Old 10-30-2016, 09:50 PM   #29
Lantana frs
Drives: 13 frs red
Anyone remember the dsport intake test? They never showed an overlay of the tuned stock vs tuned for intake. Peak gains were small unless you compared to stock untuned. So it goes with alot of the aftermarket bullshit.
Lantana frs is offline   Reply With Quote
Old 10-30-2016, 09:56 PM   #30
Hawk77FT
Drives: GTS 86
Originally Posted by Spartarus View Post
He's not using the factory intake manifold.
His throttle body is feeding the intake elbow of the Sprintex 335 Supercharger.
How about on the NA car?
Hawk77FT is offline   Reply With Quote
Old 10-31-2016, 12:43 AM   #31
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Honestly, no tricks, matched AFR's and timing...
Zip. Zero. Nada.
Its just not a restriction for NA. The engine in NA form can't ingest enough air to choke on the stock throttle body with the stock cams.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
JDM4E (10-31-2016)
Old 10-31-2016, 04:37 AM   #32
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Lantana frs View Post
You can't compare tuned vs untuned.
Good points but when I see that a car has been tuned I have to wonder how much of the gain is attributable to the component being tested.
Originally Posted by Irace86 View Post
I don't think the stock throttle body is a restriction unless he is pushing huge numbers. Do a google search for what people are making in terms of power and what type of numbers they are running at the drag strip or in competition, and you will likely find some pretty high hp cars running 65mm throttle bodies without issues. 2jzgte stock TB is 65mm ID, and Supras/cars with single turbo 2jz's are pushing huge numbers without aftermarket intake mani/TB combos.
Maybe the point of restriction is in the air flow path of the top mount blowers. Maybe that is why the Edelbrock, Harrop and Cosworth units put the manifold on top.
Originally Posted by Kodename47 View Post
Probably because no one will fork out large amounts of money and then post up that it made no difference and not many people will pay to do something that they don't expect to work
1
Zip. Zero. Nada.
It is true that not many have changed the throttle body, but the few who did it they said there were noticeable gains. I believe a tune is necessary to get most of it, because you change something after the MAF reading. So, you need at least to reprogram the MAF and for something more extreme also the red line. If someone changes the AFRs and the timing, then I agree that the gains cannot be attributed to the bigger throttle body.
Additionally, noone said that we have a restriction with the stock throttle body. This not how things work. You're just trying to push more air and if you manage it, then the engine will compensate and will add more fuel. This is how FI works and this is a way to done it if you want to stay NA. If the throttle body wasn't that important in the overal air flow channel, please explain to me why Subaru is using a tapered design? OEM specifications is 71mm in the inflow side and 65mm in the outflow side. I suppose that you understand of what is happening with the air flow when you have a tapered design.
Old 10-31-2016, 08:00 AM   #33
Kodename47
Kodename47's Avatar
Drives: UK GT86
A bigger TB will increase response if the angle mapping isn't changed. You would definitely feel an "improvement" but then this is no different to the throttle mapping gizmos or just remapping the throttle. You're not adding power but just merely increasing the airflow per degree of accelerator pedal movement.
NA you will not be pushing more air in. The engine works as an air pump drawing the air through the TB, hence the wording of a restriction. The reason it is tapered is to increase air velocity so it carries that through the manifold and ports. If the TB is too large you can actually reduce velocity and less air arrives in the cylinder before the valves close. You really should be looking at pressure changes either side of the throttle plate. If there are none then there will be no performance increase of a larger opening.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 5 Users Say Thank You to Kodename47 For This Useful Post:
Decay107 (10-31-2016), Hawk77FT (10-31-2016), johan (11-01-2016), Spartarus (10-31-2016), wparsons (11-09-2016)
Old 10-31-2016, 10:49 AM   #34
Spartarus
...Just add nauseum
Spartarus's Avatar
Aww man the damn thank button went away... I only pressed it once!
...And that's why I don't have a dial-up throttle anymore.
-Spartarus
Old 11-01-2016, 04:32 PM   #35
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Are you maxed out on pulley size? Meaning, couldn't you just buy a smaller pulley? Wouldn't that be the cheapest route?
