Old 10-21-2016, 12:45 PM   #20581
DANG, there, soulreapersteve, that blow up doll of yours really looks real .....
humfrz is offline
go_a_way1 (10-21-2016), soulreapersteve (10-21-2016)
Old 10-21-2016, 12:48 PM   #20582
Ashikabi
Ashikabi's Avatar
Say, has anyone converted their music library from whatever fine type to mp3? What program did you use? Did you have to do each album individually or did the software take care of it? Did you have duplicates?
Ashikabi is offline
Old 10-21-2016, 12:54 PM   #20583
It is the nozzle on that blow up doll that is the issue.
Tcoat is offline
Old 10-21-2016, 01:47 PM   #20584
I don't get it ........are you saying it's a "bi" blow up doll ......
humfrz is offline
Old 10-21-2016, 01:49 PM   #20585
Ashikabi
Ashikabi's Avatar
Tcoat got tricked by Visual Kei and now he thinks all asians are cross dressers...
Ashikabi is offline
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
go_a_way1 (10-21-2016), soulreapersteve (10-21-2016), Tcoat (10-21-2016)
Old 10-21-2016, 01:51 PM   #20586
No boobs :/
Not all Asians just Japanese (oh, and the occasional Thai) ! And the one in Steve's gif in particular.
Tcoat is offline
Old 10-21-2016, 01:58 PM   #20587
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Damn it, looks like Photobucket went coocoo again, so I won't be cleaning up MCS today... I'll check again on Monday.
ichitaka05 is offline
Old 10-21-2016, 02:46 PM   #20588
cjd
cjd's Avatar
Drives: 2017 BRZ
Why? I'll find a way to get more storage before I start introducing noise and crap going to a lossy format like mp3. If the rate is low enough it makes me right drowsy, not to mention annoying me.
I use EAC to rip CD's, and the only time I've done conversion (from Apple lossless to FLAC) was on a linux box. I've actually created a RW cd from iTunes and then converted that to FLAC too. Sometimes that's the only way (if it's protected format)
cjd is offline
Old 10-21-2016, 02:52 PM   #20589
Ashikabi
Ashikabi's Avatar
My new phone doesn't archive wma files properly so I need to convert them to something that it will do. I can't tell the difference between a "good"quality file and a "bad" quality file so out doesn't matter to me. I just want my music to work. I think I figured out a way though. Gonna install a new music player and have it convert my library then I'll delete it
Ashikabi is offline
Old 10-21-2016, 03:04 PM   #20590
cjd
cjd's Avatar
Drives: 2017 BRZ
Oh, ew. WMA. If that's lossless (it can be,) I'd still explore the option of something lossless. There are converters out there. You could keep two copies, but I highly recommend keeping a lossless version around somewhere - there's no way back. Hearing the difference isn't always obvious at higher bit rates, but as I mentioned - mp3 still seems to make me drowsy.
Another option that will take a lot less time, if you're on Android. I use Rocket Player (paid version) which looks to support WMA (though not lossless, so you may be out of luck) as well, plus a ton of other formats. Good integration, and a very good music app IMO.
cjd is offline
Old 10-21-2016, 03:12 PM   #20591
Ashikabi
Ashikabi's Avatar
I tried power amp and it was instantly buggy so I scrapped that. I'll try to pick a lossless format if I can but my primary concern is to just have my music available. If I had to pay for a music app it would be worth it. So tired of fucking with this phone
Ashikabi is offline
Old 10-21-2016, 03:37 PM   #20592
Teseo
Drives: frs
I remember when used fire fox with download helper tool and downloaded you tube video, then used audio extractor to get the audio from the video, moved the file/audio to my mp3 player and ya esta.
Teseo is offline
The Following User Says Thank You to Teseo For This Useful Post:
MrFisty (10-21-2016)
Old 10-21-2016, 03:40 PM   #20593
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I think you got that the other way around LMFAO!
krayzie is offline
Old 10-21-2016, 03:43 PM   #20594
krayzie
Drive From Home
krayzie's Avatar
Download something called xrecode ii. The free version works just fine.
I agree with cjd, go with lossless if possible so your ears won't bleed from prolong listening to lossy compression.
krayzie is offline
