Old 10-20-2016, 02:21 PM   #449
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Originally Posted by BRZyJ View Post
@BRZyJ Dude, ELT. Nice.
Pointmutation is offline   Reply With Quote
Old 10-20-2016, 03:00 PM   #450
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
BRZyJ is offline   Reply With Quote
Old 10-21-2016, 01:47 PM   #451
metalmoses
metalmoses's Avatar
Drives: 2013 Scion FR-S Firestorm MT
I just ordered one of these units on Amazon for $279, I picked up all the adapters as well. I'll share some pictures upon completing the install.
Parts List: Perrin CAI + Borla UEL Header + Perrin Overpipe + Invidia Front Pipe w/ High-Flow Catalytic Converter + FT-86 SpeedFactory V1 Exhaust + 10k HID's + Eibach Sportsline Springs + TRD Spoiler + Rear Diffuser + Rear Spats + OFT Stage 2 Tune +18" Enkei Black Raijin Wheels (18x8 +45 up front 18x9.5 +45 in rear) Tire Specs: 235/40R18 in the front, 265/35R18 in the rear
metalmoses is offline   Reply With Quote
Old 10-21-2016, 03:06 PM   #452
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Wow disabling of Google App and Play Services helps a ton. And Maps still works fine.
Only issue with the phone now is the mic , I have put it behind the steering wheel but there still a ton of noise on the other side.
shadoken is offline   Reply With Quote
The Following User Says Thank You to shadoken For This Useful Post:
Yoshoobaroo (10-21-2016)
Old 10-29-2016, 10:44 PM   #453
FrostyPaws
FrostyPaws's Avatar
Drives: Blue Monogram FRS
Hey guys, I just wondering, has anyone been able to figure out running netflix? I keep getting error (0013). I purchased the joying JY-TL123 from Amazon. Spent time getting the bluetooth dongle to communicate with torque but finally got it connected. Like most folks have already said this is a great unit, especially after flashing malaysk's rom.
FrostyPaws is offline   Reply With Quote
Old 10-29-2016, 11:52 PM   #454
BRZyJ
BRZyJ's Avatar
According to the dude at the end of this thread that's a known issue with MTCD units running 5.1.1:
http://forum.xda-developers.com/andr...dunit-t3405931
Old 10-30-2016, 11:17 PM   #455
Leeto
Leeto's Avatar
Drives: 2016 BRZ Series.HyperBlue
..Tested everything out before reassembly of dash and all worked as expected. Reverse camera lines have to be activated in the android OS but the default ones in the Malaysk rom I'm using doesn't line up well for the angle of the stock camera. I'll have to mod the apk for that later on. ..
Have you modded the apk to have more accurate trajectory lines yet? If you have, would you mind sharing the png?
Leeto is offline   Reply With Quote
Old 11-02-2016, 11:18 PM   #456
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Anyone else seen these? http://www.autopumpkin.com/android-6...l-control.html
Found a video too
Rican_D is offline   Reply With Quote
Old 11-03-2016, 03:16 AM   #457
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Does it get rid of the massive freeze every time the unit starts? I'm about tired of this fucking thing right now.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 11-03-2016, 07:04 PM   #458
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
I dont know. I never had the freezing before so dunno if it helps.
On another note , do not update google maps. The latest update makes it so you cant use offline maps without play services.. Fuk you google. Now i gotta find the older APK and install that.
Old 11-03-2016, 09:39 PM   #459
Rican_D
Rican_D's Avatar
I'm having zero lag issues
Old 11-04-2016, 02:22 PM   #460
Pointmutation
Drives: 2016 ZC6
I've modded the stock lines but I'm just using the png on carjoying's RAV4 blog post at: https://www.carjoying.com/Joying-blog/28.html Visually it isn't as in your face chunky as the stock Malaysk rom reverse image.
But that png doesn't match our twins' cam angle and wheel track (obviously because it was made for a RAV4. lol). Here's what it looks like on the unit.
The red 0.5m line is pretty good distance wise. But the green 2m line is more like 1m on our car. And the yellow track lines are obviously off. I just use it for the red line distance as I reverse mainly using mirrors and head check and only refer to the reverse cam for distance to wall once I'm already straight. I may just go in and remove those track lines and the numbers on the green line.
Old 11-05-2016, 01:02 AM   #461
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I dunno what to do with this thing. Fresh install of the ROM and all I have is Spotify and Torque, with USB OBD reader. The thing is basically unusable until I slap the rocket button to clean up bullshit running in the background. Disabled play services. I dunno.
Old 11-05-2016, 07:10 AM   #462
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Try Nova launcher, the stock one is pretty heavy. Also disable any stock apps you don't use. A lot of them will still load into the ram, which is why hitting the rocket button works.
-Josh
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
