Old 11-09-2016, 09:11 AM   #15
wbradley
Sarcastic SOB
wbradley's Avatar
45 HP increase, no ethanol fuel. Those extra horses will be very expensive after a shop like Cosworth builds it, and by build it I mean a completely different engine utilizing the same block. You have to give up buying a house to pay for it. But why?
Old 11-09-2016, 09:34 AM   #16
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
My direction started with a 4.556 FD for around 11% faster gearing (all gears). Drop in air filter, aluminum drive shaft (debatable benefit, but tightened the feel of the drive train for me and weighs half of stock).
Going forward looking at Crawford power blocks, Ace EL headers and a custom tune.
Further down the line some forged 17x7.5" wheels with 225 rubber and, if I can put up with 30% range reduction and the hassle of finding E85, go for a flex fuel custom tuned kit.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 11-09-2016, 10:31 AM   #17
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Vracer111 View Post
For NA mods I would do things which would concentrate on lightening mass and lowering MOI of parts while keeping it reliable enough for a DD....don't care about raising power levels as much as getting better engine responsiveness from an NA build. If you can up the redline you can up the power... costs $$$$ though.
Valvetrain and drivetrain would be the focus...exhaust and intake work are a given on any modded car.
Camshafts, rockers/lifters, valves/springs, lightweight flywheel, and reagearing the rear end is where I'd first spend my money/efforts for building NA with the FA20.
Quick FYI there engines don't make any more power after roughly 7800 rpm they die out. You can not do cams that are even remotely worth while without changing the stroke and pistons to prevent them from kissing the valves.
Old 11-09-2016, 10:34 AM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Does your driveshaft make much noise?? I am looking at getting on simply because its one piece. And get lighter wheels makes big difference on how your suspension reacts to the road that's a step in the right direction
Old 11-09-2016, 01:36 PM   #19
driggity
Drives: Silver Coupe with a Boxer
Originally Posted by DSLeach View Post
I don't want to run E85 or other Flex Fuels. While available locally, its not available everywhere and I don't want the added hassle of swapping out tunes to accommodate the availability/unavailability of Flex Fuels in other locations.
It's a minor note, but with one of the Flex Fuel kits and Tunes you don't have to deal changing tunes. It will all be handled automatically based on the ethanol content measured by the Flex Fuel kit.
driggity is offline   Reply With Quote
Old 11-09-2016, 02:38 PM   #20
brzd
brzd's Avatar
Drives: Firestorm FRS
Oft plus a good uel header will make a noticeable difference. I suggest a shorter final drive to make it feel fast.
That's my next mod since I too am not planning to go FI
Sent from my SM-G920W8 using Tapatalk
brzd is offline   Reply With Quote
Old 11-09-2016, 02:58 PM   #21
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
It's not the loss of mass that is most important in a lightweight flywheel, it's the redistribution to give a lower MOI that is most important...
I don't know about you, but when I've installed racing flywheels with as much mass removed from the periphery as possible to drop the MOI, acceleration/decceleration of the vehicle noticeably and measureably increases - and has nothing to do with a 'power increase'. If you want an assembly to spin up quicker you can either apply more power to it or you could reduce it's MOI - thereby reducing the effort/time needed to accelerate/deccelerate it. Wheel selection is the same way, select the wrong wheels with unneccesary mass concentrated at the periphery and you just slowed down your vehicles acceleration/decceleration. Select a same mass set of wheel with a maximized low MOI and you just increased the vehicles acceleration/decceleration. Same mass, different result - all depends on how its distributed.
Like I said in my initial post, don't really care about raising the power level as much as letting the engine do it's job easier and quicker through MOI reduction. The goal of a NA motor build to me is to increase responsiveness (the ability to accelerate/deccelerate the drivetrain quicker). Increasing power level doesn't necessarily give you a more responsive motor - it can, but it's not a given.
I WAS going to respond in my usual fashion.
However, since last night I have lost the will to live.....
Sure! Reduce weight of the engine & drivetrain rotating mass.
You will immediately feel a "HUUUUGE" increase in HP.
It will make this car great again.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Cole (11-09-2016), Tcoat (11-09-2016)
Old 11-09-2016, 03:18 PM   #22
Saw you posted.
Expected a good read.
Got this instead.
Old 11-09-2016, 03:48 PM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Intake
From what I have read, you can achieve almost all the gains available on the intake side by using a simple drop in filter (e.g. K&N). While not as pretty as a GrimmSpeed intake, a K&N is a lot less expensive and give 80 - 90% of the available gains. There are no significant gains for replacing the TB or the intake tube.
I don't think you'll notice anything with a drop in filter. A real waste of money. Personally, I didn't notice any improvement.
The Following User Says Thank You to nikitopo For This Useful Post:
brzd (11-09-2016)
Old 11-09-2016, 03:53 PM   #24
Sounds cool!
Has exactly the same gains as a light pulley.
brzd (11-09-2016), Cole (11-09-2016), FRS13_ (03-30-2017), gramicci101 (11-09-2016), ThatAsianBradah (02-20-2018)
Old 11-09-2016, 04:02 PM   #25
DSLeach
Drives: None
That's my next mod since I too ammo both planning to go FI
The new 2017 does have a higher ratio final drive. If I'm not mistaken it is a 4.30 vs 4.10 in the old car. MT of course.
DSLeach is offline   Reply With Quote
The Following User Says Thank You to DSLeach For This Useful Post:
brzd (11-09-2016)
Old 11-09-2016, 04:03 PM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Sounds cool!
I am preparing now for a bigger TB. I hope I'll not regret it
Old 11-09-2016, 04:04 PM   #27
DSLeach
Drives: None
Actually, I've read exactly the contrary. A K&N alone shows as worth a couple of HP all by itself.
Old 11-09-2016, 04:05 PM   #28
DSLeach
Drives: None
I don't think you will get much from a larger TB except a lighter wallet.
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 09:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 10:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 06:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 09:53 PM
