Old 10-16-2016, 08:46 AM   #15
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by The Racers Line View Post
Very nice, I have something similar designed, but haven't figured out my reverse lockout yet. I would love to try this thing out though.
A customer of mine is racing in Germany currently, I wonder if he can bring it back for me....
I am sure a significant amount of R&D goes into a product like this to get the right feel and reliability. Remember they made shifters for BMW for a long time before making one for the FT86.
Wouldn't it be a lot easier for you to ask them if you can become a dealer? It seems like there are already at least 2 potential customers in this thread. I phoned with them when ordering mine, so if you are interested I could help you with contact details.
Tor is offline   Reply With Quote
Old 10-16-2016, 12:04 PM   #16
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Actually, I have already started chatting with them! It looks like I am going to be bringing a few into the states! I'm very excited to try this out in my shop car as well.
Thanks for starting this thread!
The Racers Line is offline   Reply With Quote
Old 10-17-2016, 12:51 AM   #17
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
I'd be interested in one. Let us know when you get them.
djwishbone is offline   Reply With Quote
Old 10-17-2016, 02:12 AM   #18
ryoma
ryoma's Avatar
hopefully it has similar travel distance/feel to the CAE
Old 10-17-2016, 09:21 AM   #19
bhmax
Drives: 13 BRZ, 17 Focus RS
I'm assuming the shaft/shift knob area is aluminum? Curious how hot it would be after sitting in the sun for a while since a different knob obviously isn't an option.
bhmax is offline   Reply With Quote
Old 10-17-2016, 03:18 PM   #20
ryoma
ryoma's Avatar
in my MR2 when I had a black aluminum ball knob (stupid idea, I quickly switched that out) I used a brake reservoir sock over it when parking. I learned my lesson when I basically burned my palm trying to reverse out of the parking spot (reverse was really hard to get into and needed some force).
Old 10-17-2016, 09:37 PM   #21
Tor
Tor's Avatar
Drives: Toyota GT86
Yes, the whole assembly is aluminum. It's very lightweight, I can imagine that it could get hot, but given that it doesn't feel like it has a lot of mass my guess is that it would cool equally fast.
Old 10-18-2016, 12:32 AM   #22
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Definitely interested in this. Subbed for future content.
drew_kar is offline   Reply With Quote
Old 10-18-2016, 02:56 AM   #23
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Pretty cool option to the CAE. Not sure about the bracket design - with that geometry it looks like it would flex much more than the CAE, CAE is rock solid in feel...like SOLID with zero hint of any movement when the shifter is put into gear. One difference, beside the much thicker walls of the shifting mechanism in the CAE, is there is a reverse lockout stop adjustment on the CAE and not one on the IRP.
Would really be interested on how the IRP compares to the CAE in shifting feel.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 10-18-2016, 03:33 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
Unmodifiable and metal knob might make usability issue indeed. Of course, if one considers just and only track use with gloves, not so much, but i guess that most will still put on way longer mileage during dailydriving outside track. Would be nice to see it customised with some delrin(?) cover around knob to increase "normal" driving comfort/usability, imho shouldn't increase price too much.
Old 10-18-2016, 07:48 AM   #25
M1K3
M1K3's Avatar
Drives: vrooom...
I too like Vracer run the CAE, which I think is a really amazing shifter, but would have really thought hard about giving this IRP shifter a shot if it was available at the time.
The one key difference I see between the two shifters is the centering spring on the CAE shifter that brings the shifter back to neutral when you pull it out of gear, which I see the IRP does not have. I too would really like to see how the two shifters compare in shifting feel.
M1K3 is offline   Reply With Quote
Old 10-19-2016, 12:16 PM   #26
Tor
Tor's Avatar
Drives: Toyota GT86
I ordered some spare parts yesterday and hopefully will get it installed over the weekend. I don't know if the parts are actually needed or not. But someone made a DIY on the German forum and recommended changing them. My car is 3 years old but low mileage. Probably it's not really necessary. But as I don't want to get stuck in the middle of the install I ordered them too.
It's just some small stuff for a few bucks only. As the bill is lying here on the table next to me I'll might as well list the part numbers:
Rubber boot (Subaru: 35016CA020 Toyota: SU003-00881) - 14.88€
O-Ring (Subaru: 35035CA020 Toyota: SU003-04101) - 1.24€
Split (Subaru: 35057CA010 Toyota: SU003-00898) - 3.30€
Washer (Subaru: 35038CA010 Toyota: SU003-00892) - 2.08€
As a rough guideline, I guess you can convert € to $ 1:1.
There is no way in hell that bracket will flex (if it flexes you have bigger problems! ). It's 4.5 mm aluminum. Any thicker would just be unnecessary weight.
I'll report back if it's an issue or not when putting it into reverse.
I never saw the CAE shifter in person and was wondering what the purpose of the spring was. Thanks for clearing that up. Stock shifter doesn't return to neutral either so the question is how much a difference it makes during actual shifting. Maybe it's just for easier getting into neutral? Obviously, I won't be able to compare but I'll keep that in mind as well when driving it and report if it would feel like something I would be missing.
Old 10-19-2016, 07:04 PM   #27
redlined600
redlined600's Avatar
Drives: Fr-s
I think his statement was worded slightly ambiguous. What he means is that the spring helps the shifter return to center when not in gear. The stock lever returns to center when not in gear but is controlled by the springs in the trans.
redlined600 is offline   Reply With Quote
Old 10-19-2016, 07:50 PM   #28
Crazypinoy9
Drives: FR-S TRD RS1#1488
Where are you guys seeing that they won't ship to the states? Comes up fine for me...
Crazypinoy9 is offline   Reply With Quote
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
WTB: Megan Racing Cat-Delete pipe And short shifter AZ_Racer_1 Want-To-Buy Requests 1 01-25-2015 12:54 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Short Vid about Okinawan Street Racing vividracing BRZ Photos, Videos, Wallpapers, Gallery Forum 1 03-03-2014 10:29 PM
TOM'S Racing Parts, First from Vivid Racing! vividracing Exterior Parts - The Rest 4 09-11-2012 04:20 PM
