Old 10-01-2016, 10:50 AM   #71
JoeBro
JoeBro's Avatar
Drives: Scion FR-S
@dito just wondering how you achieved -4 camber in the front? When I maxed out my top plates the bag rubbed and ruptured on the strut tower/side of engine bay.
JoeBro is offline   Reply With Quote
Old 10-01-2016, 03:01 PM   #72
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
Take out the strut, then take a hammer and knock out the plastic clips. Also unscrew the metal nut from the engine bay.
ChanceK is offline   Reply With Quote
Old 10-14-2016, 11:49 PM   #73
Datboywing
Drives: 2015 Subaru BRZ limited
My wheels are coming in soon. Work meister m1 3 piece matte gunmetal. Specs are 18×9+23 and 18x10+26. What are your thoughts? Will it clear? On airlift v2 on brz. Anyone??
Datboywing is offline   Reply With Quote
Old 10-20-2016, 01:43 AM   #74
ChanceK
ChanceK's Avatar
Drives: 2016 FRS
I run 18x9.5 +22 in the front. You should be fine.
Old 12-04-2016, 03:22 AM   #75
wutangbrz
Drives: 2015 dgm brz
this only concerns the stance guys who are looking to go for aggressive camber.
managed to get -8 degrees front camber on 18x9.5 +5 with good bag clearance from the inner strut wall and the barrel. Achieved this by using a pair of Racer X front lower control arms.
wutangbrz is offline   Reply With Quote
Old 12-07-2016, 10:03 PM   #76
csong30
Drives: Brz
You have a staggered set up??
csong30 is offline   Reply With Quote
Old 12-08-2016, 02:22 AM   #77
wutangbrz
square 9.5 +5
The Following User Says Thank You to wutangbrz For This Useful Post:
csong30 (12-11-2016)
Old 12-14-2016, 07:48 PM   #78
csong30
Drives: Brz
square 9.5 +5
Hey did you get enough clearance even without the front lower control arms?
I remember last time I asked you about the inner wall clearance on the driver side. I ended up popping my bag thinking I made enough clearance by hammering the wall. Trying to make sure I have enough clearance all around. Thinking about raising it up some as well.
Old 12-15-2016, 11:46 PM   #79
wutangbrz
Yes i had enough clearance before the flca. hammered in the inner wall, took out all the clips and bolts. it helps that i not running a fat tire on the 9.5 as well so theres no tire on bag rubbing issues.
csong30 (12-25-2016)
Old 01-03-2017, 09:19 AM   #80
pZiLLA
Drives: Scion FR-S
This is my current setup. I wanted to know if I will clear
18x9.5 +24
Tires 235/45
I was thinking about getting some 5 or 10 spacers.
pZiLLA is offline   Reply With Quote
Old 01-25-2017, 08:00 AM   #81
Mbndeon
Drives: 2014 FR-S Monogram
Did you have to slot your struts to get that much camber before the flca's? I haven't played with my plates yet as its on full postive atm but I'm guess maxing it with the 14mm crash bolt trick and camber bolts on the lowers holes wont get me that much. I also got some oni camber plates on the side but I might just sell them since I havent heard of anyone running it on our airlift struts due to the inner wall clearance issues
Mbndeon is offline   Reply With Quote
Old 03-22-2017, 01:44 PM   #82
csong30
Drives: Brz
Are you on bags or coilovers?
Old 03-29-2017, 01:44 AM   #83
Izanagi
Izanagi's Avatar
Drives: 15' Raven FRS.
Hey guys, suspension newbie here. I currently have 18x9.5 +35 (235/40) squared. Will I run into any problems with rubbing while driving? If so how would I go about fixing this?
Thanks!
Izanagi is offline   Reply With Quote
Old 03-29-2017, 02:08 AM   #84
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Originally Posted by protpibe View Post
I emailed FT86speedfactory and they confirmed that an 18x9.5 +33 with 245/35/18 tires will clear the Air Lift system
I guess I'll find out for sure next week lol
EDIT: Should read 265/35/18
so would you say that a 18x9.5 et 35 would clear the bags?!
TheWhiteWizard13 is offline   Reply With Quote
airlift, bag, cup, suspension, tfworks
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 632 12-22-2023 09:49 AM
Double Exhaust catback system infos Junkwipe Engine, Exhaust, Transmission 25 01-21-2014 12:25 PM
Double Cat Front Pipe? Emissions? swift996 Engine, Exhaust, Transmission 9 01-13-2014 10:29 PM
Essex Competition Brake System (Endurance) fitment on 18x8.5 57Xtremes Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-10-2012 03:08 PM
