Old 10-24-2016, 03:26 PM   #15
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by Calum View Post
Most of the graph shows nothing outside of tolerances in the machines. It's the last 500 rpm where things start to get interesting. No REALLY interesting, but interesting nonetheless.
I saw that but in one graph the pull was cut short, and almost the exact same RPM on the other graph starts a decline. So, I'd be curious to know what exactly happened.
Old 10-24-2016, 03:30 PM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Original manifold is known to provide sufficient air flow up to 7200 RPMs. I am not aware that the newer manifold can provide the necessary flow for a higher redline. Maybe it is true, but we need evidence
Old 10-24-2016, 03:34 PM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by celek View Post
The answer is YES
Moto East no tune changes on a turbo car.
Drift Office tuned NA car
One shows the big increase the other shows a bit of a decrease. I said in my first post that with a tune there world be more of an impact. Just the manifold itself would mean very little without one.
The cost vs improvement alone would make it a very poor mod if looking for better performance.
Are we looking at different posts? They both show power and torque being essentially identical until the top end. The turbo car appears to have some issues with its boost controller as the boost builds, but outside of that the difference in the curves are negligible.
The turbo car seems starts showing a difference in the curve at ~6500 rpm, while the NA car starts showing a difference at ~7000 rpm.
I fully agree that this as a mod for more power would only be useful for a very limited group of people.
Old 10-24-2016, 03:35 PM   #18
Calum
That Guy
Good point. It looks like one stops at 7450rpm, which is stock redline IIRC. The other stops at ~7600rpm.
Old 10-24-2016, 03:37 PM   #19
LOL! Thanks. Was looking on my phone and where the two lines crossed on the bottom graph I carried them to the end backwards. Looking on the computer monitor I see they are pretty much the same.
Old 10-24-2016, 03:54 PM   #20
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
It looks like on the NA car the 3500 to 4000 dead spot is gone though
oldgunfan is offline   Reply With Quote
Old 10-24-2016, 04:03 PM   #21
wparsons
wparsons's Avatar
The red line is the 2017 manifold, which actually loses more power in the valley than the blue line.
flickr
Old 10-24-2016, 07:47 PM   #22
oldgunfan
oldgunfan's Avatar
humm ok my bad I thought the blue was the 2017
Old 10-24-2016, 08:48 PM   #23
Calum
That Guy
Given the 180 whp, I'd guess there was a header involved as well. That's likely more responsible for the lack of dead spot.
Old 10-25-2016, 10:03 AM   #24
celek
Resident Gear Head
celek's Avatar
My point is that every type of racing, drag racing, road racing ect...
The longer you can stay in a gear and make power the less shifting and time you lose.
For street use is it worth it? No
For actual functional use yes.
How many of you with a tune leave the factory redline?
How many of you are seeing the car fall on its face at 6800 RPM?
celek is offline   Reply With Quote
Old 10-25-2016, 04:31 PM   #25
s30series
Drives: 2015 BRZ Series.Blue
anyone have a flowbench they could use?
I'm pondering buying it for cheap with some extra cash laying around. If nothing else, at least it cleans up the engine bay
s30series is offline   Reply With Quote
Old 10-25-2016, 07:57 PM   #26
celek
Resident Gear Head
celek's Avatar
I have access to a flow bench and have spare plastic manifolds. But the proof is in the dyno. It flows more at the top end which is why it produces more power. Unfortunately these are now back ordered until December 2016
Old 02-15-2017, 04:19 PM   #27
Bobster
Drives: GT86 GTS
Bump,
Anyone got one of these who can measure the diameter of the throttle body opening for me please.
Stock plastic on too if possible
Bobster is offline   Reply With Quote
Old 02-15-2017, 04:48 PM   #28
Hawk77FT
Drives: GTS 86
Originally Posted by Bobster View Post
Bump,
65mm on the plastic manifold (I will double check this weekend if you like). I am quite certain it will be the same for the new one as well!
Hawk77FT is offline   Reply With Quote
2017 Red Manifold BrunoCr7 Engine, Exhaust, Transmission 121 03-26-2018 01:35 PM
2017 Aluminum Manifold F/I Gearbanger Forced Induction 11 11-14-2016 05:56 PM
Intake manifold dallenj Engine, Exhaust, Transmission 0 11-02-2015 02:56 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
