Old 11-04-2016, 09:19 AM   #3767
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Originally Posted by Reamer View Post
Attachment 145464
Got a date with PRT Performance for the 17th, doing prep work for the JRSC.
Sent from my HTC 10 using Tapatalk
My car will be in on the 15th.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 11-06-2016, 01:08 AM   #3768
arren123
Drives: 2013 BRZ (RIP), now 2017 BRZ
Hey, I finally joined the club and install the C38 on my BRZ, but ran into a small issue.
For those who have the C38 and fog lights, did you have issues with the tube on the driver side of the intercooler?
No matter how I positioned it, the tube ended up in contact with the fog light area of the bumper and now I have the dreaded bumper gap. Any tips on how to position it?
arren123 is offline   Reply With Quote
Old 11-06-2016, 11:41 AM   #3769
PMok
Codename: Stitch
PMok's Avatar
Originally Posted by SoCalArgento View Post
Ah I see I was mostly curious as to how complex installation would be. I'll call up my local shop
I had wondered the same so I went on YouTube and found an install video for the P3 vent gauge ... it was an hour long and the guy was swearing the whole time haha. After that and knowing my own (lack of) skill and patience I decided to leave it to the pros LOL.
Old 11-06-2016, 02:42 PM   #3770
Bramick
Bramick's Avatar
I saved myself the grief and ordered the Ptuning washer fluid reservoir. Now there's plenty of room.
Old 11-07-2016, 01:36 AM   #3771
VABeachBRZ
Yeah I have the gap on the drivers side as well.. can't seem to make it fit.
VABeachBRZ is offline   Reply With Quote
Old 11-07-2016, 07:47 AM   #3772
arren123
Thanks! This morning when I was thinking about it and doing research, it looks like other people have deleted the washer fluid reservoir. Then I remembered the pipe hitting the reservoir.
I think I will go the Ptuning route. Will do a google search. Hopefully it'll take care of the gap. Thanks!
Old 11-07-2016, 08:17 AM   #3773
arren123
Oh one more thing. In the instructions Page 6, step 11, it said to
"Reroute the valve cover hose from the passenger side of the A/C compressor to the driver side. Route the hose below the A/C
compressor and behind the oil filter and the oil filler neck."
I actually unbolted the A/C compressor and routed it underneath the compressor and bolted the A/C compressor on top of the hose.
This results in a severe 90 degree bend in the hose, although air was still able to flow through it when I blew air into it.
Did I do this step wrong?
When i tried to route the hose around the rear mounting bolt of the a/c compressor, it didn't seem like there was enough hose to bring it around the oil filler neck like in the picture.
Old 11-07-2016, 12:10 PM   #3774
CSG Mike
CSG Mike's Avatar
There is enough hose to do it, when you pull it through.
If the air can freely flow through the hose, then your alternate routing is okay.
Old 11-07-2016, 01:27 PM   #3775
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
@SoCalArgento it's actually not too bad. You pop off the vent and swap yours with the gauge. The rest of it is just plugging into the obd port and the green wire to your parking lights. I'm sure there is a thread on installing it somewhere which is probably what I used to do it.
phanguy is offline   Reply With Quote
Old 11-07-2016, 01:57 PM   #3776
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I already have a hunch on which video you saw. I'll tell you this: ALL of his install videos are like that.
menikmati is offline   Reply With Quote
Old 11-07-2016, 03:01 PM   #3777
PMok
Codename: Stitch
PMok's Avatar
I think it's definitely easier if you buy the replacement vent pod from P3cars with the gauge already installed in it. The tricky part seems to be taking apart your own vent pod if you didn't buy the replacement, I could see myself using too much force and breaking some plastic bits if you're not careful. That kind of thing happens to me whenever I work on cars...
Old 11-07-2016, 04:43 PM   #3778
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Congratulations on your JR system!
If you adjust the tube and hose correctly, you will clear everything in the front end. It is tight, but the bumper will fit properly.
Jackson Racing is offline   Reply With Quote
Old 11-09-2016, 04:01 AM   #3779
phanguy
phanguy's Avatar
I bought mine used without the whole replacement pods. Just went slow and was careful. I've been taking things apart for a long time though so maybe I'm just a bit adept at it :P
Old 11-11-2016, 01:03 PM   #3780
klear
Drives: 2002 V7 Bugeye STI/2014 BRZ limited
Is this the kit to get for a car that sees regular track use? My biggest worry is the heat problems with forced induction and I keep coming back to this kit.
klear is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
