Old 11-13-2016, 04:04 AM   #14925
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Originally Posted by Oxyg3n View Post
First mod, a perrin catback 👌
Sent from my SAMSUNG-SM-G920A using Tapatalk
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 11-13-2016, 11:56 PM   #14926
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
First autocross with my '17 BRZ. Just have suspension bits on it right now.
justinco is offline   Reply With Quote
Old 11-14-2016, 12:09 AM   #14927
johan
Drives: '14 981CS, '99 NB1
Had @VitViper tune my '17 AT. Only mods are K&N panel filter and Tomei UEL.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Jmonty (11-18-2016)
Old 11-14-2016, 11:39 AM   #14928
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
HKS EVC6-IR
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following 6 Users Say Thank You to Luftwaffel For This Useful Post:
jcw99 (11-24-2016), MGPAX (11-15-2016), MJones_RB (11-21-2016), new2subaru (11-14-2016), radroach (11-14-2016), Zaku (11-15-2016)
Old 11-14-2016, 11:52 AM   #14929
Originally Posted by Luftwaffel View Post
HKS EVC6-IR
Your user name is making more sense all the time!
Luftwaffel (11-14-2016), OrangeGuitar (11-17-2016), Zaku (11-15-2016)
Old 11-14-2016, 02:12 PM   #14930
Luftwaffel
Boost Creep
Luftwaffel's Avatar
The funny thing is I'm trying my absolute hardest not to have gauge clutter. I want to monitor oil pressure but I refuse to add another hard gauge. Maybe I can do it in software, possibly with an Arduino if I have to.
The Following User Says Thank You to Luftwaffel For This Useful Post:
Tcoat (11-14-2016)
Old 11-14-2016, 03:43 PM   #14931
johan
Swap in a 17 limited gauge cluster. That'll free up some space on the upper gauge set.
Old 11-14-2016, 04:15 PM   #14932
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I don't understand what you're trying to say. There are indicator lights above the LCD in the right panel.
Old 11-14-2016, 06:43 PM   #14933
johan
Installing JDM LEDs in bumper.
The Following 3 Users Say Thank You to johan For This Useful Post:
Kabong (11-18-2016), MJones_RB (11-21-2016), Zaku (11-15-2016)
Old 11-14-2016, 08:18 PM   #14934
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
He is trying to tell you the 2017 gauge cluster gives water and oil temps along with battery voltage readouts.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 11-14-2016, 08:44 PM   #14935
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Apart from taking the bumper out....
How hard was it? Plug N Play kind of thing?
Spec C Wannabe is offline   Reply With Quote
Old 11-14-2016, 11:15 PM   #14936
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Yeah it sprung into mind a couple hours after I replied. That's probably not feasible since I think the system is cycled via steering wheel controls? I'm not exactly worried about where I could put the gauge in software... I have no use for the boost gauge on the head unit... it's literally boost gauge #3.
Old 11-15-2016, 12:32 PM   #14937
johan
Our cars don't have the plug on the chassis side, at least that I could find (I spent a long time looking). That didn't make it hard though. I just tapped the OEM DRL power/ground on the driver side headlight, works perfectly. They give you a nice harness to plug into the lights themselves, and zip ties/mounts to run the harness along the body. So aside from having to tap the headlight wiring, install is decently clean and relatively easy. If one was handy with wiring, the whole thing could be done in an hour.
Attached an image of the finished, working product. I also did the magnetic license plate mod while I had the bumper off.
In pix, the LED looks like the color temp is off, but really it's the way the light reflects off the winglet in the bumper and illuminates the pearl clear coat that creates a blueish optical illusion.
Yeah - sorry - I didn't think about the steering wheel controls - definitely a problem.
geezerbrzeezer (11-18-2016), MJones_RB (11-21-2016), Mr.Impreza (11-18-2016)
Old 11-17-2016, 04:37 PM   #14938
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
First autocross for my '17 BRZ.
[ame]http://www.youtube.com/watch?v=DeuRcsZEqj4[/ame]
The Following 3 Users Say Thank You to justinco For This Useful Post:
15limited (11-17-2016), Bristecom (11-21-2016), Lonewolf (11-18-2016)
