Old 10-22-2016, 03:56 AM   #505
Killadelphia
Hey Wayno, I notice sometimes that files that are listed in the first post disappear (sometimes with newer dates). If you remove them does that mean that you found them to be unsuitable and that they shouldn't be used anymore?
Killadelphia is offline   Reply With Quote
Old 10-22-2016, 06:00 PM   #506
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I'm still constantly improving them. I don't like having old versions attached. At the same time I'm not getting any donations indicating no one is using them so I'm not wasting any more time uploading here. For a small amount i will supply my changes in any cal id, and with launch control for 6mt. Also flex roms for 6mt and 6AT.
Old 10-22-2016, 10:59 PM   #507
Tor
Tor's Avatar
Drives: Toyota GT86
Version 120.3 is awesome, I flashed it today with my custom MAF. The changes to the injection is brilliant. "Flash, get in, drive.." Car feels strong from putting it into gear and pulling out of the driveway. Cumbersome learning seems redundant as it only changes the LTFT a small notch.
I can well understand that you don't bother to upload new tunes when nobody donates or let alone bothers to simply say "thank you".
Tor is offline   Reply With Quote
Old 10-23-2016, 05:05 PM   #508
Tor
Tor's Avatar
Drives: Toyota GT86
Please don't ask me for the 120.3 tune via PM. Ask Wayno!
This is what a good tune will do by the way:
I don't get it. People spend 1000s of $ in parts and this not worth 25 AUD = 19 (!!) USD to you?
Thank you Wayne!
Old 10-23-2016, 06:54 PM   #509
Wayno
Wayno's Avatar
Thank you Wayne!
50 USD
Old 10-31-2016, 10:04 AM   #510
Nah
Drives: 2013 Scion Frs 6mt
I'll take one.
Originally Posted by Wayno View Post
50 USD
Nah is offline   Reply With Quote
Old 11-01-2016, 12:17 AM   #511
Nah
I just applied wayno's base map and wow.
Btw wayno bro, thank you. Just left a donation.
Anyways, I can't wait to scale my maf.
Old 11-03-2016, 03:44 PM   #512
Nah
After scaling my maf I noticed at 3-4k rpms giving anywhere between 50-100% throttle afr is a little to rich (11.3-11.8) usually, causing slight hesitation there. Anyone know why and how tp fix it? Happened before and after maf scaling using wayno's tune.
Which is arguably the best base tune for oft n/a user's
Anyways thanks!
Old 11-03-2016, 04:21 PM   #513
Kodename47
Kodename47's Avatar
Drives: UK GT86
Anyways thanks!
Load limits can rectify that, reduce them to prevent it going too rich.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-03-2016, 04:52 PM   #514
Nah
Thank you sir. Will try it out on the next revision to my maf...
Old 11-03-2016, 04:54 PM   #515
Nah
I tried using the wot best vvt tool but when I loaded multiple logs the best vvt never showed up... any thoughts?
Old 11-03-2016, 06:40 PM   #516
Kodename47
Kodename47's Avatar
Drives: UK GT86
Did you paste in your AVCS tables?
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-10-2016, 03:06 PM   #517
Nah
So like this? then hit save RPM column?
Old 11-11-2016, 04:31 AM   #518
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, that's not RPM
In the top right there's RPM#1 and RPM#2. Copy the RPM column from your map into that. That determines the RPM break points in the map for the tool. The main columns are just for the log data once it's loaded in.
.: Stealth 86 :.
Kodename 47 DJ:
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
