Old 11-07-2016, 08:25 PM   #1
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
New clutch?
Hey guys, i'm getting an Edelbrock SC soon and i'm starting to look for a new clutch. What would you guys recommend? I'm looking for something similar to stock feel. I actually like my clutches very very loose and not tough at all to push down. I feel like i have more control. Is there a way to maintain that but have a stronger clutch that can handle the supercharger? Thanks for the help.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 11-07-2016, 10:19 PM   #2
Run your stock clutch. If you already have good technique I predict you will find it holds the extra torque just fine.
Change one thing at a time. Get used to the added torque. You'll have plenty of time to add extra friction if you still feel you need it.
BigFatFlip (11-13-2016)
Old 11-07-2016, 10:34 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Whatever you get, make sure to upgrade your clutch fork too
Old 11-08-2016, 01:17 AM   #4
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
You will really be fine on the stock clutch for a while. No reason to spend on the money right now anyways.
The Racers Line is offline   Reply With Quote
Old 11-08-2016, 01:44 PM   #5
Xxyion
Lowly Cartuber
Xxyion's Avatar
Ah ok. I thought it would be something i would be switching out soon. I'll keep researching clutches in the mean time and just wait till the OEM one wears out.
Old 11-08-2016, 01:57 PM   #6
The Racers Line
When yours goes, I already have the perfect setup. Did 10 of them in the past 2 months. ACT SB7-HDSS and a Velox Clutch fork, and you'll be set.
Old 11-08-2016, 02:36 PM   #7
Xxyion
Lowly Cartuber
Xxyion's Avatar
Neal...you are too awesome for words. But i only have words so...awesome
The Following User Says Thank You to Xxyion For This Useful Post:
The Racers Line (11-08-2016)
Old 11-08-2016, 02:41 PM   #8
Amputechture
Drives: 2014 BRZ
Will you be running the CARB trim///pump gas///or in other words a "mild" setup? If so, the factory clutch is more than enough to handle it. I'm at 297 whp/238 wtq on a turbo setup and have been fine.
Amputechture is offline   Reply With Quote
Old 11-08-2016, 03:52 PM   #9
Xxyion
Lowly Cartuber
Xxyion's Avatar
Gonna run the more agressive Delicious Tune till my 6th year and then switching it out for the CARB tune.
Old 11-08-2016, 04:12 PM   #10
shellslinger
Drives: Whiteout FRS
Don't know if this is going to help you but I'm running Exedy Stage 1 Clutch on a pretty much stock engine and the clutch feels very similar to stock.
shellslinger is offline   Reply With Quote
Old 11-08-2016, 04:52 PM   #11
Amputechture
Drives: 2014 BRZ
Can I ask what you mean by 6th year? Shellslinger-I plan on switching to the Exedy Stage 1 once my factory clutch takes a shit. PTuning and others have pushed wtq in the high 200's with a Stage 1.
Old 11-08-2016, 06:49 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
California does not emissions test a new car until 6 years after it's been sold to the original owner. After that it is tested once every 2 years.
No 86's will see emissions testing in California until the summer of 2018, not including a couple of special situations.
Expect to see a flood of people selling their catless headers and turbo kits in 2-3 years desperate to get their money back
ineedyourdiddly
menikmati (11-08-2016)
Old 11-08-2016, 07:37 PM   #13
Amputechture
Drives: 2014 BRZ
Ahh...commie state, gotcha. Can't you just flash to the Carb approved tune temporarily, prior to inspection?
Old 11-08-2016, 08:25 PM   #14
Xxyion
Lowly Cartuber
Xxyion's Avatar
Also have to remove my front pipe and headers. but yeah thats the idea. Gonna remove those and go back to stock. Flash with CARB tune then put it ALL back on for two more years.
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
