Old 10-29-2016, 01:25 PM   #4509
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by pszuvela View Post
To clarify: In my 2013 BRZ, C Street allows me to put a TRD rear sway bar on and still run an aftermarket front bar?
Here's my current list of mods. I'll have to take some off to be in C Street, which is a better plan for me given the ol' budget. (This is my DD)
- Grimmspeed cold air intake (remove)
- Grimmspeed front strut tower bar (remove)
- Open Flash Tablet (reflash to stock)
- Eibach Pro Springs (possibly buy Konis and a used set of stock struts)
- Stoptech Street pads (keep or upgrade to more aggressive pads for events only)
- Whiteline front camber bolts (keep)
- Enkei RPF1 17x8 with Hankook Ventus R-S3 225/45/17 (possibly put Hankooks on the stock wheels?)
Question on tires:
I think I read somewhere in the 2016 rulebook that the tires have to be less than 2 years old. Is that correct? I bought the wheels and tires off a guy on Craigslist and he'd had them for a few years so I think they're 4-5 years old.
Pads and camber bolts are the only keepers. You can not use the TRD bar (or springs) since you have a BRZ. Those tires on stock wheels is certainly an option, but it's not the setup to have if you want to be competitive - especially if they're that old.
The other option, given the fact you'll not be competitive as-is, would be to just run the car you have now in STX and see where you want to go with more time in the car competing (I'm making an assumption, perhaps you've done that already - in which case disregard.)
The Following User Says Thank You to cjd For This Useful Post:
pszuvela (10-29-2016)
Old 10-29-2016, 01:38 PM   #4510
pszuvela
pszuvela's Avatar
Drives: 2013 BRZ Limited - Manual, WRB
Thanks for the input cjd. I might try running what I have in STX and going from there, knowing it will be a learning/growing season.
pszuvela is offline   Reply With Quote
Old 10-29-2016, 05:38 PM   #4511
scirocco78
Drives: Scion FRS
The only camber bolts you can use in Street/Stock are OEM. The White Line bolts allow too much camber.
scirocco78 is offline   Reply With Quote
The Following 2 Users Say Thank You to scirocco78 For This Useful Post:
cjd (10-29-2016), strat61caster (10-29-2016)
Old 10-30-2016, 11:18 AM   #4512
xwd
Originally Posted by justinco View Post
I have the 2017 and I would not want to autocross it (over a previous year model) in the stock/street class.
It goes 57mph in 2nd gear and of course the hard limiter with stock tune.
The thought was you could run the taller 235/45 tires to add a little bit to the top end. One of the better autocross runs I've seen on video is Ogburn's from 2015 nationals where his fast run on one side he shifted 4 times on course. A 2017 probably would have been a better car and you would be shifting just as many times. Shifting that many times leaves no real margin for error though.
The Following User Says Thank You to xwd For This Useful Post:
justinco (10-30-2016)
Old 10-30-2016, 02:10 PM   #4513
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yea good point. I remember that run as well, I know I couldn't shift like that and make it work
justinco is offline   Reply With Quote
Old 10-31-2016, 12:43 AM   #4514
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
NO - Grimmspeed cold air intake
NO - Grimmspeed front strut tower bar
NO - Open Flash Tablet
NO - Eibach Pro Springs
YES - Stoptech Street pads
NO - Whiteline front camber bolts
NO - Enkei RPF1 17x8
YES - Hankook Ventus R-S3 225/45/17
NO - Tires have to be less than 2 years old.
YES (FR-S only) - C-Street allows me to put a TRD rear sway bar on and still run an aftermarket front bar?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 10-31-2016, 08:43 AM   #4515
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
NO you cannot run a TRD rear bar and an aftermarket front bar... because you have a BRZ. If you had an FR-S you'd be OK doing that.
Old 10-31-2016, 07:37 PM   #4516
pszuvela
pszuvela's Avatar
Well I'm getting conflicting responses on the rear TRD bar and aftermarket front bar from Locust and DocWalt...
Old 10-31-2016, 07:39 PM   #4517
scirocco78
Drives: Scion FRS
I'll be the tie breaker. No TRD bar on a BRZ unless you want to run in STX.
Old 10-31-2016, 08:18 PM   #4518
MarkR171
MarkR171's Avatar
Drives: '05 Elise
TRD parts are CS legal only for the Scion FRS. The Subaru BRZ cannot use TRD parts in CS. It's a stupid rule, but it's a rule.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 10-31-2016, 09:07 PM   #4519
Locust
Custom User Title
Locust's Avatar
Well I didn't notice you had a BRZ so no, you can't do it. Just assumed you wouldn't be asking about the TRD stuff if you had a Subaru instead of a Scion.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 11-01-2016, 09:24 AM   #4520
pszuvela
pszuvela's Avatar
Got it. Thanks for the clarification everyone.
Old 11-01-2016, 11:01 AM   #4521
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I mean... you can use a TRD bar, but just one and no other sway bar upgrade.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-02-2016, 02:11 PM   #4522
ryan t
Drives: frs
Has anyone tried 225 front 245 rear? My car is completely terrible on launch. We run on sealed slick asphalt and gets no forward bite.
ryan t is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
