Old 11-07-2016, 02:56 AM   #7603
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by nmastereal View Post
Sprintex have always had a 69mm pulley. It now comes packaged in IC kits too.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-07-2016, 04:28 AM   #7604
Rich196
Drives: GT86
I have stutter around 1500rpm even when up to temperature. Any judders like you have hit a rev limiter a couple of times and then it pulls hard.
Any ideas?
Rich196 is offline   Reply With Quote
Old 11-07-2016, 11:20 AM   #7605
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Any ideas?
Would need to look at datalogs.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 11-07-2016, 12:20 PM   #7606
Kodename47
Kodename47's Avatar
Drives: UK GT86
Any ideas?
Want me to have a look mate? Could be fuel, ignition timing or a hardware error.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-08-2016, 12:30 PM   #7607
riboyster
riboyster's Avatar
Maybe some sort of air leak?
Old 11-10-2016, 01:28 AM   #7608
sam69
Drives: GT 86
Need some help to find a temp gauge that is compatible with this Bosch AIT sensor (from a BMW) http://cgi.ebay.com.au/ws/eBayISAPI....175&rmvSB=true
In the process of fitting one to the base of a 210 sc so I can get pre and post laminova charge temps for R&D .
Have done a bit of searching but no luck so if anyone knows of a decent gauge that will work with this
sam69 is offline   Reply With Quote
Old 11-10-2016, 03:49 AM   #7609
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why not wire it into the ECU and then you can have all IAT temps logged?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-10-2016, 08:23 AM   #7610
sam69
Drives: GT 86
Pic of what's been done .
I have no idea how to wire it to the ecu and I was hoping it would work with the post cooler ait gauge I already have but the resistance / value of the sensors is way different so no go and what are the chances the ecu would recognize the sensor
That's why for a noob like me I was trying to go with a kiss system and just buy a compatible gauge .
Old 11-10-2016, 10:14 AM   #7611
Kodename47
Kodename47's Avatar
Drives: UK GT86
Rear O2 or CPC input. Custom map with the sensor voltage mapped correctly. Then you could have a direct output of IAT etc. You could then rewire the other sensor to the original IAT sensor input. You then have 2 temp sensors that can be used by the ECU.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-10-2016, 07:28 PM   #7612
SocalMonsta
SocalMonsta's Avatar
Drives: White FRS
Hey guys. The aftermarket idler pulley on my kit has been squeaking quite a lot lately.
Anyone have any similar issues/insight?
Edit: I've replaced the actual pulley, but it seemed it might be an issue with the pulley and the little spacer to which it connects.
SocalMonsta is offline   Reply With Quote
Old 11-11-2016, 03:40 PM   #7613
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
When mine starts to squeak for some reason it goes away with a new belt, seems like when they stretch a little it puts the oem tensioner pulley in an odd spot making it squeak. A new belt fixes it every time for me. I'm using an HD belt now and I haven't had a problem since.
Chrisbrz14 is offline   Reply With Quote
Old 11-11-2016, 05:27 PM   #7614
SocalMonsta
Drives: White FRS
Ya, I forgot but it did stop squeaking when I replaced the belt. Then it slowly came back lol. Ill give that a try. Thanks a lot!
Old 11-12-2016, 01:27 PM   #7615
SocalMonsta
Drives: White FRS
Which belt do you have installed?
Old 11-12-2016, 06:17 PM   #7616
stockysnail
Just the tip
stockysnail's Avatar
I had the same thing and went through 3 regular belts. I switched to the blue belt and it eventually started squeaking as well. I think our cars have a squeak curse from various things.
The Following User Says Thank You to stockysnail For This Useful Post:
CarzCarzCarz (11-15-2016)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
