Old 11-02-2016, 12:14 AM   #1
Coaster
Coaster's Avatar
Drives: Civic
brake expert help please
Ebc Greenstuff pads were put on a honda fit fr wheels. A wurring noise appeared after this at 30 or greater mph from fr wheel. Louder on highway. Very very high level of brake dust present. I'd clean wheels and in a week wheel coverd by dust. Tech couldn't find cause. I had new rotors installed and sound diminished a little. Braked pads showed uneven wear. Now tech said its likely pads. 2 months of this.
And tires are brand new.
Please help me.
Thanks.
Coaster is offline   Reply With Quote
Old 11-02-2016, 12:45 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What kind of "tech" are we talking about? Cause any mechanic, and I will tell you it's a stuck caliper.
Either get the rebuild kit, or swap out calipers. Any brake shop would do both. The rebuild kit would cost less.
The cheaper fix, swap out brake pads. Any pads would do, it's really just to rule out the stuck caliper or shit ebc pads. If you get more dust on the same wheel, then it's a stuck caliper.
Old 11-02-2016, 10:14 AM   #3
snidd111
snidd111's Avatar
Drives: Scion FR-S
I agree with the stuck caliper piston. You should pull the caliper and see if the pistons can be compressed properly. Then with that caliper still off, press the brake a few times to see if the pistons are moving like they should. You'll need to compress them again after to get them back over the rotor and pads.
You'll need new pads on that side either way it sounds like.
snidd111 is offline   Reply With Quote
Old 11-02-2016, 10:34 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Probably a stuck caliper. Uneven pad wear and huge amounts of dust....
Old 11-02-2016, 10:38 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
#totaled
Toyarzee (11-02-2016)
Old 11-02-2016, 02:01 PM   #6
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
More information about the car would be helpful (and essential, IMO).
Could be as simple as a stuck caliper slide. I don't think he has a stuck caliper rubbing against the rotor - as that could result in total braking failure by overheating the brake fluid.
After a drive with moderate braking, check the brake temps of each corner of the car. If one is stuck you should be able to tell a difference in heat output just by holding your hand right by the hub. Or you could use an infared thermometer gun (they're less than $15).
Old 11-02-2016, 04:44 PM   #7
Coaster
Coaster's Avatar
Drives: Civic
Thanks for the replies.
By "tech" I mean mechanic.
After replacing the rotor and still hearing the noise I was almost sure it was a stuck caliper. Others told me the same thing as well. So yesterday I had the mechanic check the calipers and rotors. All were good though.
The car is an 09 honda fit sport with 83,000 miles.
I was going to order the new Stoptech sport pads. But I may just have the mechanic just install some regular pads though.
Any more info that I can provide?
Old 11-03-2016, 12:36 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Which pad is more worn? you can easily check for a stuck caliper. I know your mechanic said it was fine, but unless you installed something incorrectly this is going to be a stuck caliper or similar issue.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Coaster (11-04-2016), Summerwolf (11-03-2016)
Old 11-03-2016, 07:06 PM   #9
Coaster
Coaster's Avatar
Drives: Civic
Not sure. He didn't specify.
Gonna say both are pretty bad since both wheels have plenty dust.
How can I test to see if it is a stuck caliper?
Old 11-03-2016, 10:49 PM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
The quick and easy way is with a temp gun. As with a stuck caliper the rotor would get hot because of the constant pad contact.
So take a 5-10 min drive do some above average braking. Come back and take temps of the rotors. You'll notice a higher number on the one that is stuck.
The long way, jack the car up have some one pump the brakes, then use feeler gauges. And yes there is specs on how far the pad and rotor must be. You'll have to see the repair manual for that one. I can't call it up from the top of my head.
The Following User Says Thank You to Mr.ac For This Useful Post:
╬╬ WILWOOD Big Brake Kits ╬╬ Free Shipping - Expert Advice - Photos and more... FT-86 SpeedFactory Brakes, Suspension, Chassis 186 04-25-2016 02:28 AM
need your guys expert help! MontrealFRS Scion FR-S / Toyota 86 GT86 General Forum 31 01-21-2013 04:43 PM
Need Expert on Retrofit !! Ericfrs Cosmetic Modification (Interior/Exterior/Lighting) 3 07-22-2012 01:22 PM
