Old 10-22-2016, 11:55 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Question about adjusting coilover height?
I've had RCE T2's about a year now and they've been great. Only thing is I can never seem to get the ride height evened out the way I want. Seems like whenever I do measurements, my adjustments never seem to work out right.
I recently read that when adjusting one corner it actually affects the height of the opposite corner. Sort of like making height adjustments in an X pattern. Is that actually true? If so, I've been going about this wrong the entire time.
smg1138 is offline   Reply With Quote
Old 10-23-2016, 01:14 AM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Adjust two at a time, raise or lower one side of the car evenly, front/rear/left/right. I start at a 'zero' point with the perches just snug on the springs so they don't move, basically 'even preload' as it would be described by those who call it that.
Don't forget the rear has a different motion ratio, one turn on the front damper will be equal to roughly 3/4 turn on the rear. I have been happy raising the front equally to approximately what I want, set the rear approximately, then set the tilt of the car, usually it's ~2 turns to raise the left front, ~1.5 turns to raise the left rear and I'm usually within about an eighth of an inch of my targets. I'm on Bilstein which aren't terribly different in this regard to the KWs, I've done the same procedure on a different car with KWs.
That's just ride heights though, then you get into corner balancing...
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
RJasonKlein (10-23-2016), smg1138 (10-23-2016)
Old 10-23-2016, 07:25 PM   #3
shattered_memory
Drives: Satin White BRZ Limited
I've had the same issues with lowering my BRZ evenly with Tein Flex Z coilovers. I had all of my measurements set before installing and when installed, the ride height was off Left to right/Front to Rear. It took a lot of trial and error to get it right. In the end, It was still not 100% even, but close enough to where I was satisfied. The best thing to do get the car corner balanced.
shattered_memory is offline   Reply With Quote
The Following 2 Users Say Thank You to shattered_memory For This Useful Post:
kevaughan (11-15-2021), smg1138 (10-23-2016)
Old 10-24-2016, 02:44 PM   #4
renfield90
The Stig's German cousin
If you're adjusting a single corner at a time and then remeasuring, in case you're not already doing this I STRONGLY recommend you:
- disconnect both sway bars
- drive a quarter mile or so (or a couple laps in the neighborhood) after each change
- measure while parked in the same spot, preferably on flat ground with no incline
Maybe I'm lucky, but on my T2s I simply counted the number of threads on the shock collar from bottom until the spring perch and matched them left/right; ended up with a very equal drop left to right. As far as ride height goes I only care about front vs rear, if I want to make a change on one axle then I turn the spring collar the same number of turns left/right.
Also note that getting ride height equal left/right does not necessarily mean your corner weights will be equal left/right. It's definitely important to fix gross imbalances, but if it's a couple mm I wouldn't worry.
The Following User Says Thank You to renfield90 For This Useful Post:
smg1138 (10-24-2016)
Old 10-24-2016, 03:07 PM   #5
smg1138
smg1138's Avatar
I think I finally got it evened out last night. I started out with all the spring perches even relative front/back and then made small adjustments from there. The fronts are exactly the same and the rears only required 1/8 difference from left to right. Now my ride height is 25 1/4 F & 25 3/8 R with a full tank and all the trunk junk. This is going to be winter mode for me.
question about adjusting ride height with coils spicyricecake BRZ First-Gen (2012+) — General Topics 4 03-14-2016 02:32 AM
How does adjusting ride height affect toe? smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-11-2016 12:28 AM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 01:57 PM
Adjusting Fog Light Beam-Height k3l3ka Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2013 11:21 PM
coilover shock body height adj garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-19-2013 04:32 AM
