Old 11-10-2016, 06:50 PM   #15
Teseo
Drives: frs
The red manifold fits on 13-16 engines; its a direct bolt-on.
Any chance you guys can swap 2017 manifold on 13-16 car and dyno it to see the results?
Old 11-10-2016, 06:52 PM   #16
CSG Mike
CSG Mike's Avatar
I dont plan on taking mine off, but if you want to send a loaner, I can probably convince CSG to do it with the boosted BRZ.
Old 11-11-2016, 07:45 AM   #17
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Does this mean you will be running your car NA for a while?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-11-2016, 08:30 AM   #18
If the total changes made for 17 made a 5HP increase what do you hope to see from dynoing just a manifold?
Old 11-11-2016, 09:43 AM   #19
gtengr
Drives: 2017 BRZ
I also want to see what effect the revised header has on the superchargers. I'm hoping for a mild 5-10 rwhp increase on the base kits.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
HI (11-16-2016)
Old 11-11-2016, 10:55 AM   #20
CSG Mike
CSG Mike's Avatar
Based on NA tuning results, I doubt there are any significant gains to be had with the new manifold on FI cars.
Tcoat (11-11-2016)
Old 11-11-2016, 10:01 PM   #21
gtengr
Drives: 2017 BRZ
Oh well, I'm looking for an excuse to avoid changing the header.
Old 11-14-2016, 07:37 AM   #22
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
If the new header still has a cat and your still planning to go FI then your better of swapping with something aftermarket with no cat.
The cat can prematurely let go and that can cause some conditions that will not be good. Like running lean
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-14-2016, 03:44 PM   #23
gtengr
Drives: 2017 BRZ
Thanks for the heads up. Is cat degradation influenced by boost levels and/or turbo vs supercharger?
Old 11-25-2016, 03:23 PM   #24
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
boost. It will happen over time.. no matter what kind of induction you choose.
FRS
The Following User Says Thank You to Boofneenee For This Useful Post:
gtengr (11-25-2016)
Old 12-07-2016, 11:08 AM   #25
gtengr
Drives: 2017 BRZ
Any new developments?
2017 Acura NSX vs. 2017 Nissan GT-R JPxM0Dz Other Vehicles & General Automotive Discussions 1 10-19-2016 01:50 PM
Controlling the nannies in 2017 vs. pre 2017 mdm Scion FR-S / Toyota 86 GT86 General Forum 23 10-04-2016 11:11 PM
Models without LSD Harvey Scion FR-S / Toyota 86 GT86 General Forum 42 06-17-2015 07:59 AM
Scale models The359 Other Vehicles & General Automotive Discussions 1 06-09-2013 04:10 PM
Exactly what will/won't be the same between the AS1 models? Mess11 BRZ First-Gen (2012+) — General Topics 7 10-28-2011 11:26 PM
