Old 11-10-2016, 06:55 PM   #155
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by brzaapi View Post
haha. Well, when you look at it that way
I dont know what i would do if i couldn't mod my car, what a great hobby and stress relief.
You are right it's a great hobby.
We can mod, but there are so many restrictions if wanting to keep it legal. Just as an example I can't get the wheels I want (Enkei RPF1), because they don't have TÜV approval. I have a limited choice of coil-overs etc etc. Brakepads? Forget being legal!.. As we say here when someone asks for advice: "Do you want to be legal, or do you want to be able to brake?".
Tor is offline   Reply With Quote
Old 11-10-2016, 07:10 PM   #156
johan
Drives: '14 981CS, '99 NB1
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Ultramaroon (11-10-2016)
Old 11-10-2016, 09:11 PM   #157
Make the twins great again.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
AKBrrrrrrrrZ (11-10-2016), chaoskaze (11-20-2016), CSG Mike (11-10-2016), drew_kar (11-11-2016), gramicci101 (11-11-2016), Lynxis (11-11-2016), meWant (11-11-2016), sato (11-12-2016), why? (11-12-2016)
Old 11-11-2016, 09:20 AM   #158
CSG Mike
CSG Mike's Avatar
This is how you baseline 17 OEM suspension vs.... JRZ, Ohlins DFV, and Tein SRC.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
BatStig (11-11-2016), BRZ FTW (11-11-2016), Lynxis (11-11-2016), SuperDave (11-11-2016)
Old 11-11-2016, 09:57 AM   #159
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Looks you all are going to have a fun Friday once the sun comes up. Where you all at?
Edit: Lucky SOBs, I am stuck in the office all day. Although i may close early since half my customers took off
for veterans day.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-11-2016, 02:58 PM   #160
CSG Mike
CSG Mike's Avatar
for veterans day.
Ironically I'm stuck working, instead of spectating at Super Lap battle.
Grr.
brzaapi (11-14-2016)
Old 11-14-2016, 04:51 PM   #161
CSG Mike
CSG Mike's Avatar
So, I can confirm that a 13-16 intake fits on a 17 MT engine (red manifold). The only issue is that the clip that holds the MAF harness against the intake is in the wrong orientation.
MAF scaling needs to be for 17, not 13.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
brzaapi (11-15-2016), funwheeldrive (11-16-2016), SuperDave (11-14-2016)
Old 11-16-2016, 02:22 PM   #162
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I know you havent likely had this on the track yet, but i was curious after a couple more weeks if you could share anymore experience on the '17 MY willingness to rotate?
Mid-Corner Dynamics?
Rotation?
Does the car suck back in when you lift? or continue on the line like the Zenki models?
I may be early on these questions, but I am just damn curious.
Daily: Audi TT RS
Old 11-17-2016, 07:02 PM   #163
CSG Mike
CSG Mike's Avatar
Hmmm... why are BOTH of my cars here?
Old 11-17-2016, 07:04 PM   #164
CSG Mike
CSG Mike's Avatar
Rotation?
Mid-corner is understeery off throttle, will rotate on throttle.
Lifting can cause terminal understeer or oversteer, depending on the loading of the suspension when you lift... in most cases it'll understeer.
brzaapi (11-21-2016)
Old 11-17-2016, 07:04 PM   #165
gramicci101
Off Topic
Engine swap? It's a little early for that; you just got it.
The Following User Says Thank You to gramicci101 For This Useful Post:
funwheeldrive (11-17-2016)
Old 11-18-2016, 03:53 PM   #166
CSG Mike
CSG Mike's Avatar
This is happening
brzaapi (11-21-2016), MaximeT (11-18-2016), whataboutbob (11-18-2016)
Old 11-18-2016, 05:32 PM   #167
lbejosano
Drives: 2014 Firestorm Scion FR-S
Actually, almost completely
Just saw this thread and want to take a crack at it, for fun. Specifically:
CSG-spec Brembo GT
Tein SRC 3-way
CSG built heads
TWS wheels
On a more general level I want to guess this build is leaning more towards the N/A route based on (what I interpret as) hints toward raising the redline, and the fact that it's a "big surprise" as opposed to what's already out there (lots of boosted track builds).
lbejosano is offline   Reply With Quote
The Following User Says Thank You to lbejosano For This Useful Post:
CSG Mike (11-19-2016)
Old 11-20-2016, 01:44 PM   #168
CSG Mike
CSG Mike's Avatar
Not bad! 8 sessions between two tracks, and plenty of laps.
Wear is pretty even with the evaluation set of dampers and a last minute eyeballed at the track alignment. Tire temps had less than 12F total delta across each tire AND all 4 tires.
aegisdrgn (11-20-2016), BatStig (11-20-2016), brzaapi (11-21-2016), Lynxis (11-20-2016)
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 09:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 07:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 03:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 01:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
