Old 11-03-2016, 10:29 PM   #1
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Rewire an AT traction button into MT? Use traction toggle as an accessory?
So I've done a quick google search of the site and couldn't find anything really for what I'm looking for besides this thread:
http://www.ft86club.com/forums/showthread.php?p=2506276
I'm redoing my trim to be a piano black gloss and need to buy the black traction control buttons (MT). I remembered that the AT's buttons have the "Snow / Sport" toggle and wondered if there's a way to rewire these for some other purpose?
Someone mentioned that the AT module has a different connector so you'd have to repin the harness in the MT? I'm looking to use this later on as either an accessory toggle for something, or maybe if I get ECUTek use it for map switching.
Really I just want to know what I'll need to do to A) install this properly in a MT and B) wire it up to be used for something later on.
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 11-05-2016, 12:36 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Test it with a cheap LED strip. It is essentially a rocker switch so it would only send a signal while down, not a constant on/off style. I'm not sure on resistance lvls tho that's y I'd say test it with an LED strip. Cud prolly pick up a silver 1 cheap on eBay otherwise just useless buttons
lbroskee is offline   Reply With Quote
Old 11-05-2016, 02:19 PM   #3
norcalpb
norcalpb's Avatar
Is a rocker switch similar to a momentary switch? On my Audi I had a "funk" button (one way, momentary radio button) that controlled my radar detector.
Old 11-06-2016, 07:22 PM   #4
stevesnj
stevesnj's Avatar
http://www.beastronix.com/#products
My 2016 Build thread
Old 11-08-2016, 01:08 PM   #5
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Damn nice idea! I'm going to install air cups over the winter, so it'd be awesome to have them go up and down using those buttons...
Thanks for the idea! I'll start digging into it and post my findings
tato.valverde is offline   Reply With Quote
The Following 2 Users Say Thank You to tato.valverde For This Useful Post:
go_a_way1 (11-08-2016), The_Understated (11-08-2016)
Old 11-08-2016, 01:16 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^ Now that would be cool to see
Old 11-08-2016, 05:19 PM   #7
markitect
Drives: Scion FRS
I was thinking it would be cool to add buttons this way too. I bought a used AT set off someone, and was going to start looking at it soon. Just need to finish up my heated mirrors first.
markitect is offline   Reply With Quote
Old 11-08-2016, 07:03 PM   #8
lbroskee
lbroskee's Avatar
my mistake. i meant momentary, not rocker
Old 11-08-2016, 11:02 PM   #9
The_Understated
Hmmm if they're momentary that makes it more difficult.... Not sure what I'd use it for then. Though I'm still tempted to buy it for the extra $10 just to see if I want to use it for anything later.
Old 11-09-2016, 03:35 AM   #10
davmandave
Drives: 2016 Scion FRS, Pearl White, M/T
It should be pretty easy to use a relay to lock out the signal when you push the button. After all, most TVs use a momentary switch to power on and off.
ETA: I dug around on this issue, and found a StackExchange question like yours. It gets a little hairy, but they list chips that would work for what you want, which is to push a momentary switch and have it toggle a constant signal (like TVs and laptops).
http://electronics.stackexchange.com...ntrol-a-toggle
davmandave is offline   Reply With Quote
The Following 2 Users Say Thank You to davmandave For This Useful Post:
tato.valverde (11-09-2016), The_Understated (11-13-2016)
Old 11-13-2016, 03:07 PM   #11
The_Understated
Thanks for the link. I'll do some digging on the StackExchange forums and see what I can find. I'm thinking just a signal input to a relay should do the trick and eliminate the need for a digital processor. IE: press "snow" send signal to close relay for pin A, pressing again opens relay. Press "sport" closes relay for pin B, press again to open relay.
Old 11-15-2016, 07:20 AM   #12
davmandave
It would actually take more than one component to do this. You can lock the relay in an "ON" state with just a signal by running a cable between the "ON" output and the signal input. However, to turn it back off, you need a NAND gate to read if the relay is on, and the momentary switch is pressed. Also, you'll need an AND circuit to determine if you are allowed to turn the relay on (reading the NAND gate and momentary switch) This will allow the signal to be interrupted. You'll also need a monostable circuit right after the "snow" switch to prevent flip-flopping of the circuit.
All in all, it's probably a lot easier to just get the chip for around a nickel and play with some resistors to get it running. You might be able to sub in an Arduino or Raspberry Pi, and do it all in code. I can do more scratch pad diagrams later if you're still interested on building the electronics yourself.
Old 11-15-2016, 01:48 PM   #13
markitect
Drives: Scion FRS
I looked at the electrical wiring and checked the AT switch I bought. Here is the drawing of the connector.
Pin 2 has a LED flowing to Pin 3 for lighting
Pin 8 is ground, and All buttons tie low.
Pin 6 is Snow(AT only)
Pin 5 is VSC Off
Pin 4 is Sport(AT only)
Pin 1 is VSC Sport
It looks like it is a subaru connector, I'm going to try out 040-3 recepticals in it to see if they fit in the connector. Then any Tie Low button will work.
The Following 2 Users Say Thank You to markitect For This Useful Post:
tato.valverde (11-15-2016), The_Understated (11-15-2016)
Old 11-15-2016, 09:30 PM   #14
The_Understated
Attachment 146046
Pin 5 is VSC Off
Pin 1 is VSC Sport
Now you're stretching my electrical knowledge. Quick explanation?
Piano Black Dash Panel and Black Traction Control Button? stoneman155 Cosmetic Modification (Interior/Exterior/Lighting) 13 10-02-2015 11:09 PM
Traction - Where is it? TurboBRZ Engine, Exhaust, Transmission 63 07-25-2015 11:19 PM
Traction light came on for a sec. Josh Ehlert Issues | Warranty | Recalls / TSB 10 06-25-2015 03:47 AM
Traction Control & MPG Euro Engine, Exhaust, Transmission 21 10-04-2014 04:34 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
