Old 11-03-2016, 01:15 PM   #491
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by wbradley View Post
Just get a smaller pulley.
I don't want to over spin this blower. This is the limit of the V2 kit, as I know it, unless there is a pulley / restrictor combination to make 12-13psi and not over spin.
HKS USA refused to give me any information regarding pulleys for the V2 Kit also
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-03-2016, 02:21 PM   #492
wbradley
Sarcastic SOB
wbradley's Avatar
Aside from 1 bolt pulley vs the 5 bolt on the V1, I didn't think there was any internal difference in the GTS7040L unit.
I am staying at the 100 mm pulley and super safe. If the plan was for huge power would have gone a different route. As it is on days where startup temps are cool enough that it takes 10 minutes for the coolant gauge to centre the needle, I get a squeal from the supercharger as I accelerate. It stops when the temps are high enough I presume, for the traction oil. That is usually the same time the coolant is fully warmed.
Old 11-04-2016, 11:42 AM   #493
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Is there any info on issues with the V3 as of yet? How many people have been running them and what mileage have you put on them thus far?
Sent from my SM-G920T using Tapatalk
Anderzz is offline   Reply With Quote
Old 11-08-2016, 10:16 AM   #494
empower-auto
Kouki-Monster
One day. One day, HKS USA, will eventually offer me some support for this product. We're going on 2 years soon but dammit I will win!
Rich Anderson
EMPOWER AUTO
Old 11-08-2016, 10:31 AM   #495
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
I'm not sure what kind of support you are seeking, but I'll gladly answer anything I can. What support is it we're not providing you?
Torry@HKSUSA is offline   Reply With Quote
Old 11-08-2016, 04:40 PM   #496
johl
johl's Avatar
Drives: toyota 86
Does anyone have pics of a v3 kit powder coated black?
Also any recommendations for clutch upgrade with this kit? I want to stick to jdm brands. I just want to future proof my car so although initially I can get away with the stock clutch I would like to change it while I'm installing everything else. I think the stock pedal feel is too light so ideally would like it to feel heavier however I drive everyday but rarely in congested traffic.
Any help would be appreciated.
johl is offline   Reply With Quote
The Following User Says Thank You to johl For This Useful Post:
zeal86 (11-08-2016)
Old 11-08-2016, 04:49 PM   #497
wbradley
Sarcastic SOB
wbradley's Avatar
At the power level and with the torque curve with regular pulley/fueling you really don't NEED a stronger clutch. At least not for some time anyway.
The Following User Says Thank You to wbradley For This Useful Post:
Kylebrz (11-13-2016)
Old 11-08-2016, 05:13 PM   #498
johl
johl's Avatar
Drives: toyota 86
I should be fine for at least 12 months but with my work schedule I can't guarantee a week to have my car off the road to upgrade my clutch. So in my circumstances it makes more sense to change it while doing everything else and never have to think about it again
Old 11-08-2016, 10:12 PM   #499
wbradley
Sarcastic SOB
wbradley's Avatar
OK It's good for the local economy, I guess. The stock clutch seems to handle my setup with no signs of deterioration. Once at the 300 WHP level or higher it's pretty inevitable the clutch will go prematurely. Canada and Australia prices are probably pretty close. Expect over $1000 for a replacement possibly excluding labour.
Old 11-09-2016, 08:26 AM   #500
Torry@HKSUSA
Drives: HKS
If you have any interest in sticking with HKS, we do offer a clutch kit for the BRZ/FR-S: http://www.hksusa.com/2013-2015-brz-...on-clutch-kit/
The Following 2 Users Say Thank You to Torry@HKSUSA For This Useful Post:
johl (11-09-2016), zeal86 (11-09-2016)
Old 11-09-2016, 12:34 PM   #501
empower-auto
Kouki-Monster
I'll try to put it in brief.. it may not be that brief.
When I called HKS USA, I was running a Version 2 kit with the restrictor bored out to 43mm. I was making 9psi peak and was trying to get some info about the next step.
I asked if there was any data of what to expect for boost with the restrictor removed. I asked what was required to run approx 13psi, and I also asked if I was risking over-spinning the blower.
I also asked that in the event simply removing the restrictor didn't provide the results I wanted -- what the next step would be. Could I purchase a different pulley? Would it be advisable to run the new pulley and put the restrictor back in? So on etc
The response I got was, that of someone completely uninterested in what I was doing and just wanting to sell me a V3 upgrade kit. He explain the V2 being discontinued, not supported, and tried to tell me to just get the V3 kit. When I asked why and what I could gain from it, just vague answers and no figures.
I was also (wrongly) told that removing my inlet restrictor would "not do anything at all" "you need to buy a different pulley" "just get the V3 upgrade kit" and then he referred me to the wrong pulley. I was linked to a V3 kit pulley. I also asked which size pulley I'd need for my goal and he had no idea.
So -- that's pretty frustrating. I had one of the first V2 kits in the country here and my car is also a rolling HKS bill-board .. we've got HKS product on the shelf here etc
I'm currently still running the V2 with upgraded injectors and pump. It's running a peak of 11psi with the restrictor out. The powerband is way to peaky for me so I'm looking to change it up.
Rich Anderson
EMPOWER AUTO
The Following User Says Thank You to empower-auto For This Useful Post:
Efferalgan (01-17-2017)
Old 11-09-2016, 01:37 PM   #502
Torry@HKSUSA
Drives: HKS
To answer your questions:
You can get more power by removing the restrictor plate, but we don't have data on how much more because it's not something we've tested.
There is no pulley upgrade for the V2 kit since it uses a single bolt pulley. My suggestion would be to get the V3 upgrade kit, which will convert it to a 5-bolt pulley. Also, you get a larger inlet pipe that does not use a restrictor. The pulley is larger (110mm), but because of the larger diameter inlet pipe and no restrictor, it actually makes more power at less boost, because the intake temperature is so much cooler. This is because the supercharger doesn't have to work as hard to pull air in with the larger inlet pipe.
If that's still not enough power for you, you can then get the V3 upgrade kit that includes a 100mm pulley (5-bolt) which should put you up around 8 or 9psi. That might be about the same as what you're currently seeing, or maybe even less, but again, you should be making much more power because the intake temp will be much cooler than what it is on your V2 kit.
The V2 > V3 Upgrade Kit is part number 12002-KK002. It's not on our website, but any HKS Pro Dealer would be able to order this for you. It's $780.
Then if you want the upgraded pulley for the V3 kit, it's $360. (12002-KK001)
Old 11-09-2016, 01:45 PM   #503
HuntingtonFRS
Drives: 2013 Scion FR-S in White
And then you will need fuel injectors and fuel pump. Don't forget the spark plugs if you haven't already changed them (should have been done with the supercharger)
HuntingtonFRS is offline   Reply With Quote
Old 11-09-2016, 03:22 PM   #504
empower-auto
Kouki-Monster
Pump and Port Injectors are done. OEM plugs are fine.
But I am running HKS plugs at the same heat range as oem (9)
Rich Anderson
EMPOWER AUTO
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
