Old 11-18-2016, 03:51 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by turtlefeeder View Post
Hey mike lol I was actually looking to drop by and pick up the SB7 since it seem favorable. you guys do you have them in stock?
Great question. Call CSG and ask! I know they were backordered a few weeks ago, but they may have stock now.
CSG Mike is online now   Reply With Quote
Old 11-18-2016, 04:20 PM   #16
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Just called a couple of time no one answering. Mike, are yo not working with or not CSG?
turtlefeeder is offline   Reply With Quote
Old 11-18-2016, 04:44 PM   #17
CSG Mike
CSG Mike's Avatar
I'm the test driver.... I'm at the track right now
Old 11-18-2016, 07:52 PM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I picked my clutch based on what the guys at ft86speedfactory run on their turbo shop car
malubawla is offline   Reply With Quote
Old 11-18-2016, 10:07 PM   #19
twag4
Drives: frs
Originally Posted by Dr. BRZ View Post
it says normal weight for the flywheel on sb7
http://www.advancedclutch.com/600705
The streetlite weighs 11.8 pounds. The whole clutch switch shaves around 10lbs. It is a lighter flywheel. I have this clutch, have held both flywheels together, and it is significantly lighter.
twag4 is offline   Reply With Quote
Old 11-18-2016, 10:11 PM   #20
twag4
Drives: frs
By the way, Fidanza says stock flywheel is 20lbs 7 oz.
Old 11-19-2016, 12:47 AM   #21
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
someone's website is wrong then, check out @ft86speedfactory website. it says normal weight.
Dr. BRZ is offline   Reply With Quote
Old 11-19-2016, 12:58 AM   #22
twag4
Drives: frs
http://www.ft86speedfactory.com/act-...l#.WC_pSbROKhA
Sb7hdss says lightweight flywheel. Not sure where your info comes from, but the sb7 kits come with the streetlite light weight flywheel. I have that very one. Sb8 is the prolite light weight flywheel. Even lighter still...
Read down in the description. It says it is sb7hdss. There is a typo up in the header.
Old 11-19-2016, 12:59 AM   #23
turtlefeeder
Drives: UltraMFrS
Damn this is tough trying to find the SB7 instock around socal ORNAGE COUNTY
Old 11-19-2016, 01:02 AM   #24
twag4
Drives: frs
They have all kinds of typos on both those kits at ft86speedfactory. Goto the ACT website, or counterspace garage for better information.
Old 11-19-2016, 01:06 AM   #25
turtlefeeder
Drives: UltraMFrS
CSG is 25min from me but I've tried calling them many times they won't answer I would go down there this Monday on my day off to pick it up but can't get in contact
Old 11-20-2016, 10:06 PM   #26
Dr. BRZ
Dr. BRZ's Avatar
so i have a light weight pulley kit, would yall recommend the sb7 since it weighs 11.7lbs and not the sb8 at 10.2lbs? I'm leaning towards the sb7 also. i am NA, stage 2 e85 EL.
Old 11-20-2016, 10:11 PM   #27
CSG Mike
CSG Mike's Avatar
Unless you have experience with ultralightweight flywheels, go with the SB7.
Old 11-22-2016, 07:01 PM   #28
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Email. Sales@counterspacegarage.com They'll give you details about stocks
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 10:36 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
