Old 10-24-2016, 03:21 AM   #15
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Okey dokey reviving thread guys. It's been a while since I sent my midpipe to ft86speed factory and they sent it to the manufacturer to check. Manufacturer told them they've inspected the pipe and found nothing defective, so they went on testing it by putting it onto their car. They again stated there was no noise. Hopefully they drove it 15-30min on highway..
anyways just got it back last week and put it on.. nothing as first so glad than a day or two after it came back quietly than the 3rd day after a drive from work to home it got loud again like the first time. Now a week since I installed it again.. anyone got any idea or free time to come inspect? It's driving me crazy here😰
turtlefeeder is offline   Reply With Quote
Old 10-24-2016, 08:27 AM   #16
15limited
15limited's Avatar
Originally Posted by turtlefeeder View Post
it seem to come from right under the center console in the middle of the car. there are no gaskets it is tightened by clamp with nuts.
That's somewhat close to where the front pipe meets your mid pipe. There is a donut gasket there however, should also be springs on this connection as well, check for those things. You should also have 5 exhaust hangers, 4 on the axle back and 1 supporting the mid pipe.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-24-2016, 08:35 AM   #17
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Pictures of all joints. Pictures of either side of piping. We're not clairvoyant.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
15limited (10-24-2016)
Old 10-24-2016, 08:45 AM   #18
bfrank1972
Drives: 2013 FR-S Argento
Who is installing/uninstalling your exhaust?
If you, then what is your procedure?
One area that can be the issue is actually the overpipe - clearance is quite narrow there and if you loosen up everything after it and move it around, it might be touching that crossmember it 's supposed to clear. Get under your car, loosen up your front pipe - move it around a bit, push up on it and secure bolt to hold it. Tighten everything up again and see how it goes.
Old 10-24-2016, 01:05 PM   #19
turtlefeeder
Drives: UltraMFrS
mid pipe knocking
Hmm Does the donut gasket weld onto the front pipe or is it just attached in between like a regular gasket?
I checked the connections and they seem solid also went under several times to check if it is bumping or hitting other parts but nothing that would explain the kind of knocking
Old 10-24-2016, 01:20 PM   #20
Use a bright light and look for shiny spots where the metal is hitting/rubbing. It doesn't take much of a hit to make a loud noise.
Luftwaffel (10-24-2016)
Old 10-24-2016, 03:02 PM   #21
wparsons
wparsons's Avatar
It slips over the stock front pipe, and fits snug against the stock cat back. If you're still running the stock front pipe, it was probably still there when you put the new cat back on.
That said, the noise doesn't sound like a leak at all.
flickr
Old 10-24-2016, 03:11 PM   #22
bfrank1972
Just watched the video - you mean that sharp periodic snapping sound? That doesn't sound like rubbing to me - sounds like metal expansion or some sort of thing. Rubbing has frequency related to idle - it will sound like a buzzing.
I assume you've taken this to a shop and had them look at it? What did they say?
Old 10-24-2016, 05:27 PM   #23
turtlefeeder
Drives: UltraMFrS
Im on a full cat back, everything else is stock from 2nd cat back up to headers, I still have the stock catback with midpipe however I did not find any removable parts like the DONUT gasket maybe it could be that?
Yes it's that period snap/ knocking noise that's getting my attention, agree it wasn't a rubbing type noise, also I check for rubbing it has clearance and wasn't touching other stuff
Also yes I did take the car to a few mechanic to take a look
Old 10-25-2016, 08:46 AM   #24
15limited
15limited's Avatar
Only reason I was thinking donut gasket or lack there of would cause a build up of pressure then the joint to expand, letting exhaust gasses out then it making contact as it comes back together, but :confused: :confused:
Old 10-26-2016, 02:28 PM   #25
turtlefeeder
Drives: UltraMFrS
Just checked on Monday. Donut gasket still there so that's not the issue neither
Old 10-26-2016, 03:53 PM   #26
frosty288
frosty288's Avatar
Drives: 2015 BRZ
It's probably the overpipe tapping the subframe. It happened to me when I put on a new header, it moved the OP down a little bit - I also have a 2.5" OP. What can help is the bolt that is in the middle of the midpipe can be drilled a bit higher than it is from the factory, this will give the overpipe a little more clearance over the subframe and it shouldn't knock anymore.
Stiffer motors mounts would probably fix it too - but the cheapest and fastest way is to just move the the midpipe up a bit on the hanger.
frosty288 is offline   Reply With Quote
Old 10-26-2016, 04:32 PM   #27
turtlefeeder
Drives: UltraMFrS
mid pipe knocking
Hmm it knock when I'm idle after a long drive on the high way so I doubt it's hitting the subframe :/ aside from the catback the rest is stock even header.
Old 10-26-2016, 08:17 PM   #28
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Delete the spring screws they factory exhaust uses. Use normal solid nut and bolts only, report back.
The factory mounts are crap but held up very well with a NA car. Once you push 300hp the factory mounts for the trans and engine turn into gue....
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Knocking after i turn the car off bored@work84 Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2016 03:31 PM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 09:09 PM
Wheels Knocking kalamitykode Issues | Warranty | Recalls / TSB 1 05-21-2014 05:50 PM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 07:18 AM
