Old 11-15-2016, 04:10 PM   #15
unhappymeal
Drives: 2018 Miata RF, 2017 Golf R
Originally Posted by track junkie View Post
It isn't mentioned in the 2017 BRZ owners manual. Hopefully it's dealer adjustable.
Unhappymeal can you feel any difference in the handling between the 2016 and the 2017 BRZ. Can you detect if the 2017 is more responsive to steering inputs than the 2016.
Sorry, I can't comment. I literally had the 2016 for five minutes before rolling it into a ditch.
unhappymeal is offline   Reply With Quote
The Following User Says Thank You to unhappymeal For This Useful Post:
track junkie (11-15-2016)
Old 11-15-2016, 04:17 PM   #16
unhappymeal
Originally Posted by pinski View Post
I can't believe they did away with the leveling control! That said, when I first got it new from the dealer, mine were pointed at the highest setting.
This must be a significant improvement over the pre-17s then. Ours is garbage, warmed over.
Huh. I think it works rather well.
Most cold mornings I don't even turn on the climate control after pulling out of the garage. Just the passive heat flowing through the plumbing is enough to keep the little cabin warm.
Is it as cheap feeling as the pre-17's? Mine is barely a step above plastic.
Depends on your purpose. The car is underbraked for even the most laid back track day. Mine all but completely faded after a 30 minute session. Fluid and pads are a worthwhile upgrade, imo.
I always thought this was missing as well - I don't get why they left it off.
Welcome! Glad you decided to stay in the fold after rolling the '16. As much as I enjoy mine, if I somehow crashed it, I doubt I'd be back.
I say the dual zone is laughable because the cabin is small and there are so few vents. The difference between the passenger setting it to 20 C and the driver having it at 24 C is negligible.
As for your other questions:
-The infotainment for Canada is the same as the 2013-16's, but it's still better than Cadillac CUE. Yeah, ponder that.
-The steering wheel material in the 2017 feels *cheaper* than the earlier models. It's really not good, at all. I'm hoping once it absorbs some oils from human skin it softens.
-The car is not underbraked for street use. The pedal lacks the initial bite of the 4-pot Brembos on my ATS, but it stops well. I honestly think it's the tires holding it back.
-The lack of automatic unlock/lock is my largest gripe. It's such a simple feature and it blows my mind that they omitted it.
Old 11-15-2016, 05:28 PM   #17
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
"The lack of automatic unlock/lock is my largest gripe. It's such a simple feature and it blows my mind that they omitted it."
Well I believe, at least on Made in USA cars, like Ford and GM, the autolock is on auto trans cars only.
Examples: My 05 Mustang V-6 auto had it. My 05 Mustang GT manual does not have it.
"The car heats up really quickly--I like this."
Also car defogs both front and rear very quickly...best of any car I've ever had.
Very helpful considering the wipers, at their fastest speed, are not fast enough in heavy rain.
Note: I've not driven this car in snowy/icy conditions, therefore don't know how well w/s stays clean in such conditions. Other cars I've had get snow/ice on top left of w/s in such conditions, necessitating stopping the car to flick the left wiper arm to deice itself. I would design cars to have heating elements top of w/s, very few engineers consider this. Well most likely due to cost cutting in most cars.
ToySub1946 is offline   Reply With Quote
Old 11-15-2016, 05:39 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by DatsunDimer View Post
Per the 2017 release
"Automatic LED Low & High Beam Height Adjustment"
EDIT- That was meant to agree with you @unhappymeal ...the headlights are suppose to be auto-leveling.
If this is the case, then there is usually a switch or sensor connected to the rear lower control arm.
May force aftermarket lower control arms to be revised.
-alex
Old 11-15-2016, 05:49 PM   #19
86Boyz
Drives: on the highway to hell
You can remove the air conditioning system in order to go faster.
86Boyz is offline   Reply With Quote
The Following 2 Users Say Thank You to 86Boyz For This Useful Post:
Somerandom18 (11-15-2016), ToySub1946 (11-15-2016)
Old 11-15-2016, 09:06 PM   #20
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
Welcome to the 2x BRZ in a year club
softgrip is offline   Reply With Quote
Old 11-16-2016, 06:33 AM   #21
It is pretty much the same as all cars where the stuff after the wipers builds up and starts to freeze.
The heating system does a great job of defrosting and warming the upper body in really cold temperatures. It however really sucks at warming your feet! Even with the blower just blasting the floor the top of you will be wetting and your feet ice cold. There was a couple of threads on this and we finally figured out that even though the blower is down there it isn't circulating the heat through the whole car. There isn't enough space between the back of the front seats and the front of the back seats to allow much air movement and this prevents the air back there from heating well. The result is cold air from the back keeping your feet frozen for about1/2 an hour of driving.
soulreapersteve (12-16-2016), ToySub1946 (11-16-2016)
Old 11-16-2016, 07:05 AM   #22
unhappymeal
Odd. Both of my Civic Sis, which are manual, had it.
Old 11-16-2016, 07:10 AM   #23
None of my 7 DSM/Mitsubishis had it. Neither my MTs or the wife's ATs. I hate that feature anyway and would have disabled it if it was on these cars.
Old 11-16-2016, 12:30 PM   #24
acetothermus
Drives: Flying in a Blue Dream
-The doors don't automatically lock over 25 kph or unlock when stopped. Really Toyota/Subaru?
I think this is more a symptom of manual vs. auto. My truck (which is a Toyota) is manual and doesn't lock the doors when I shift into gear.
Maybe that's just the way Toyota does things?
acetothermus is offline   Reply With Quote
Old 11-16-2016, 12:43 PM   #25
LOL. FT86club, where the unexpected can happen and usually does.
Guy says he crashed his car in five minutes and nobody asks what happens. The whole thread just turns into a discussion on auto locking doors.
acetothermus (11-16-2016), daiheadjai (12-17-2016), Rakshaa (11-17-2016), tCsonfrs (11-17-2016)
Old 11-16-2016, 01:16 PM   #26
acetothermus
I think the mention of zero C was enough reason to not question the wrecking 5 mins after delivery.
The Following User Says Thank You to acetothermus For This Useful Post:
Tcoat (11-16-2016)
Old 11-16-2016, 01:19 PM   #27
LOL ya but there was way more too it. I am just amazed that it just received no real reaction.
Old 11-16-2016, 01:24 PM   #28
ryoma
ryoma's Avatar
if this were the Honda forums...
The Following 2 Users Say Thank You to ryoma For This Useful Post:
acetothermus (11-16-2016), Tcoat (11-16-2016)
Bought kandiflippin Want-To-Buy Requests 0 05-22-2016 08:58 AM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 03:57 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 09:32 PM
Just bought some... markmatley Hawaii 0 11-27-2012 03:44 PM
