Old 08-31-2016, 02:52 PM   #533
wtfrs
Drives: 2014 Monogram
How low are you?
I am on air, but when i drive, i drive at 0 wheel gap. I daily it like that without scraping and going up specific driveways and entrances. Scraping it was one of my biggest concerns but I bit the bullet and i have yet to scrape it.
wtfrs is offline
Old 08-31-2016, 02:54 PM   #534
Nah
Drives: 2013 Scion Frs 6mt
anyone have a perrin cbe that fits with the diffuser?
Nah is offline
Old 09-02-2016, 02:11 PM   #535
Jonsey
Jonsey's Avatar
Anyone have problems with the prongs sticking out to far and scraping on driveways?
Yes. With the diffuser on the lowest setting due to stock exhaust and on Swift Spec R springs (1.0" drop), I scraped the diffuser and front splitter every time I entered the parking garage at work (which had a pretty decent angle change). I have ground the prongs on the diffuser a decent bit.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline
Old 10-19-2016, 05:56 PM   #536
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
For anyone that is really low, we obviously recommend the non-aggressive version, it helps with scraping quite a bit. Unfortunately, most of the super low guys want the aggressive version.
We have now released rear spats to accompany the diffuser.
FT-86 SpeedFactory has a few and we have a few on the shelf. Doing another production run now.
Thanks,
Eric
VerusEric is offline
Old 10-19-2016, 11:50 PM   #537
Iamwu
Drives: 86
I have the aggressive as well, on bags. Unfortunately even at full raise I manage to scrape perhaps 50% of the time unless I'm able to get a really good corner up/down the roads. For what its worth this happens every time I drive onto and off the Washington State Ferry on my way to Seattle. It definitely sounds worse than it actually is.
@ Jonsey, how bad is the front splitter scrape? Do the scrapes do any noticeable damage? I'm holding off installing my front lip due to the inclines / declines I encounter daily.
km4sh #00002
Iamwu is offline
Old 10-19-2016, 11:57 PM   #538
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
Do you have CFD out for these yet?
Ashikabi is offline
Old 11-11-2016, 05:49 AM   #539
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Any recs on how to jack up the rear of your car with this installed?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline
Old 11-11-2016, 06:25 AM   #540
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Make a 2x6 ramp (or equivalent) two 2x6s high. Make the bottom one 24" and the top 12". Once you drive onto them jack by the rear diff at a slight angle as not to hit the exhaust/diffuser fins.
OR
Use the OEM jack on the pinch weld to get the car high enough to fit a real jack under the diff. This method is difficult to lower the car with.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 11-11-2016, 08:22 AM   #541
Ashikabi
Ashikabi's Avatar
OR
I use the first method. Works well
Ashikabi is offline
Old 11-11-2016, 08:50 AM   #542
Bramick
Bramick's Avatar
My rear diff is covered by the diff/suspension covers That's the tricky part. I'm thinking long and tall ramps or dual jacks.
Bramick is offline
Old 11-11-2016, 08:55 AM   #543
Ashikabi
Ashikabi's Avatar
Those would be really long ramps... Have you considered modifying the cover, jack, or diff to make it more practical for lifting? Maybe a hole in the cover? I'm sure you don't want to cut up your shit but I haven't come up with a good alternative yet. I'll be facing the same dilemma before to long. With the diff covered, won't it get really hot?
Ashikabi is offline
Old 11-11-2016, 09:33 AM   #544
VerusEric
VerusEric's Avatar
No, they are more for looks than performance so we did not CFD them. They probably do very little for performance.
The rear diff is still open with the diff/suspension covers. That's what I use to jack up my car.
Thanks,
Eric
Old 11-11-2016, 09:35 AM   #545
Ashikabi
Ashikabi's Avatar
Thanks,
Eric
At least you're honest lol. How about the skirts?
Ashikabi is offline
Old 11-11-2016, 09:40 AM   #546
VerusEric
VerusEric's Avatar
We haven't released images but numerically they reduce lift coefficient by 11 points while increasing the drag coefficient 2 points.
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
