Old 07-28-2013, 06:00 AM   #1
eckoflyte
Drives: Toyota 86 GTS
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber?
So I installed these today but am wondering about the grease that comes packaged with the bushings.
I noticed that Whiteline included grease which is a Lithium base complex grease with moly additive (really just marine grease or multi purpose grease you can get at the hardware store).
Quoting straight from Whiteline's website - "The supplied grease has been formulated from a reinforced No. 2 lithium complex base and selected additives with molybdenum disulphide for mechanical stability extreme pressure qualities for extended life and a high melting or drop point of 230C minimum."
Since the Whiteline poly bushings make direct contact with the stock rubber bushing, is this grease safe to use on rubber?
Now that they are installed, I am worried it may dry out the stock bushings causing them to crack. I can't find any definitive information that it is safe to use on rubber.
eckoflyte is offline   Reply With Quote
Old 07-28-2013, 08:30 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Jan at white line is pretty good at responding, send him an email.
Old 07-28-2013, 08:34 AM   #3
eckoflyte
Sorry mate, i have no idea who Jan is. Tried googling and checking whiteline website but no luck
Old 07-28-2013, 10:01 AM   #4
FastWhite
Drives: Subaru BRZ Limited M/T
Jan@whitelineus.com
Jan@redrangerusa.com
This is what I have on file for Jan
When I had issues with my STI bushings
FastWhite is offline   Reply With Quote
Old 11-09-2016, 01:23 PM   #5
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
any update on this ?
neilvosko is offline   Reply With Quote
Old 11-09-2016, 02:13 PM   #6
Lithium or silicone based greases are fine for rubber and plastic. We use lithium grease to install bushing at a plant I work at. Do not use petroleum based greases on rubber or plastics!
neilvosko (11-09-2016), wparsons (11-09-2016)
Old 11-09-2016, 03:11 PM   #7
gramicci101
Off Topic
Water-based lube works much better on rubber. Plus it's easier to wash off later.
Old 11-09-2016, 03:15 PM   #8
Unless it is on components where you don't want it to wash off!
Old 07-14-2018, 11:24 AM   #9
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Bumping this thread to add some information.
Calcium Sulfonate Grease can be used in place of the grease that comes with Whiteline. Generally performs better than lithium complex grease and is compatible with it too.
Lubrimatic 11404 has a drop point of ~287C (550f) and is certified NLGI #2 for automotive wheel bearing and chassis lubricant. A pound of it cost ~$12 on Amazon, you can use it for your clutch TOB and fork pivot too, beats paying for what Subaru recommends in price and performance.
Trueweltall is offline   Reply With Quote
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 09:20 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 05:15 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
