Old 11-15-2016, 04:45 PM   #15
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by stevo_12v View Post
Installed, but requires tune
CounterSpace Garage is offline   Reply With Quote
Old 11-16-2016, 10:23 PM   #16
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
$3100!!!! Are you out of your god damn mind...
No way that sloppy welded intake will out do the new 2017 intake.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-17-2016, 05:15 PM   #17
Snake
Drives: ADM Toyota 86 GT
Deep breath.
Without nice people like OP purchasing these things, chucking it on the dyno and giving us some independent numbers, we wouldn't know. So be supportive! Jun does say that it's been developed to make power after 7,200rpm, up to 8000rpm which I'd say even the 2017 intake has not been designed to do (especially considering the red line is the same as pre-2017).
Snake is offline   Reply With Quote
The Following 12 Users Say Thank You to Snake For This Useful Post:
DAEMANO (11-18-2016), DocWalt (11-20-2016), Hawk77FT (11-17-2016), hmong337 (11-20-2016), JazzleSAURUS (11-19-2016), new2subaru (11-18-2016), PulsarBeeerz (11-17-2020), R2RO (11-18-2016), RSKYBZ (11-07-2018), stevo_12v (11-17-2016), Teseo (11-18-2016), Turdinator (11-17-2016)
Old 11-18-2016, 01:07 AM   #18
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Still confused about what exactly the purpose of this is.
1. To somehow allow you to safely up the rev limiter and drive at up to 8k RPM
Or
2. To essentially "shift" the HP curve over to the right a bit for people who have engines already modified to drive at 8k RPM.
I'm guessing its #2?
Engine internals aside, I get a feeling the car would shake itself apart at 8k RPM haha. Stock redline already makes enough rattle in random places (OEM reverse lockout comes to mind)
The Following User Says Thank You to PandaSPUR For This Useful Post:
stevo_12v (11-18-2016)
Old 11-18-2016, 05:49 AM   #19
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Ummmm.... Ok, I'm not sure what's going on here but.... There have been the Crawford power blocks before and the y took max power to the left but increased area under the torque curve. Net win. I am guessing if these extend the power curve to the right they are actually shorter tubes than stock. But as @kch mentioned without upgrading the valve train could be a little unreliable.
Old 11-18-2016, 05:55 AM   #20
Captain Snooze
Drives: Red Herring
@VeloxEric
Old 11-18-2016, 10:40 AM   #21
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
That is exactly what you're seeing Snooze. The runner length has been substantially reduced. We don't know about the difference in diameter, but we're going to just have to take their word for it that the difference in runner length and diameter has now shifted the resonance to 8000rpm. I like that they used to words "inertial supercharging" to describe helmholtz resonance too, marketing buzzword really, but is a pretty good synonym for what is happening.
It also looks like they greatly increased the plenum volume (which you would almost have to with this design in order to decrease runner length), but who knows what the increase in volume is. Historically too big a volume increase on N/A leads to a laggy feeling in throttle response (not saying it's too big mind you, I know JUN knows their stuff), but is outstanding in a forced induction application.
And that's what I initially thought when i saw this manifold, that it looks like they made it for FI. Possibly specifically for the FA20 WRX. But then I saw it's designed for N/A. So either way, it's a super cool part that's way out of my personal budget, which is why I'm glad that you have one to show us
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
stevo_12v (11-18-2016), Traktor (12-19-2016)
Old 11-18-2016, 12:52 PM   #22
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Quick update
Photo of the dyno plot from my tuner. Didn't want to up the rev range to 8krpm obviously as the motor doesn't have the necessary mods for that.. yet.
Around a 12hp gain in N/A form, well for me at any rate. Previous dyno power run was ~190hp. Also I decided to get the exhaust changed out from the 2.5in dia HKS Spec-L to the 3in dia HKS Racing Single exit cat back.
I still retained the Crawford power blocks and the Torquesolution TAB spacers. TODA throttle body also.
Ran on pump gas also. I haven't had a chance to drive it yet as I'm at work. Just got the photo sent to me.
stevo_12v is offline   Reply With Quote
The Following 5 Users Say Thank You to stevo_12v For This Useful Post:
BatStig (11-18-2016), DocWalt (11-20-2016), hmong337 (11-20-2016), Hyper4mance2k (12-13-2016), Teseo (11-18-2016)
Old 11-18-2016, 01:50 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm? JUN's intake manifold with shorter runners for optimisation for higher rpms AND BPB that makes longer runners to move optimisation at lower rpms.
WHY?
kch (12-14-2016)
Old 11-18-2016, 02:35 PM   #24
CounterSpace Garage
Good work Steve! Pedal dance time.
Old 11-18-2016, 03:26 PM   #25
Tokay444
WHY?
As stated, he doesn't want to rev out to 8000rpm, yet.
Old 11-18-2016, 03:48 PM   #26
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
His point is why shorten the runners with a new intake manifold just to lengthen it again with the blocks.
The Following 4 Users Say Thank You to x808drifter For This Useful Post:
Captain Snooze (11-18-2016), hmong337 (11-20-2016), kch (12-14-2016), Summerwolf (11-18-2016)
Old 11-18-2016, 03:50 PM   #27
Tokay444
To keep the power band where he needs it. There are obviously other advantages to the manifold besides the shorter runners, as evident by the dyno plat.
The Following User Says Thank You to Tokay444 For This Useful Post:
stevo_12v (03-06-2019)
Old 11-18-2016, 04:28 PM   #28
Captain Snooze
Drives: Red Herring
WHY?
To keep the power band where he needs it. There are obviously other advantages to the manifold besides the shorter runners, as evident bu the dyno plat.
No, I am totally lost.
Photo shows a positive gain in the power curve. Win.
BUT as @x808drifter and @churchx says, and the part that messes with my head, I would have thought that the net length of the runners is about the same. Short JUN runner plus blocks equals same length. I am not disputing the graph, I just don't understand how the result has been achieved.
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 09:16 PM
Automatic Transmission Surge N1rve Issues | Warranty | Recalls / TSB 25 03-16-2016 10:58 PM
Fuel surge issue??? owenxguo Tracking / Autocross / HPDE / Drifting 1 12-22-2014 09:58 PM
SBD turbo surge?? shif7i7down Forced Induction 72 11-20-2014 09:49 AM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 12:28 PM
