Old 10-20-2016, 06:32 PM   #1
Bobster
Drives: GT86 GTS
ACE CS400 Dyno's Please
Hi Guys,
Purchased a set of ACE CS400's, would like to know what kind of results you guys are getting. Please can you post you ACE CS400 dyno's with supporting mods as well.
Pretty please
R
Bob
Bobster is offline   Reply With Quote
Old 10-20-2016, 08:00 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I haven't dyno'd it, and my only supporting mods are a drop in air filter (Cosworth) and the DT tune. The rest of the exhaust is 100% stock.
I can tell you that this setup has much more torque than I was expecting. It has usable torque even down at 2000 rpm. It's not unusual for me to be putting along in traffic at about 65 km/h in 6th gear. From there, the power just builds like a freight train (well, ok, an NA freight train) all the way to red line. You will not be disappointing.
Old 10-20-2016, 08:36 PM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I have considered this as well, it doesn't hurt that it is ACE's lowest cost offering either. Haven't seen a ton about the 400 as it seems most get the 350.
Old 10-20-2016, 10:40 PM   #4
Calum
That Guy
Don't quote me on this, but when I talked to Zach about the 400 vs the 350, he said the top end was unaffected. Even if there is a difference, it seems likely that it would be pretty minor.
Old 10-20-2016, 10:59 PM   #5
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Hot off the presses in UK.
Please don't pick this apart, a guy got a CS400 and dyno'ed it. Here are his results
AceHeader-MT is offline   Reply With Quote
Old 10-21-2016, 02:28 AM   #6
Bobster
Drives: GT86 GTS
Thanks Matt! Header just arrived!
Yea trying to get a place for this info
Old 10-21-2016, 03:46 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Summerwolf: Most drive LHD, thus most get 350 as one giving most gains area under curve, unfortunately it also has clearance issues on RHD.
CS400 is somewhat similar ACE's header to 350, that fits fine on RHD. Also has good gains under curve & slightly even more low rpm optimised then 350 IIRC. It has Type B slip-on welds that makes production faster/cheaper, thus reduction to price, but for clearance enhancement it's overpipe is similar to 250, thus to move optimisation lower in rpm range it had to tuck extra runner length prior ovepipe, with sharper bends in piping.
In general get it if RHD or if "almost 350" for less, but if your car is LHD and want no-compromises best possible, get 350. To extract it's gains fully from any of them you'll need competent ecu tuners work though. Safe choice should be Delicious Tuning OTS ecutek tunes for ACE headers.
Old 10-21-2016, 05:01 AM   #8
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
Ace header is undoubtedly the best header out there. I currently have a set of CS 400 with JRSC C30, DW injectors & pump, and flex fuel. Currently running Church Tuning conservative tune from Wilmington, CA, outputting 294hp 216tq with cali 91 pump and 330hp 234tq on E85 from a dynopack.
Aside from the performance gain, Ace customer service was phenomenal. I had issues with fitment, and Ace was able to fedex overnight from Taiwan, a brand new header to me to correct the issue.
86two6 Thursday Meets in SoCal.
IG @86two6
Greddy86 is offline   Reply With Quote
Old 10-21-2016, 05:05 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
CS400 and high flow cat, otherwise stock exhaust. Tuned by Mark at Abbey Motorsport. Lower line is stock car.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-21-2016, 06:35 AM   #10
Calum
That Guy
Do you have any before dynos? Even just a baseline with the supercharger and then supercharger and header would be phenomenal. Also, I'd love to see what that torque curve looks like with that combination.
Old 10-23-2016, 01:54 AM   #11
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
I don't have the power figures from before the Ace header was installed. I was running tomei uel before. After switching to Ace, mid to high end power gain was easily noticeable.
I think the ultimate sacrifice for me to switch to EL was the sound. I really miss the rumble. But with the power I'm making, I don't regret.
IG @86two6
Old 10-23-2016, 08:14 AM   #12
JDM4E
Drives: Honda Accord Euro
Funny how the curve is different od Dynapack vs roller dyno. Or is it tuned ""not as good"?
JDM4E is offline   Reply With Quote
Old 10-23-2016, 02:58 PM   #13
tracerit
Drives: '13 SSM BRZ Limited 6MT
I just wish there were more sound clips of the exhaust with a stock exhaust. Aside from my powertrain warranty ending in 15 months, that's the only thing holding me back. I'm a big stickler for sound, not looking for something obnoxious like most UEL's. Pretty sure the CS400 will sound good, but I just need to get a better feel for it.
tracerit is offline   Reply With Quote
Old 10-23-2016, 06:07 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
The Dynapack shows more torque below 3500. Other than that they're quite similar, bar smoothing and differences between dyno types. Ramp rate might also have an impact on that.
.: Stealth 86 :.
Kodename 47 DJ:
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes malubawla Southwest 14 11-21-2015 01:53 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
