Drives: hyper blue BRZ
JUN GT SURGE TANK FOR FT86/BRZ
Hi guys recently discovered this beauty, anyone have any info or thoughts on this intake manifold seems promising able to "boost stock rpm7200 to 8000rpm".link here https://www.nengun.com/jun/gt-surge-tank-for-ft86-brz
#2 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
http://www.junauto.co.jp/news/enews000206.html
Yeah found it also. Wonder what the HP gain is for a N/A. Not a bad way to spend 351,000 JPY.. |
#3 |
Drives: 2014 GT86
Even if hp gains are less, ability to rev higher is good by itself, due enabling of longer being in lower gears. Though this looks not so much enabling reving higher (which i guess would rather need extra stronger engine internals, like in some more boosted FI setups with rebuilt engines), but rather changing intake manifold design to skew optimisation to top rpm range (probably hurting low rpm/mid rpm performance). Am i wrong?
#4 |
Señor Member
If you change the title to intake Jun Intake Manifold you may get a bit more interest in this thread.
1974 TA22 Celica
2013 86 GT |
| The Following 7 Users Say Thank You to Turdinator For This Useful Post: | ATL BRZ (11-14-2016), celek (11-16-2016), go_a_way1 (11-18-2016), Hostile_Kittens (11-14-2016), Hyper4mance2k (12-13-2016), Kris86 (09-12-2016), venturaII (11-15-2016) |
#5 |
Senior Misanthrope
The intake isn't the biggest problem for the rpm limiter; it's the valvetrain. No way in hell will I run 8k redline on stock springs.
| The Following User Says Thank You to kch For This Useful Post: | Captain Snooze (11-18-2016) |
#6 |
...Just add nauseum
Drives: 2003 (AP1) S2000
The translation is very rough.
So, it's an intake manifold with tuned runner diameter and length for a volumetric efficiency peak at higher than stock RPM. "Surge tank" is a poor translation. If max VE, and max torque stays the same, but moves higher in the Rev range, the percent increase in horsepower will be equivalent to the percent increase in RPM for peak torque, because of how horsepower is calculated.
There are many ways to displace.
-Spartarus |
| The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
#7 |
Getting this installed this week
| The Following 9 Users Say Thank You to stevo_12v For This Useful Post: | DAEMANO (11-18-2016), Drakiv (11-14-2016), go_a_way1 (11-18-2016), Hawk77FT (11-14-2016), Hyper4mance2k (12-13-2016), johan (11-16-2016), new2subaru (11-14-2016), R2RO (11-15-2016), Ultramaroon (11-14-2016) |
#8 | |
Drives: GTS 86
Keep us updated |
| The Following User Says Thank You to Hawk77FT For This Useful Post: | stevo_12v (11-14-2016) |
#9 |
Might be closer to $6k as I'm getting it installed and car retuned as well. Gonna put my TODA T/B on for dat throttle response :P
![]() I'll be very happy if I manage over 15hp tbh lol Car already has *most* of the N/A and response mods you could think of - HKS EL Headers, MOTIV overpipe, CBE will be changing out to HKS Single Racing Version(3in) - HD Clutch, 10.5lbs flywheel - CF driveshaft - 4.556 final drive - Lightest 18's you can get(TWS T66F) at any rate, it will be a good supporting mod for when I go turbo later on |
| The Following User Says Thank You to stevo_12v For This Useful Post: | Hawk77FT (11-14-2016) |
#10 | |
Sent from my HTC One_M8 using Tapatalk |
#11 |
Drives: Honda Accord Euro
Holy s*it dat price. In for results.
#12 | |
Drives: GTS 86
Needs more ACE header! My mods are very similar to yours and I can say it is pretty quick
#13 |
Installed, but requires tune
| The Following 4 Users Say Thank You to stevo_12v For This Useful Post: |
#14 |
Drives: GT86 GTS
| Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion | Xero-Limit | Engine, Exhaust, Transmission | 42 | 04-27-2017 09:16 PM |
| Automatic Transmission Surge | N1rve | Issues | Warranty | Recalls / TSB | 25 | 03-16-2016 10:58 PM |
| Fuel surge issue??? | owenxguo | Tracking / Autocross / HPDE / Drifting | 1 | 12-22-2014 09:58 PM |
| SBD turbo surge?? | shif7i7down | Forced Induction | 72 | 11-20-2014 09:49 AM |
| Automatic FRS Surge in Manual Mode | N1rve | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 12:28 PM |
