Old 10-18-2016, 01:39 AM   #785
Rodn333y
Drives: 2016 Scion FR-S
Make sure your downloading Romraider definition and not Ecuflash definitions they are different.
After you download the definitions then you need to tell romraider which one to use , use menu option, Definition Manager
see Romraider tips link below, their is video as well in their
Ok so I made sure I download "ECU Definitions" extracted them to my RomRaider Directory then opened the application and went into the menu and located them restarted the application then tried to edit a bin file from my ots directory but still no luck. I'm still getting the ECU Definitions not found error
I should mention I am trying to edit roms from a Scion FR-S not a Subaru but I didn't think that would matter right? I just looked at the FAQ on the RomRaider website and saw a question asking if it only worked on Subaru so I just want to clarify lol.
Rodn333y is offline   Reply With Quote
Old 10-18-2016, 03:34 AM   #786
Kodename47
Kodename47's Avatar
Drives: UK GT86
Where did you get the definitions from? Did you get the ones specific to your ROM type from the OFT website? When you open up the Definition Manager from the menu, are the definitions still showing?
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 12:57 PM   #787
Rodn333y
I got them from the romraider website not the OFT website? Yes they are still showing in the definition manager
Sent from my SM-N920V using Tapatalk
Old 10-18-2016, 01:49 PM   #788
Kodename47
Kodename47's Avatar
Drives: UK GT86
What ROM type are you using? If you followed the link from the menu in Romraider then you need the correct definitions.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 02:11 PM   #789
Rodn333y
I'm not sure? I did use the "get ecu definitions" link from the rom raider menu and i just chose standard
Old 10-18-2016, 04:02 PM   #790
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.openflashtablet.com/downloads/
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 04:15 PM   #791
Rodn333y
Yeah thats where I downloaded romraider from but no definitions are listed among those downloads?
Old 10-18-2016, 05:00 PM   #792
Kodename47
Kodename47's Avatar
Drives: UK GT86
They come with the ROM files.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 05:07 PM   #793
Rodn333y
I downloaded it installed it opened it and then tried to open a bin file to edit and it gives me the error "ecu definitions not found"
Old 10-19-2016, 03:59 AM   #794
Kodename47
Kodename47's Avatar
Drives: UK GT86
Download the OTS tune files from that link.The xml definition files are in that zip folder (folder is called v2.06 XMLs [MUST USE THESE FOR EDITING]). You need to know which Cal ID/ROM type is on your car so you can edit the correct file and add the correct definition to allow you to do so. If you can post you Cal ID/ROM type I can likely send you my own definition which is more complete than those that come in the download.
It's. Really. Not. That. Difficult
.: Stealth 86 :.
Kodename 47 DJ:
MrFisty (10-20-2016)
Old 10-19-2016, 09:12 PM   #795
Rodn333y
That's what I did lol.. I'm trying to open the file OFT_ZA1JF40C and it keeps giving me error loading ecu definition not found so what is it I'm doing wrongbecause I've literally done everything you said lol
Old 10-22-2016, 07:14 PM   #796
MrFisty
The Fistiest
MrFisty's Avatar
Drives: 2013 Argento FR-S
My calibration ends in A01C, but OFT will only let me use A00. Help?
They said my last sig was too big.
MrFisty is offline   Reply With Quote
Old 10-22-2016, 08:49 PM   #797
alxtheoreo
alxtheoreo's Avatar
You'll need to download the new maps from the OFT website. You'll fine all the .bin files there.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
The Following User Says Thank You to alxtheoreo For This Useful Post:
MrFisty (10-23-2016)
Old 10-23-2016, 05:22 PM   #798
MrFisty
The Fistiest
MrFisty's Avatar
I actually did that.
Here's an update. When I put my original file back on my car, I read the ECU info to check the cal. It ended in A01C. Then, whilst downloading the new stuff, which I was simply re-downloading, I checked the cal via OFM. It read A00.
Now, I've put the stage 1 back on and I checked the cal through my tablet and ecu. Now, the read calibration on the car ends in B01C. Why is what OFT reads my ecu's calibration to be changing?
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
