Old 10-21-2016, 05:00 AM   #15
allowe
allowe's Avatar
Cheap pulley kit from ebay
Originally Posted by nikitopo View Post
There is a debate for many years. Some people defend them, some don't and some just try it. Personally, I tried it and my car is much better than ever. Keep in mind that this is a small NA engine and it helps saving rotational weight. However, keep also in mind that my car is less than 2620lbs, I installed the most expensive pulley kit and it also underdrives the alternator (not good if you have A/C, heated seats or in general use the battery a lot). Additionally, you'll hear more noises from the engine. For me it is fine, because it is a sports/race car and not a daily driver. I would never install this on my daily car. If you want to buy it, I agree with the others. Don't buy these things from ebay for cheap.
I've been waiting for a reply like this. Thanks for your input. I do have A dual 12 inch sub that's always blasting and my ac is always on. So guessing this is a bad idea then
allowe is offline   Reply With Quote
The Following User Says Thank You to allowe For This Useful Post:
nikitopo (10-21-2016)
Old 10-22-2016, 08:45 AM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by GSpeed View Post
Some people want to know if they slow down the alternator or other accessories at high RPM ("underdrive"), but don't really investigate whether or not that's necessary. Do they make the accessories drive slower? Sometimes, yes. But again, that's not really accomplishing anything other than justification bias on these motors as already mentioned. Now, if you go buy a motor from Element Tuning or someone that's meant to spin to 9,000 RPM all day long, then maybe there's some merit there.
An underdrive alternator pulley slows down the alternator always and not only at high RPM. You don't have to spin the engine at 9,000 RPM or something like that as you mentioned. In general there is a lot of misunderstanding of how to accomplish underdrive. I've even seen pulleys that the manufacturer stated they were providing underdrive and in fact it was the other way around
Old 10-24-2016, 01:01 PM   #17
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
True. Just pointing out that's the only time you'd WANT to slow down accessory drive speeds. I could have worded that better.
Jake
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
nikitopo (10-24-2016)
Stock crank pulley CHEAP jack43 Engine, Exhaust, Bolt-Ons 0 08-22-2014 06:27 PM
Cheap eBay catback system (Australia) Fizz Engine, Exhaust, Transmission 9 10-24-2013 10:06 PM
Thinking of offering this sticker cheap on eBay... wbradley Off-Topic Lounge [WARNING: NO POLITICS] 33 01-29-2013 10:02 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
