#407 | |
Drives: 2018 Miata RF, 2017 Golf R
What I was pointing out though is the sheer inertia that FT86 enthusiasts are working against when they go on and on about a hotter version. |
| The Following 3 Users Say Thank You to unhappymeal For This Useful Post: |
#408 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
As I said before, now I will show my work
I'm not one to suffer much from CDS, (Can't Do Sh*t). So I immediately took my SM, (smoothed map) Requested Torque B map, and started adding more throttle in the low end, and taking away some throttle in the higher end. Here are pics of the OTS map, the SM map, and the BRUT4S, (Brute Force) map I've ended up with. As you can see from the pics, the BRUT4S map is quite different than the OTS map. The comparisons are equally revealing. The SM map is only slightly different than the OTS map, while the BRUT4S map is over a hundred points higher at 10% throttle! Now it drives like a sports car should.
If I say yes, will that make you think I understand?
#409 | |
#410 |
Bullsh**. The OEM is already using a different FD. I'm here to say that everyone that says this car has no low end torque is wrong. The OEM has set it up that way. My opinion is that they are wrong to do so. A Corolla has more low end torque than this car. They can do the same thing with this car as they've done with the Corolla.
#411 | |
#412 |
You are certainly entitled to "your opinion". Do you have anything to back that up? Because I actually back up "my opinion" with real pics of real tables, that I have really driven with in my real car.
#413 |
Yeah, colorful. I have plenty to back it up. I didn't post for your benefit. I posted for everyone else that may be seduced by your pretty charts.
#414 | |
I've mentioned both Final Drive and drive-by-wire specifically because neither mod changes the actual amount of horsepower the car puts down, but instead, each mod increases the power felt by the driver. Now, what is the most common complaint buyers and reviewers have about this car? That it doesn't have enough power. Not only are these two changes doable by the OEM, but they are already being done by the OEM. It is "my opinion" that they just aren't taking it far enough.
#415 |
Holy shit. Wow. Did you actually read the post you quoted? "list of reasons that could fill a book."
I'll up the ante and correct Tcoat. Should read "list of reasons that fill a book."
| The Following User Says Thank You to Ultramaroon For This Useful Post: | why? (11-07-2016) |
#416 | ||||||||||
Drives: 2015 Series.Blue
![]() Quote:
Focus sells like hotcakes. Mazdaspeed Miata was killed. Civic sells like hotcakes. 300ZX was a halo car and the height of the Japanese sports cars. Mustang sells like hot cakes. STI is a halo car. Golf sells like hot cakes. Corvette is a halo car. The twins are a low volume mid range car. The money simply isn't there and it can't compete with the higher range or you affect brand image. Quote:
In essense you're do the inverse of putting a piece of wood under the gas pedal. Quote:
![]() Quote:
Want to see the advertising direction that they should have gone? Look no further than the Miata. [ame="https://www.youtube.com/watch?v=t5UjmHOl4pU"]A Driver’s Life – Driving Matters™ | 2016 Mazda MX-5 Miata| Mazda USA - YouTube[/ame] It's a pure masterpiece and goes after the emotions, the same emotions that drive people to buy a sports car in the first place. |
| The Following 4 Users Say Thank You to Poodles For This Useful Post: |
#417 |
Drives: 15 ZN6 Asphalt
Funny that video Mazda made was a big swipe at Tesla.
2015 ZN6 DD AT
#418 | |
Your techno babble with no true grasp of the true function of the throttle and fuel/air mixture is amusing. You think the throttle has nothing to do with how much gas is injected and just controls air flow? That is hilarious. Increases the "power" felt by the driver? Oh that is a good one. You had better get an email off to the manufacturers right away and explain that you have discovered something they are overlooking and that they can do with no problem. Make sure you send all your testing records to prove that your butt dyno is fully calibrated and up to the current ISO test standards. I am sure they will pay you millions for saving them so much trouble. I guess I am wasting my time with you again since your incredible ability to take one aspect of a system and run with it while totally disregarding all the other factors is truly mind boggling.
| The Following User Says Thank You to Tcoat For This Useful Post: | mrg666 (11-06-2016) |
#419 |
Several books actually. To the best of my memory there are currently at least 800 ISO standards that apply to the testing requirements and protocols for cars and their component parts. That is just one standard of several dozen that apply. Then we can get into the reams of regulatory requirements. They would fill another volume. These asshats that think that the manufacturers can just do whatever they want have no bloody clue the reality of what the industry deals with.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#420 |
Yeah, mine was a whopper of an understatement.
| Stupid? Or Cool? I'm too old to know | FNCrazy | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 08-03-2016 10:59 AM |
| Does This Look Stupid? | FNCrazy | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-24-2016 10:54 PM |
| Help stupid iphone | Atticus808 | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 01-19-2015 10:53 PM |
| stupid question about brz | andrewmay9 | BRZ First-Gen (2012+) — General Topics | 55 | 05-17-2014 03:10 AM |
| stupid deer | balla_08 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 12-14-2013 05:23 PM |
