing and any probs they have had.
300+ HP for 3+ years guys- well?
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Old 11-21-2016, 10:35 AM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Hey a quick FYI: PSI on 1 turbo will not make the same power at the same PSI level of another turbo. I am currently running 10 PSI and I would guess I am 280-300whp. I have had it up to 13psi for a day and it lived. Tuned on 94 pump
Old 11-21-2016, 10:36 AM   #19
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I thanked some old posts so they will check
Old 11-21-2016, 10:54 AM   #20
celek
Resident Gear Head
celek's Avatar
I think the current record is 693 HP
celek is offline   Reply With Quote
Old 11-21-2016, 12:43 PM   #21
wbradley
Sarcastic SOB
wbradley's Avatar
https://www.google.ca/webhp?sourceid...0fa20%20engine
Old 11-21-2016, 01:20 PM   #22
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I wouldn't put anymore than 300 on the motor. And thats only getting into your turbo every once in a while. . I think I'd feel pretty safe at 275 which is what I'd like to have
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 11-22-2016, 05:06 AM   #23
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I'm running near 300kW on stock motor (2015) and stock transmission. Still using the stock 215/45/17 tyres so they are the first thing to give out. And run varied boost from 14.5 to 18 PSI.
All depends on driving habbits etc etc. I don't boost past 4th gear. Mayyyybe 5th if high RPM and speed. Turbo comes in nice and slow to maintain rods etc.
COO86L is offline   Reply With Quote
Old 11-10-2017, 12:35 PM   #24
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Turbo/boost/torque coming in slower I get.
Not using power in 4th or higher makes no sense to me at all...
You rev the engine to say 6k with 14psi in 3rd, but won’t do that in 4th... why?
I like driving!
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
Tcoat (11-10-2017)
Old 11-10-2017, 12:50 PM   #25
86 South Africa
This is a really fun read...
http://mywikimotors.com/subaru-fa20/
Skip to the bottom
I like driving!
Old 11-10-2017, 01:42 PM   #26
StraightOuttaCanadaEh
Wes
Skip to the bottom
"To receive 350+ horsepower, you need the new fuel pump, fuel injectors, pulley and water/methanol injection. Don’t forget about transmission cooler and aftermarket radiator.
Instead of supercharger kit, you can install turbo kit on the basis of Garrett GTX3076R. Such kit is possible to install on stock internals and to receive 400 ++ WHP, and even up to 500 WHP (sport fuel).
FA20 stock internals keep more than 500 WHP, and if you use sports fuel and adjust ECU correctly, than over 600 horsepower."
What!
Old 11-10-2017, 03:26 PM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Do they mention expected life of 400-500-600hp FA20 with stock internals?
whataboutbob (11-16-2017)
Old 11-10-2017, 04:21 PM   #28
It said you can keep them not that they would last.
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
How much can stock drive shaft handle?? Argento_FR-S Forced Induction 24 06-01-2013 08:54 PM
Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 11 03-24-2013 03:49 AM
scratches - best way to handle them Vladror AFRICA 6 02-03-2013 05:05 PM
