| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1961 |
#1962 |
Drives: 2014 FR-S
#1963 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
You could be right, I have -2 degrees camber in front although fitted fine even before then. But, with +45 offset. With +38 that many people run I think I would have had issues.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#1964 | |
Drives: Subaru BRZ 2017 (almost)
Sent from my Nexus 6P using Tapatalk |
#1965 |
Drives: 2013 Subaru BRZ
![]() ![]() Fitted 17x9+35 Rpf1 with 245/40 tires. Not the meatiest tire but I'd like to show that I'm able to fit somewhat meaty tires on stock body with pbm angle kit 😁. Sent from my iPhone using Tapatalk
PBM angle kit, PBM coilovers, PBM RLCA, Tomei 2way diff, Hydraulic Ebrake, Bride Seat, Schorth harness.
#1966 |
That's a good look! Is it the PBM kit that gives it such a wide track?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| The Following User Says Thank You to 15limited For This Useful Post: | Allan13 (10-25-2016) |
#1967 | |
Thanks! Yes the adjustable LCA from pbm lets you adjust track width 😁. Sent from my iPhone using Tapatalk
#1968 |
Drives: FR-S 10 series
mas protein
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 Last edited by mmmcambelsoup; 11-04-2016 at 10:08 AM. |
#1969 |
There is no MPSS or ExtremeContract DW in 255/35 available in Australia. Should I go 245/35 or 255/40? I don't want to go 265 since it's just too much tyre for the power of the car. I want to fill the fender as much as possible..
EDIT: I'm probably going 265/35 with rear arms. Dealer suggesting Cusco and says its super easy when i mentioned it is apparently a pain to setup/adjust..and cannot find SPC in Australia lol. Last edited by nima314; 11-04-2016 at 09:33 PM. |
#1970 | |
#1971 |
18x9.5" +38. I would probably need them with that offset. I am thinking of buying SPC directly from FT86 SF depending on their response to how long it will take to arrive here in Australia.
#1972 |
Agreed, you'll likely have fender rubbing without some extra rear camber
| The Following User Says Thank You to nzer For This Useful Post: | nima314 (11-04-2016) |
#1973 |
#1974 |
Drives: 2014 FR-S
None, i only have ST coilovers, natural camber in the rear from the drop and a little camber up front to tuck the tires in.. ill take some more shots tomorrow
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