I will be shortly...
DIE1000DEATHS is offline   Reply With Quote
Old 11-01-2016, 04:56 PM   #36
DIE1000DEATHS
TechNINJA
Much appreciation to you sir for reading my posts and the effort in yours!
That Grams must've just hit the market. I did a bit of searching before making this thread.
The car won't get driven in the shitty Michigan winter, so I'll likely get the Grams and will try to do a proper write-up with dyno comparison.
For those who TLR, OP is using a Sprintex 335 supercharger. The big one. On a built engine.
The 335 hits a ceiling long before you max out the blower.
There's a point of diminishing returns with smaller pulleys that shouldn't be there.
Somewhere in the system there's a significant restriction.
The popular speculation points to the throttle body.
Other speculation points to the Laminova intercoooler core.
But he's on a Sprintex 335, it doesn't use the stock intake manifold. The Sprintex manifold has its own runners of different length and diameter than stock.
Sure you can, you've just got to leave ignition timing alone. If you only correct the tuning to match AFR's between the 2 setups, that's exactly how you correctly compare.
I would try the Grams one from SpeedFactory if I were OP.
The Following 3 Users Say Thank You to DIE1000DEATHS For This Useful Post:
Hostile_Kittens (11-02-2016), nikitopo (11-09-2016), Spartarus (11-01-2016)
Old 11-01-2016, 06:44 PM   #37
johan
Drives: '14 981CS, '99 NB1
Just as a matter of my own experience in the past... Grams/Skunk2/Kraftwerks (all same company, same manufacturing - Group A Autosports).... their DBW throttle bodies have a long, consistent history of sticking closed and being very unreliable. --- maybe --- they've made progress there and it's not an issue anymore -- but I would proceed with caution.
I would highly recommend exploring OEM Subaru/Toyota/Honda options - that's why I did that Honda test last year. There are a large number of OEM keihin manufactured TB's out there from Honda V6s that could be made to work with a little effort. There is supposedly even one giant Lexus TB that is plug and play...
johan is offline   Reply With Quote
The Following 3 Users Say Thank You to johan For This Useful Post:
DIE1000DEATHS (11-08-2016), Hawk77FT (11-01-2016), Hostile_Kittens (11-02-2016)
Old 11-01-2016, 08:33 PM   #38
Turdinator
Señor Member
Turdinator's Avatar
OP, if you are still look at options TODA make a nice looking one. I have no personal experience with it but the TODA parts I have used on past cars have been quality items.
http://www.toda-racing.co.jp/en/prod...-throttle.html
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 11-01-2016, 08:54 PM   #39
Hawk77FT
Drives: GTS 86
Might as well bore the stock TB for quarter of the price. I have done mine up to 68-69 with no problems.
The Following 2 Users Say Thank You to Hawk77FT For This Useful Post:
DIE1000DEATHS (11-08-2016), Turdinator (11-01-2016)
Old 11-01-2016, 11:11 PM   #40
justinh77
justinh77's Avatar
Drives: pearl white scion frs 2014
i look forward to your write up and dyno charts on the grams im considering it myself as well
justinh77 is offline   Reply With Quote
The Following 2 Users Say Thank You to justinh77 For This Useful Post:
DIE1000DEATHS (11-08-2016), nikitopo (11-09-2016)
Old 11-02-2016, 10:26 PM   #41
Teseo
Drives: frs
Or this is enough?
Old 11-03-2016, 02:24 AM   #42
quinceyc
Originally Posted by Teseo View Post
Or this is enough?
Is this TMG custom made one off intake??
quinceyc is offline   Reply With Quote
WTB: FA20/4U-GSE Throttle body Simply_the_best Want-To-Buy Requests 1 01-11-2016 03:02 PM
WTB FRS/BRZ Throttle Body Tboxer Want-To-Buy Requests 3 12-01-2014 12:13 PM
WTB: OEM fa20 Throttle Body 1stGenBRZ86 Want-To-Buy Requests 0 01-28-2014 02:51 AM
