Old 06-15-2012, 08:15 PM   #1
loong
Drives: 98'DC2R
HID Conversion DIY
So before I got a chance to shoot the FRS I posted in photo/video thread, I was able to capture a step by step instruction of how to install an HID kit into the FRS.
Brand:
Alumina Xenon H11 6000k
Unplug the factory bulbs, and remove them from the harness plug.
Take the two prong connectors from the Alumina H11 bulbs and plug them into the factory harness plug.
Connect the plugs from the Alumina H11 bulbs to the Alumina S2 ballasts.
Take the remaining plugs from the Alumina H11 plugs and connect them with the remaining plugs from the Alumina S2 ballast.
Turn on your headlights to check if all your plugs are connects properly. If the bulb does not ignite, reverse the two prong connected to the harness.
Once you have checked all your connections, and everything is working, use electrical tape to secure the prongs to the harness plug.
Plug the Alumina H11 bulbs back into the factory socket.
Find the supplied zap straps
Zap strap any loose wire and lines to de-clutter your engine bay.
Mount your ballast to a secure location using either double sided tape or zap straps. The ballast was mounted to the frame using double sided tape.
Before and After
loong is offline   Reply With Quote
Old 06-15-2012, 08:36 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Nice write up!
But Did you adjust the squirrel finders for the HIDs?
86_ZN6 is offline   Reply With Quote
Old 06-15-2012, 08:47 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Mash those metal pieces (squirrel finders) hard
tonystewart is offline   Reply With Quote
Old 06-25-2012, 12:54 PM   #4
Turbowned
Turbowned's Avatar
How much was the kit?
Old 06-25-2012, 01:23 PM   #5
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
How is your light cut-off on the top?
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 06-25-2012, 02:59 PM   #6
Dragon86
Drives: Whiteout FR-S MT
What are these squirrel finders lol? are they in the hosuing somewhere?
Dragon86 is offline   Reply With Quote
Old 06-25-2012, 03:07 PM   #7
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
They are used to reflect light a certain way if you bend them then it creates a much better cutoff for pnp HID in Halogen porjector housings.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-25-2012, 03:18 PM   #8
Dragon86
I know what your saying, but i need a Visual image to see what it is.
Old 06-25-2012, 03:37 PM   #9
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
google it
http://www.3gwrx.com/forum/index.php?topic=13416.0
Out of the FRS game
Old 06-25-2012, 05:02 PM   #10
Dragon86
Thanks man, now i know what it is.
Old 07-06-2012, 09:46 PM   #11
beefalo
Drives: 2013 Scion FR-S Asphault M/T
Where did you get these and how much were they?
beefalo is offline   Reply With Quote
Old 07-17-2012, 02:41 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
Can someone post a link to where to buy this or similar Xenons that won't F up
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-17-2012, 02:52 PM   #13
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Sorry to rant but I hate these ghetto ass kits that don't even provide the OEM connectors.
Old 07-17-2012, 03:11 PM   #14
Synack
Boosted
Synack's Avatar
Drives: Sideways
There probably aren't any kits that fit the stock connector. Does anyone know if the Scion tC and xB have the same harness connector as the FR-S? That would save a lot of trouble.
leather seat conversion stalon320 Interior Parts (Incl. Lighting) 6 07-20-2012 04:36 PM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
Anyone ever heard of a coupe to removeable hard-top conversion shop? Saibot CANADA 26 02-09-2012 10:38 PM
