Old 11-18-2016, 12:21 AM   #1
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
ACT CLUTCH CHOICE
Hey guys my OE clutch is slipping and looking for something that would be better so for I've heard ACT is a great quality clutch so I'm looking into the SB7 than I saw SB8 a bit confused.
It looks like SB7 is mainly for street and SB8 is street and mainly racing in a sense. But is that all? Any has experienced with ACT SB7/ SB8, which would you recommend for a boosted car 12psi 300hp. I don't want any chattering for sure though.
Thanks for the useful information 👍
Ps need clutch really soon. It's slipping around 4K rpm so really... really soon
turtlefeeder is offline   Reply With Quote
Old 11-18-2016, 12:47 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It's not an ACT clutch, but I'd recommend the South Bend Stage 2 clutch. The daily model holds 315 ft/lbs of torque and is still very soft peddle. Others hold upwards of 400 ft/lbs, too.
MS, CSCS, TSAC-F, CPT
Old 11-18-2016, 02:01 AM   #3
turtlefeeder
Drives: UltraMFrS
Yeah I was looking into south bend too but I heard they chatter and I've read people are having great results but I'm a bit low on dough 🍩 lol
You have it on your twin right?
Does it chatter? Are you boosted?
Old 11-18-2016, 03:30 AM   #4
CSG Mike
CSG Mike's Avatar
SB7HDSS
CSG Mike is online now   Reply With Quote
Old 11-18-2016, 03:50 AM   #5
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Thanks for the useful information ��
bro, the only difference is the sb7 doesn't come with a light weight flywheel, the sb8 comes with the lightweight flywheel. they are both rated the same. so there decide, do you want a lightweight flywheel or nah?
Dr. BRZ is offline   Reply With Quote
Old 11-18-2016, 07:49 AM   #6
weederr33
weederr33's Avatar
I have the SB Stage 2 daily, but there is no chatter. Of course, I have the stock flywheel too. And yes I'm boosted haha
Old 11-18-2016, 09:37 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'll second SB7HDSS.
JazzleSAURUS is offline   Reply With Quote
Old 11-18-2016, 10:07 AM   #8
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
Sb7
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
Old 11-18-2016, 11:30 AM   #9
twag4
Drives: frs
Not true. Sb7 comes with streetlite flywheel, sb8 is the prolite flywheel. Both are much lighter than stock. Prolite is the lighter of the two.
twag4 is offline   Reply With Quote
Old 11-18-2016, 12:03 PM   #10
turtlefeeder
Drives: UltraMFrS
SB7HDSS
Hey mike lol I was actually looking to drop by and pick up the SB7 since it seem favorable. you guys do you have them in stock?
Old 11-18-2016, 12:51 PM   #11
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
SB7-XTSS
I have this clutch kit and no complaints. Comes with everything needed including new flywheel, bolts and lube. Good for 347 ft lbs of tq
malubawla is offline   Reply With Quote
Old 11-18-2016, 01:07 PM   #12
turtlefeeder
Drives: UltraMFrS
Originally Posted by malubawla View Post
SB7-XTSS
Chatter?
Old 11-18-2016, 01:33 PM   #13
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Not at all. Only some faint noises around 1800-2100 rpm but go away when accelerating. At idle, it is as quiet as stock. The pedal feel is a bit stiffer, but not too bad. I still drive my car everyday in traffic as well.
Old 11-18-2016, 01:48 PM   #14
Dr. BRZ
Dr. BRZ's Avatar
it says normal weight for the flywheel on sb7
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 10:36 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
