Old 11-06-2016, 12:15 PM   #29
Norinradd
Drives: 2013 frs
What aboutthis step. I dont get it. Name:  IMG_7029.JPG
Level with what!?!
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-06-2016, 12:18 PM   #30
Norinradd
Drives: 2013 frs
Is that essentially. Leaving the bolts loose and putting tires on. Putting car on ground and then fonishing torquing bolts. I assum thats what leveling the arm is mimicing
Old 11-06-2016, 12:23 PM   #31
cjd
cjd's Avatar
Drives: 2017 BRZ
Level means level... Not sure what you don't understand. Perpendicular to gravitational pull. Its an absolute measurement. The car should be raised so its level as well, as best you can.
The Following User Says Thank You to cjd For This Useful Post:
wparsons (11-07-2016)
Old 11-06-2016, 12:26 PM   #32
cjd
cjd's Avatar
Drives: 2017 BRZ
Not necessarily. A level driveshaft (not arm!) may not be the same as static rest position, and with tires on you need to roll the car or it won't settle right/evenly.
Old 11-06-2016, 01:03 PM   #33
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I googled your location. Looks like there are several speed shops around that could help.
The Following User Says Thank You to Summerwolf For This Useful Post:
wparsons (11-06-2016)
Old 11-06-2016, 07:48 PM   #34
Norinradd
Drives: 2013 frs
Yah i noticed it was friveshaft and not arm. Re did rears today. With proper spring placement. Seems to be a little better
Old 11-06-2016, 07:49 PM   #35
Norinradd
Drives: 2013 frs
Not really? There are two tuner style shops. One claims u dont need to tune an frs after installing headers exhiast and intake. Even if youre throwing cel and idling weird. The other doesnt do chassis. Theres one good alignment shop in the whole province. Ill be going there this week
Old 11-06-2016, 07:55 PM   #36
Summerwolf
Panda Trueno
Summerwolf's Avatar
Idk, but you probably need some eyes on help at this point and just get someone to fix it. Good luck.
Old 11-06-2016, 08:24 PM   #37
wparsons
wparsons's Avatar
I highly doubt there's only one good alignment shop in all of BC... I'd suggest talking to some local racers to see where they go.
flickr
Old 11-06-2016, 09:43 PM   #38
Norinradd
Drives: 2013 frs
Only one i know of. I phoned best tuner shop in bc yesterday and he said same thing
Old 11-06-2016, 10:53 PM   #39
Norinradd
Drives: 2013 frs
Pretty much i guess to be straighforqard i seek the cheapest way to 1 degree of variance in rear and 1.5 degree upfromt. Whitelines for front, put bottom bolt up top? Im only 3.6mm closer to suspension than stock setup with my tire and rim now. Will i need something to not hit suspension?
And spc lrcs is cheapest route for atleast 1 defgree in the rear?
Old 11-07-2016, 01:10 PM   #40
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by mav1178 View Post
1) are you 100% sure your springs properly installed?
2) are you 100% sure there's no accidents or bent suspension components on the car?
3) cheapest option is to slot rear lower control arm. next cheapest is SPC rear lower control arm.
I'm just going to quote myself here for you to review.
If you want cheap, the options are listed here.
-alex
Old 11-07-2016, 07:56 PM   #41
Norinradd
Drives: 2013 frs
All is good! Camber is at -1.7 and -2.0. Always get a second alignment if things arent making sense i guess!!
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs customfab87 Brakes, Suspension, Chassis 0 02-08-2016 10:41 PM
Fitment with -2 Camber and 1" Drop 18x9.5? ajcarson11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-26-2015 01:29 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
