Old 11-18-2016, 04:51 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by turtlefeeder View Post
Hey mike lol I was actually looking to drop by and pick up the SB7 since it seem favorable. you guys do you have them in stock?
Great question. Call CSG and ask! I know they were backordered a few weeks ago, but they may have stock now.
Old 11-18-2016, 05:20 PM   #16
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Just called a couple of time no one answering. Mike, are yo not working with or not CSG?
turtlefeeder is offline   Reply With Quote
Old 11-18-2016, 05:44 PM   #17
CSG Mike
CSG Mike's Avatar
I'm the test driver.... I'm at the track right now
Old 11-18-2016, 08:52 PM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I picked my clutch based on what the guys at ft86speedfactory run on their turbo shop car
malubawla is offline   Reply With Quote
Old 11-18-2016, 11:07 PM   #19
twag4
Drives: frs
Originally Posted by Dr. BRZ View Post
it says normal weight for the flywheel on sb7
http://www.advancedclutch.com/600705
The streetlite weighs 11.8 pounds. The whole clutch switch shaves around 10lbs. It is a lighter flywheel. I have this clutch, have held both flywheels together, and it is significantly lighter.
twag4 is offline   Reply With Quote
Old 11-18-2016, 11:11 PM   #20
twag4
Drives: frs
By the way, Fidanza says stock flywheel is 20lbs 7 oz.
Old 11-19-2016, 01:47 AM   #21
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
someone's website is wrong then, check out @ft86speedfactory website. it says normal weight.
Dr. BRZ is offline   Reply With Quote
Old 11-19-2016, 01:58 AM   #22
twag4
Drives: frs
http://www.ft86speedfactory.com/act-...l#.WC_pSbROKhA
Sb7hdss says lightweight flywheel. Not sure where your info comes from, but the sb7 kits come with the streetlite light weight flywheel. I have that very one. Sb8 is the prolite light weight flywheel. Even lighter still...
Read down in the description. It says it is sb7hdss. There is a typo up in the header.
Old 11-19-2016, 01:59 AM   #23
turtlefeeder
Drives: UltraMFrS
Damn this is tough trying to find the SB7 instock around socal ORNAGE COUNTY
Old 11-19-2016, 02:02 AM   #24
twag4
Drives: frs
They have all kinds of typos on both those kits at ft86speedfactory. Goto the ACT website, or counterspace garage for better information.
Old 11-19-2016, 02:06 AM   #25
turtlefeeder
Drives: UltraMFrS
CSG is 25min from me but I've tried calling them many times they won't answer I would go down there this Monday on my day off to pick it up but can't get in contact
The Following User Says Thank You to turtlefeeder For This Useful Post:
twag4 (11-20-2016)
Old 11-20-2016, 11:06 PM   #26
Dr. BRZ
Dr. BRZ's Avatar
so i have a light weight pulley kit, would yall recommend the sb7 since it weighs 11.7lbs and not the sb8 at 10.2lbs? I'm leaning towards the sb7 also. i am NA, stage 2 e85 EL.
Old 11-20-2016, 11:11 PM   #27
CSG Mike
CSG Mike's Avatar
Unless you have experience with ultralightweight flywheels, go with the SB7.
Old 11-22-2016, 08:01 PM   #28
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Email. Sales@counterspacegarage.com They'll give you details about stocks
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 11:36 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
